Data & techie stuff for BAFS 2017
Our Community Forums Freezing Saddles Winter Riding Competition Data & techie stuff for BAFS 2017
  • #918868
    I noticed that the FS website is showing recent photos.
    Please remind us how that happens. Are all photos associated with a Strava ride shown on the website, or do we need to hashtag them?
    If it’s all photos, is there a way to opt out of having a photo shown on the website?
    What about Instagram? Is there a hashtag to use?
    Any other instructions or tips about photos on the Freezing Saddles website?
    [ATTACH=CONFIG]12950[/ATTACH]
Viewing 15 replies - 76 through 90 (of 179 total)
  • #1064212
    BobCochran
    @jrenaut 153031 wrote:
    If you can get that distributed model to work at scale, I can find you a half a billion dollars in venture capital.
    Well there is the guy who got Linux to work and then Git. I’m pointing at Git. Distributed, at scale, and it works. Don’t worry about the half billion, now. I’m happy with my heavily taxed gross pay and my heavily taxed net pay.
    #1064226
    Basic works great. The line numbers are great for keeping programmers organized.
    #1064230
    10 PRINT “Go away”
    20 GO TO 10
    #1064236
    @BobCochran 153030 wrote:
    So you have n rides out there and each one has a cell phone and the phone could be running a nice virtual machine in the form of a Docker container. And no I don’t know Docker well. I haven’t studied it closely and most of all played with it the way I should. But anyhow these riders are each running a virtual machine and inside that machine, a Freezing Saddles app is humming away. It’s recording the miles the rider is doing. It’s storing that data away.
    Meanwhile, Node, or some other ES6/ES7 scripting engine, Express, and MongoDB all containerize well.
    Even SQLite containerizes well.
    What you’re describing is basically fulfilled by applications like Srava. They are not distributed in the same way that Git is, but the effect is the same: you log your miles, they’re stored away, and you look at your dashboard and you see all your friends’ activities just as soon as they post them. There’s no need to reinvent that system. Sure you could do it without Strava, but Strava does it elegantly. Not to mention the herculean effort to create Android and iPhone ride tracking apps … The problem right now with the traditional Strava API is that it must be polled to learn of new rides. Well, this actually is less true than it used to be; they have added webhooks (http://strava.github.io/api/partner/v3/events/) which allow an application to subscribe to events like “new activity”. If someone (hint, hint :)) would like to implement that in Freezing Saddles it would mean real-time updates to our leaderboards. As it is, though, having a few minute delay is not exactly terrible for our purposes. Probably there would be some benefit to a tighter sync on the last day of competition, but with a competition sized at 250 people, we’re able to sync all the riders on a very regular basis. (And Strava increased API limits for our app. The weather data has a more limiting API — 500 reqs / day, which when you consider that participants often ride more than once per day is much closer to maxed out.)
    There’s really no technology problem with FS, other than a million things we could build but no one with the time to do it. We could, for example, start using the geo indexes — show participants other people that ride similar routes and start at similar times of the day. We could find intersections in routes to find out who crosses paths with regularity and where they cross. You could find areas where most cyclists seem to converge around the sames times and propose new coffee-shop locations. You could find out the best roads to ride when it snows. Or what the trail conditions are based on riders’ routes, speeds, wattage, etc. We could find groups that ride together. Really, the possibilities with the current datasets and possibilities are pretty endless. What great data for dataviz exploration. I’m a bit sad that my work always becomes a frenzy in winter time, as I find the possibilities endless. I probably would make some technology changes if I were really working on the project, but we certainly haven’t run up against any serious technology limitations to date. The constraint is human resources.
    On a side note, Docker is interesting technology (I use it every day), but I’m not sure it makes sense in a phone context. You don’t need docker to have sandboxed applications on phones and there’s probably little value to running n instances of a georecording container (app) on a phone. Docker is a great tool for software deployment on server infrastructure, as it simplifies configuration management, empowers developers to work with deployment-like images, and makes provides a nice abstraction for scaling and orchestration frameworks. Those use cases don’t really apply to people’s personal phones, though.
