Chain and Cogs: Don’t wait too long!
Our Community › Forums › Bikes & Equipment › Maintenance › Chain and Cogs: Don’t wait too long!
- This topic has 101 replies, 40 voices, and was last updated 9 years, 5 months ago by
huskerdont.
July 11, 2014 at 3:22 pm #1005661
Participant@jrenaut 90018 wrote:
I’m assuming the chain broke and got caught in the cranks? I don’t see how else it could have flipped him over the bars. Anyway, if you haven’t done it recently, go lube your chain and make sure it’s still in good working order.
I think it probably was just the momentum of pedaling; if you suddenly surge forward with no resistance from a chain the chances of going forward over the bars are great. Especially if you are working out of the saddle, etc.
Most (actually, I think all) chain failures I’ve had have been on mountain bike and there was nothing wrong-looking with the chain beforehand. But it was newby riding errors like shifting under load coupled with the more significant torque of mtb that caused those failures, I assume.
July 11, 2014 at 3:35 pm #1005665jrenaut
ParticipantHis bike is a very old steel road bike. When we did the century in May he had to get some emergency parts because the axle that goes through his pedal sheared off a mile into the ride.
July 11, 2014 at 4:43 pm #1005674n18
Related to this thread – make sure your chain is in good shape. I don’t have good details on what happened, but my brother-in-law was in a bike accident out in San Fransisco. He’s okay, but according to the woman who used his cell phone to call his wife, his chain broke and he went over the handlebars. He lost a few teeth, some of which had to be cut out of his lip, and he broke his elbow, which is going to require surgery.
The chain probably got stiff links, combined with missing “missing links” or bad links that broke. When my chain got rusty, and I switch to the fastest speed, stiff links sometimes roll at the bottom around the largest gear in the front then going upward and under the chain on the top part of the front gear, resulting in the front gears locking up, and you can’t peddle forward, not even an inch. The only way to move the cranks at this stage is to peddle backward. It’s unnerving when it first happened to me as I didn’t know what’s wrong. I peddled backward by small amount, then forward, but nothing happened until I peddled backward quarter to half turn and seen the chain dropping. Going home and lubing the chain fixed the problem for a while.
I am sorry that this has happened to him, I wouldn’t think that something like this could happen. Cyclists need to be educated on the seriousness of this issue. Many are concerned with frame strength, but these days they are building them better than they used to.
January 4, 2016 at 5:35 pm #1043890AFHokie
ParticipantWhile my bike was at REI they replaced a chain that showed just under .75 wear with the 3.2 park tool wear indicator. With the new chain/old cassette it shifts fine until under a load, (up hills, hard acceleration from a stop, etc) then it jumps or skips. It doesn’t appear to skip with infrequently used cogs, but I’ve only ridden once with the new chain…tonight’s commute home sould be fun.
Did I run the old chain too long and kill the frequently used cogs, or is this something common that needs a few more rides to settle, or an additional cable/derailleur adjustment?
If it helps its a SRAM PG-950 9spd cassette the bike came with & has ~3200 miles.
January 4, 2016 at 5:55 pm #1043891huskerdont
It’s quite common to have a new chain slip on an old cassette. I pretty much always replace the cassette when I replace the chain after once or twice trying to see if I could get by and finding I couldn’t. Your symptoms are exactly what happened. If possible, leave it in a cog that works and use the front derailleur to compensate until you can get a new cassette.
January 4, 2016 at 6:07 pm #1043895TwoWheelsDC
Before buying a new cassette, try adjusting the RD…shift into one of the skip-y gears, lift the rear wheel off the ground and crank the pedals while twisting the barrel adjuster until the skipping stops (if the RD shifts a cog, you’ve twisted too far). Then run through the gears and re-adjust as needed. If you can’t get the skipping to stop, then it may indeed be time for a new cassette.
If you don’t have a stand readily available, just hang your bike on a tree branch from the nose of the saddle.
January 4, 2016 at 7:02 pm #1043900Vicegrip
ParticipantI now go through 4 or more chains per cassette. The first chain on my modern bike I ran too long and I ate the cassette up along with the chain. Learned my le$$on about $aving money the hard way and I now check and replace the chain just a bit before it hits .75.
