Returning to Cycling and Commuting
Our Community Forums General Discussion Returning to Cycling and Commuting
  • This topic has 6 replies, 3 voices, and was last updated 1 year ago by Gr P.
Viewing 6 posts - 1 through 6 (of 6 total)
  • #1134622
    Rootchopper
    There is a dedicated path for bikes and pedestrians along the ramp from Telegraph to Eisenhower. Completely separated from traffic.  Go straight across Eisenhower to Mill Rd which is saner than Ike Ave. Right on Mill. Slight left on Jameson at the light where Mill goes right. Jameson to Dulany. Left on near sidewalk on Dulany to connect to the Duke Street underpass. (Bikes are allowed.)  Once on the north side of Duke, backtrack on Diagonal to Duke. Go one block and you’re at Callahan and the Temple.
    I hope this is helpful.
    #1134711
    Gr P
    Hello Rootchopper,
    Thank you for your input. I “think” I can picture where / what you mean? I am fairly familiar with Eisenhower Ave., particularly the area around the Metro station. I’ve never noticed any type of separated path on the ramp to Eisenhower.
    Tell me if I’m correct, please. When coming down right side of Telegraph (requires crossing Telegraph at least twice from Hayfield Kingstowne area to stay on a path rather than road), cross N. Kings Hwy, cross Huntington Ave. and then come to the inclined ramp leading from Telegraph to Eisenhower.
    At the bottom of the ramp at the intersection, Ike Metro station to the right, Starbucks straight across the intersection at Ike Ave. and Grist? I know that Grist Mill is adjacent to NSF, CVS and restaurants / movie theater. I definitely know where Delaney is over at the PTO across from Alexandria Metro station.
    If I can make it onto Eisenhower, I might take a right and go to the end and hit Duke near Whole Foods, then head down Duke until S. Union and onto the path by Oronoco Bay Park.
    I just cannot picture where the separated path might be unless it’s concealed by the concrete barriers leading up the ramp? I’m going to drive over to the ramp at Eisenhower this weekend and try to locate that path.
    Much appreciated Rootchopper!
    #1134712
    Rootchopper
    The ramp to Eisenhower is indeed separated by a concrete wall.
    The ride along Telegraph south to the ramp is not for the squeamish. You need to use the crosswalks at Huntington and the slip lane from Huntington to Telegraph. The curb cut to the ramp is at the end of the crosswalk at the slip lane.
    Good luck.
    #1134720
    Gr P
    Heya, Rootchopper, I checked it out Saturday morning and was able to see the path right at the crosswalk up the ramp, concealed by the concrete barriers.
    Thank you so much for pointing out the path to me. As often as I’ve taken that ramp or driven past it, I never noticed it. Now commuting will be a significantly more pleasant experience knowing I’ll be on a path all the way down to Eisenhower!
    #1134753
    Terpfan
    Your other option may be using Van Dorn to the path by old Top Golf that pops you out near Rose Hill.  Few residential roads to Clermont and you can hit the switchbacks that will take you down and below the beltway to Eisenhower Rd which has a path along it the whole way (or at least from there I know it does).
    #1134760
    Gr P
    Hi Terpfan,
    I had considered cutting through Rose Hill and through the Winslow subdivision to hit Clermont right at the top of the steep descent and come out on Eisenhower at the big wall and Ike 495 ramps. That used to be my route in the late 70’s through very early 80’s before they closed Claremont to through traffic, when I worked at Cameron Station (“the good old days”). That does add another 15-20 minutes to my commute. Thus far, pedaling down Telegraph seems to be working alright.
