while we’re talking tires…good compromise between gravel and slick?
Our Community Forums Bikes & Equipment while we’re talking tires…good compromise between gravel and slick?
  • #917463
    Tania
    Got a super fun new bike and it came with Schwalbe Sammy Slicks 35s. No issues with them really although I put my Michelin Pro 4’s on there the other day because I had planned to get up stupidly early and ride some hills with the Bikenetic crew. I slept in instead.
    Anyway, the Pro4’s are still on there (23’s) and coming in this am I was hesitant to hop off the W&OD and onto the gravel side track (sad face). It’s a beautiful afternoon and I’d like to go up the C&O to Chain Bridge and then suffer up 41st but…skinny Pro 4’s and I only have one tube with me.
    Again, no issues with the Schwalbes, just wondering if there’s a better middle ground tire that lets me take some super fun detours on my super fun new bike during my daily commute.
Viewing 15 replies - 136 through 150 (of 202 total)
  • #1060236
    Judd
    @ian74 148768 wrote:
    Yes.
    Everyone is going to die.
    #1060239
    @DismalScientist 148766 wrote:
    Other than studs for ice, I don’t change tires depending on the season. Am I going to die?
    No, but you will inevitably be grouchy.
    #1060264
    Lt. Dan
    but not all of us truly live.
    #1060271
    Wider makes sense to me! But I can’t see any value in knobs and knobby tires are less grippy on wet pavement, as a rule. Maybe if the leaf bed were very thick the knobs might find their way through to contact asphalt … ?
    A tire with rubber designed to grip well in cold temps is not a bad idea this time of year, as Emm points out.
    #1060274
    Raymo853
    Mounted my Sector 32 tires. They are a little smaller than the 32c Roubs. Assume they might plump up a bit overnight.
    The left one below is the Sector
    #1060275
    Let us know how they fare. I have heard nice things about the Sector/Secteur 28, so I imagine those apply here too. The $100+ price was a bit steep for me back when I was looking at the 28s, but probably one can find them cheaper now.
    #1061311
    Raymo853
    Wow. I was very upset with my Sectors today, until I learned what I ran over. I ran over a puncture plant that produces goat heads. No bike tire can handle them. Even motorcycles and cars are at risk.
    Luckily I had just added sealant. After digging all 20 plus goat heats out, both tires sealed up and are fine.
    #1075783
    Raymo853
    Suspect I will post to this thread every six months for years.
    I bought two pairs of Panaracer Gravelkings SKs, 35s and 40s. I love them both. I have used both for commuting, gravel riding, and super rocky degraded washed forest roads. They have been amazing. Rolls great on pavement, handle gravel and dry trails perfect, and really encourage my leaning over in turns on pavement and gravel. Makes me sad I did not get dedicated gravel tires earlier.
    Photos of the 35 vs 40. The 40 is wider, but most of the extra size seems to come in volume, which I like. The 40 is on a bigger rim, an Easton Heist 27 internal vs a Stans Arch EX2.
    [ATTACH=CONFIG]15461[/ATTACH]
    [ATTACH=CONFIG]15462[/ATTACH]
    #1075784
    Raymo853
    Photos of the 35 vs 40. The 40 is wider, but most of the extra size seems to come in volume, which I like. The 40 is on a bigger rim, an Easton Heist 27mm internal, vs a Stans Arch EX2, a 23.5 mm internal?.
    #1075788
    UnknownCyclist
    You know, if you have enough to drink, you can’t tell any differences between tires.
    #1076835
    vern
    This is an amazing thread. After carefully reading all of the posts I decided to order a pair of Specialized Roubaix Pro 2BR tires for routine commuting on my new cyclocross bike, that is, until the snow starts flying.
    #1076842
    Raymo853
    The 40s did get bigger after a few rides, like way too big. I went back to the 35s and the 40s are going to be saved for really crazy gravel/single track rides. The 35s are just perfect, would be spot on for anything out near Leesburg.
    #1076847
    I rode a set of the 43mm version of these tires for a bit. I think the 35mm might have felt nicer — probably lighter.
    – The volume was nice and the traction felt marginally better than my go-to G-One tires.
    – They definitely rolled slower (stiffer sidewalls?) than the 40mm G-One which at the end of the day made me always want the G-One tires.
    – On my third off-road ride I got a nasty puncture right in the center just riding along — to big to seal. This probably would have happened on my G-One tires too, but it spooked me off so I won’t bother replacing the tire that had the big puncture. (I’ll probably repair the tire and give them away to someone that wants to try big-volume gravel tires.)
    So my thoughts are that the GravelKing SKs are great value if you want to walk into a bike store and buy tires. If you are willing to order from overseas then you can get the G-One Allround tires for around the same price. IMO/IME the G-One is a nicer tire if pavement is involved in the ride and they work great for off-road riding too. Not great for muddy conditions, but I rode them at the very muddy Hilly Billy Roubaix and would use them again for that. They also worked great at Monster Cross when I dropped the pressure down to 25/30 psi (at the price of my rims, sadly, in that case).
    #1077287
    Raymo853
    My 35 Gravelking earned more affection from me yesterday. On a short ride each tire ended up with a dozen or so goat heads. Pulled them all out, heard a short hiss each time and all the holes sealed quickly.
    Of course my affection may be better reserved for fresh Stan’s at twice the recommended amount.
    Sent from my B3-A20 using Tapatalk
    #1078882
    Raymo853
    Shoot, my Gravelkings left me down on a ride. The sidewall got cut be a rock while on tame single track. Was my fault as I failed to follow my advice, go over rocks, not around. This is my first sidewall cut in years which is insane with my attraction to rocks.
    Lots of the sealant came out. Had to tube it. May try to patch up side wall or may just get some G Ones. f52571f6938bffec294fba3955e632eb.jpg94c1c54d37fb24b3acd9ff4a017fd4df.jpg
