"Freeze Points" metric
Our Community › Forums › Freezing Saddles Winter Riding Competition › "Freeze Points" metric
- This topic has 84 replies, 32 voices, and was last updated 2 years, 2 months ago by
AlanA.
February 14, 2016 at 12:47 pm #1047628
ewilliams0305
Participant@vvill 134945 wrote:
There would be no curves based on mileage/temperature if it was just supposed to gnarliest, because let’s face it, riding 250+ miles in freezing temperatures on Jan 1 would just blow a gnarliest score out of the water (…hi Eric!) Another element was time –
I think it’s also important to factor in “ride time”, something I failed to do with my longest coldest ride award. I realize it’s important to not only reward people for big miles and cold days but also ride time. I think it’s a heck of a lot easier to ride a metric when it’s 20 degrees out if you can ride a metric in 3-4 hours. If this metric took say 4-6 hours it’s safe to say your suffering on a completely different level. Another example, shuby road 109 miles at 21 degrees yielding a score of 5, I have NO doubt this was a lot harder than say riding 6 miles at 0 degrees. I’ll have to start my own thread about this but I think a good measure would be ride time VS temp.
As VVILL noted my 257 mile ride was averaged at 32 (not cold), but after 12 hours of being outside I can tell you I’ve never been this cold in my entire life.
February 14, 2016 at 12:58 pm #1047629Rod Smith
Participant`I like to wait until it warms up. Kudos to those hearty souls wise enough to ride in the middle of the day when the sun is at it’s highest above the horizon.
January 14, 2021 at 12:07 pm #1109196BigBaldy
ParticipantNoob question – got a Garmin for Christmas…how do you set it up to repport the weather on your rides, especially when linked to Strava? Mostly just interested, I generally wimp out if it’s < 37-38 degrees. Thanks...
January 14, 2021 at 12:21 pm #1109197josh
I’m not 100% sure what exactly you’re asking — if it’s related to the Garmin itself, I’m not sure. I have a Wahoo Elemnt Bolt that has a thermometer, and so logs temperature. Strava, as of April 2020, includes weather data for activities for premium subscribers. There are free apps that do similar things, such as Klimat (which I believe has free and premium tiers). This thread is about Freeze Points, which use Dark Sky as the source for weather data (previously Weather Underground). All the other FS weather/temp-related things also work in a similar way I believe. Hopefully this answers your question.
February 15, 2022 at 4:19 am #1119357sszibler
ParticipantDoes Dark Sky look at the whole ride for freeze points, or like Klimat, just looks at the beginning temps and you get that temp for all your miles?
February 18, 2022 at 4:09 pm #1119588merlin
The code believes that it samples the weather data hourly over the entire duration of the ride based on your approximate start lat/long rounded to 1 decimal place, so within 10 miles or so. Temperatures are averaged, precipitation is accumulated and scaled so if you rode 30 minutes you get half of the hour’s precipitation, or if you sat in a coffee shop for 3 hours of a 4 hour ride you’ll get 1/4 the weather. For technical reasons if you do a massive ride starting just before midnight your weather credit will be shortchanged. Some of this could be improved, but the weather data are so unreliable and the code test coverage so non existent, the bearing of any of this on reality is questionable and any improvements would as likely as not not be.
March 19, 2023 at 12:13 am #1126302AlanA
ParticipantAs someone battling for the ‘reverse’ freeze points this year, I would love to know how the other end of this game works. I was so far ahead a few weeks ago, and now someone is ahead of (below) me.
March 20, 2023 at 10:37 pm #1126371merlin
Well, so freeze points is the sum of the daily max of (11*(ATAN((R.distance+4)-2*PI())+1.4)-2.66)*(1.2+ATAN((32-W.ride_temp_start)/5)) which clearly explains how you lost your spot.
March 20, 2023 at 11:15 pm #1126372 -