Keeping the chain well oiled goes a long way. I no longer go to great lengths to clean the chain other than wiping the globby chunks off when I re-oil. For me it seems chains last the same amount of time and miles cleaned and oiled often as when they are simply just oiled often. I re oil often as needed or more and always after it gets wet. While slowly turning a crank backward I drip in chain oil until the chain is fully wet then turn for 15 seconds or so to work the oil around and in. I then wrap a bit of end of service life shop rag around the chain and spin the crank some more to wipe off the excess oil and most of the black gunk. Takes 60 seconds or so to re oil this way and no mess to clean up.January 4, 2016 at 7:32 pm #1043904dkel
This would depend on what type of skipping we’re talking about. If the chain is jumping teeth, it’s probably not a derailleur trim issue, but a worn cog. If the chain just doesn’t want to settle into gear, that’s a derailleur issue.
January 4, 2016 at 7:37 pm #1043905vvill
ParticipantI have so many bikes, cassettes and wheels that I have no idea how much wear is on each anymore.
January 4, 2016 at 8:56 pm #1043911hozn
Keeping the chain well oiled goes a long way. I no longer go to great lengths to clean the chain other than wiping the globby chunks off when I re-oil. For me it seems chains last the same amount of time and miles cleaned and oiled often as when they are simply just oiled often. I re oil often as needed or more and always after it gets wet. While slowly turning a crank backward I drip in chain oil until the chain is fully wet then turn for 15 seconds or so to work the oil around and in. I then wrap a bit of end of service life shop rag around the chain and spin the crank some more to wipe off the excess oil and most of the black gunk. Takes 60 seconds or so to re oil this way and no mess to clean up.So replacing chains between 0.50 and 0.75 for me gets me roughly 4 chains per cassette — or about 6k miles at 1.5k miles per chain. (On my commuter.) Last cassette I decided to just run the chain and cassette to the ground together and I got ~4500 miles on the chain and cassette before it started skipping (ever) and ran it up to about 5k before I felt like the performance really was suffering. So I don’t think I’ll change chains out anymore — at least not to save money.
January 4, 2016 at 8:58 pm #1043912sethpo
ParticipantI recently had a chain skipping issue that turned out to be a stuck link. The chain was pretty clean and only about 1/2 through it’s normal life span. I lubed the heck out of the link but that didn’t really work. I ended up using this method to fix it.
https://www.youtube.com/watch?v=QU79CQsz-Ps
I guess it got just a tad bent somehow. Anyway, if you have skipping be sure to check that the chain links are functioning properly as well.
Oh, since we’re talking about chains: I go w/ the cheapest available. I’ve not found any difference in performance or durability with more expensive chains. KMC4me! YMMV of course.
January 4, 2016 at 9:12 pm #1043914Crickey7
That’s my experience as well. I wear them out together and get around 5k per, less if I fail to clean them religiously. The one warning is that I think this method wears out your chainrings somewhat quicker than the alternative, but, again, not sure it’s worth changing that. I’ll get around 10K out of my chainrings, and I suspect I would not get than much more if I changed chains more frequently.
January 4, 2016 at 10:33 pm #1043922Steve O
ParticipantI have never kept track before, just waiting til problems develop. But now that we are having this discussion, I’m in a good position to do so. I switched out my entire drive train last spring after FS ended, going to 1×9, so everything was new. I can check Strava for my miles and see how far I go before it all goes to crap. I’m probably at close to 4000 miles right now without any noticeable issues. I wonder if having a single on the front will make it last longer, since the chain isn’t ever being dragged across it.
How do I add up all the miles for one particular bike within a date range? I can add up my total miles, but that includes miles on other bikes and CaBi, etc. than just the one in question.
January 4, 2016 at 11:52 pm #1043928dkel
ParticipantI’m not sure what I’m doing differently from everyone else, but by way of comparison, I am at 6000 miles, and have only swapped out my chain once—not that long ago. I’m nowhere near .75 on the new chain, and things are running great. I do a lube and serious wipe down about every 75 miles or so, but that’s it. I expect my current chain will run another couple thousand miles at least, and then I’ll change the cassette. My theory is that it’s because of the extremely long front fender—with mudflap—that runs only a couple inches off the ground. Or maybe I’m just lucky. Either way, I’m pretty happy about it!
January 5, 2016 at 12:15 am #1043932hozn
ParticipantMaybe you ride gently? Half kidding
I definitely know there are folks that get 10k on chains without fenders, so I don’t think the fenders are a significant factor. But I could be wrong. I do definitely get longer chain life on the bike that doesn’t get ridden in the rain as much. But I noticed no difference in chain life moving from almost-touching-ground mudflap to no mudflap. (Also no significant difference in how dry/wet my feed ended up, though I suspect there was *some* difference if someone were to apply science there.)