    To be honest, I don’t know much about NodeJS, Express, Mongo, etc. I’ve done a fair bit of async programming, though, and so I bring a little bit of skepticism that these are simpler ways to build applications. Async programming — promises/deferreds, callbacks, etc. — is hard. Harder, in my opinion, than managing threads and shared state. But, to be fair, most of the actual “work” being done by an application like FS is I/O work, specifically HTTP and database. And, assuming you have async db drivers (which I’m sure mongodb does since that’s the poster child for use with nodejs), this certainly can be handled well in an async model. But I don’t see any inherent advantage. I’m admittedly not a huge javascript fan; ES6 is better, but I would never look to JS as a server-side language. The state of JS package management is an absolute feed frenzy. Transpilers make debugging even more complicated. And debugging callback hell or Promise chains is absolutely ridiculous. But that’s enough about that! :)
    #1064241
    BobCochran
    @hozn 153056 wrote:
    Well, this actually is less true than it used to be; they have added webhooks (http://strava.github.io/api/partner/v3/events/) which allow an application to subscribe to events like “new activity”. If someone (hint, hint :)) would like to implement that in Freezing Saddles..
    Hans, thank you for taking the time to discuss this with me. I hear you about webbhooks and geo indexing.
    A little earlier you were hinting at a user interface you are interested in. Can you please tell me more about that when you have a moment? I should have asked for details earlier but forgot.
    Thanks a ton
    Bob
    #1064242
    My #1 want out of the website is to start pulling the “rode with” data from Strava so we can track team rides. I looked at it last year and didn’t get anywhere. Maybe I’ll try again.
    #1064252
    I came up with a strawman scoring system for this if you can figure it out.
    #1064270
    Thanks a ton
    Bob
    Here was where I had started long ago: https://github.com/hozn/freezingsaddles-aurelia
    #1064306
    BobCochran
    Complex.
    #1064320
    BobCochran
    Hans, thank you for pointing me to freezingsaddles-aurelia. Can you give me a statement of what you want the user interface to do — what are your goals for the user interface? Do you have a list of features?
    Thanks a ton
    Bob
    #1064334
    Thanks a ton
    Bob
    I responded breifly on GitHub to your issue, but basically “no” — I don’t have any documentation. There are some things that could be done better in a SPA — interactive viz and leaderboards, for example. Also getting server push on changes. Better photo gallery feature would be high on my list. Otherwise, the goal was to provide same functionality as current site.
    But if you want to help there are many features that could be added to the current system. That is much higher priority. E.g. you could fix the charts. Switch to Highcharts, maybe. The charts on the site look pretty horrid.
    #1064461
    BobCochran
    I’m experimenting with a Node.js- and MongoDB implementation. I’m in the early part of designing and have little to show you. I’m working on documentation first of all, and experimenting with code as I go. When I forked the “freezingsaddles” GitHub repo, I created a new branch and now work entirely in that. Yes, I push the new branch to my own GitHub repo every now and then. I expect to make many errors along the way. My CSS skills are so rusty for example. Time will tell if if this work is really helpful.
    Thanks a ton
    Bob
    #1064483
    kwarkentien
    This may not be the right place for my horribly first world problem: my ride photos do not appear on the photo stream. They are Instagram, taken and uploaded during the ride, and I’ve “refetched” the photos to no avail. I’m so pretentiously devastated by this travesty. Can anyone help?
    #1064486
    BobCochran
    I think contacting Hans (user hozn) is a good idea.
    I did some quick Googling and this might help you:
    https://support.strava.com/hc/en-us/articles/216918517-Photo-Integration-with-Instagram
    Disclaimer: I’m not an Strava expert, nor am I an Instagram expert. I’m learning a lot of new stuff through Freezing Saddles myself.
    Bob
    #1064538
    Yeah, there is actually a problem with the site sw. Strava changed their API here a bit and Instagram photos are not currently working with the sync.
    I need to find some time to investigate and fix this. We should be able to grab photos retroactively once the code is corrected.
