Compression plug and top cap
Our Community Forums Bikes & Equipment Maintenance Compression plug and top cap
Viewing 2 posts - 1 through 2 (of 2 total)
  • #1106873
    ImaCynic
    Sounds about right. Install the headset, the fork, spacers, and make sure to cut the fork at least 30mm longer than what you think you need(get some extra spacers!). Also be sure the cut is perpendicular(use a jig/guide), wrap the cut area with tape, and use the correct saw blade for carbon. It appears that your compression plug has a lip that sets the depth, so one less thing to worry about. Just account for this lip thickness when determining your stem height.
    Good luck!
    Sent from my motorola edge using Tapatalk
    #1106877
    secstate
    Thanks — this is very helpful.
    After finishing the bike, I’m taking it in for a bike fit. The fitter indicated he’d cut the steerer tube if needed, so I shouldn’t need to worry about that!
    It’s been a fun project so far. I was never a gear junkie until suddenly I needed to pick out every component. I’ve also learned a lot about bikes, which was part of the point. Just hoping it comes together without too much frustration and results in a bike that’s well-tuned, safe to ride, and provides a new toy to get me through Freezing Saddles. I may have a mechanic inspect it when I’m done.
