Switching to tubeless
Viewing 6 posts - 1 through 6 (of 6 total)
  • #1122160
    bentbike33
    By “floor pump compressor” do you mean something like this: https://www.universalcycles.com/shopping/product_details.php?id=90584&category=132?
    If so, I recommend loading it to about double the goal tire pressure to ensure a good “pop” of the bead into place. Also, put some lightly soapy water on the tire-rim interface area, all the way around and on both sides. Before that, use at least 2 layers of rim tape. Otherwise at road-bike pressures (even though lower than tubed-tire pressures) the rim tape will stretch too much into the spoke holes so that remounting the tire won’t work without re-taping the rim.
    If you have good quality tires and rims, the mounting process really is pretty easy.
    #1122167
    NoVaNoobGA
    Perhaps you should try YouTubeless?
    #1122183
    YouTubeless would have never worked for me. :)
    #1122177
    Henry
    Keymaster
    Or a better site might be YouClueless? It’s what I need most of the time. :rolleyes:
    #1122197
    Graham
    Thanks great advice i get my compressor on Tuesday I’ll let you know how it goes.
    #1122632
    Dachs6
    It’s been a couple weeks, did you get the bike set up?
