Chain and Cogs: Don’t wait too long!
Our Community Forums Bikes & Equipment Maintenance Chain and Cogs: Don’t wait too long!
Viewing 15 posts - 46 through 60 (of 101 total)
  • #974539
    Vicegrip
    just checked my chain with the Park chain checker. Way past .75 😡
    #974540
    So why is the Park Tools device preferable to a ruler?
    #974544
    It is a go-no go gauge so less thought (yeah!) is involved. You get some warning because you go from less than 0.5% to between 0.5% and 0.75% to greater than 0.75%. Takes but a second.
    #974579
    Probably the best option, then, is just to keep riding it until it falls apart (or starts skipping). :)
    #974580
    You also don’t have to touch your chain to use a measuring tool; I haven’t used the ruler method but it sounds messier and more prone to second-guessing. (I use the park CC-2 http://www.parktool.com/product/chain-checker-cc-2 which isn’t a pass/fail tool, but only takes a second to use.)
    #975951
    mello yello
    So I just got my fixed gear back – new crank, chainring, and chain. The shop set it up on the SS side, and I rode it on the Bicycle Space Kingman Island ride last night – whisper quiet.
    When I flipped it to fixed this morning I heard that popping, crunching sound of the chain shifting in the cog – it didn’t really even look all that worn, but I probably should replace it so everything can wear together.
    #976300
    Rod Smith
    I checked my chain Monday morning and it was at .75 with 1075 miles on it. I put 73 miles on it since then. I’ll ride it one more day then guess I’ll change it this evening…
    #978818
    lancito brazofuerte
    My simple fix is this- I change my chain every 4 months and degrease my DT once a month. Sometimes more often if I’ve been riding in the rain a lot. Decent KMC chains can be had for $30-45 a pop and are significantly cheaper than replacing rings/cassettes/cogs once a year. I’ve got 2 years or so on my ring/cog on my track bike with almost no wear on the ring or cog. Same goes for my cassette on my roadie. I recently swapped to Rotor rings on the roadie so no real longevity info there.
    #978821
    that is the cleanest (scariest?) drive train I have ever seen.
    #978825
    eminva
    @eminva 55376 wrote:
    Thanks, Pete!
    One question: I have heard it said that you should replace your cassette whenever you replace your chain. I have also heard that if you replace your chain before it gets too bad you can extend the life of your cassette and don’t need to replace it with every new chain. Is there any accepted wisdom on this point, or do reasonable minds disagree?
    Thanks.
    Thanks — some of you answered my question above, but I asked the question again and got the definitive answer at bike school a couple of weeks ago [aside: I went to the Introduction to Bike Maintenance Class at United Bicycle Institute in Oregon; if anyone is interested in hearing about that, let me know and I will start a thread].
    If a chain is checked assiduously and replaced before it gets too worn, the cassette does not need to be replaced with each chain. However, type of cassette, riding conditions, frequency of cleaning and mileage all contribute to chain longevity and there is no one-size-fits-all answer to how long a chain should last. For my part, I have a 10-speed cassette, ride in a bunch of crappy weather and ride 500+ miles/month on my main bike, so I’ll be changing chains a lot more frequently than I probably thought necessary. I have a chain checking tool and use it fairly often.
    The instructor asked, “who told you you needed to change your cassette each time you change your chain?” He seemed astonished when I replied that it was one of our LBSs. Maybe the average customer waits too long and this is the default advice.
    Thanks all.
    #978832
    Yes, please. Thanks
    #979172
    Greenbelt
    Probably a good idea to replace your chain before this happens…
    #979188
    Nasty, sharp little teeth! They bites, they bites, been there done that, got the scar. ;D
    #979207
    Greenbelt
    Was lucky to make it all the way home with one link in the chain busted off on one side! It made an awesome noise each rotation. Softpedaling better than walking (or Metro), though.
    #979209
    +1
