Why you should not trust a cable lock
Our Community Forums Bikes & Equipment Why you should not trust a cable lock
  • #919665
    I have just learned that a not particularly strong, not particularly skilled with tools 50 something, armed only with a simple bikehand cable cutter (YC-767) , can cut through such a lock in a surprisingly reasonable period of time.
    Also, whatever kind of lock you have, be sure to have a spare key handy.
Viewing 15 replies - 1 through 15 (of 16 total)
  • #1074864
    anomad
    Combination locks are nice. Keyed locks that only allow you to lock with the key are nice too.
    I learned that lesson once after swimming laps in Phoenix Arizona late at night. Luckily the folks at the pool had a big ass pair of bolt cutters for the locker room that made short work of my lock.
    This would work too:
    [ATTACH=CONFIG]15381[/ATTACH]
    #1074865
    honestmachinery
    That would do it. As would a $50 cordless angle grinder from the big box, plus five minutes. Any lock, pretty much.
    #1074859
    AFHokie
    Less than 2 if not under a minute really
    #1074861
    Vicegrip
    5 min? Only if you spend 4 min 40 seconds doing something else. A craptastic harbor fright $30 cordless angle grinder will defeat a $300 “New york” format lock in seconds. After a friend lost his key and was stuck I went through a best of the best motorcycle lock in under 20 seconds and that was being careful of the bike too. No need for the $1000+ gas chop saw. I am always looking at bike lock setups people use. Have not seen one yet that looks like it would be hard to defeat with an angle grinder/cutoff wheel.
    Not trying to be bummer bob. Just pointing out that locks only slow thieves down.
    #1074863
    Birru
    That’s the sad reality. There’s not a bike lock out there that will stop a thief. The best you can hope for is yours is good enough that if a theft is going to happen, other nearby bikes will look like more convenient targets. But if a thief really wants your bike, he’s going to have it.
    #1074856
    petego
    My bike is not super pricey but I always try to put at least 3 locks if I leave it for more than 5 minutes. I always pray thieves just wouldn’t bother
    #1074858
    Assuming I do not pursue a second career in the bike theft business, and that I never end up using a lock for which I have no spare key again, there isn’t really any benefit to this newly acquired skill, is there? Helping others who are as stupid as I am?
    #1074848
    EasyRider
    The best locks will stop bolt cutters, but nothing can stop an angle grinder, is that right?
    #1074849
    anomad
    @lordofthemark
    Well if you catch SteveO accidentally cable locking himself to cats he’s throwing off 14th Street bridge you could help?
    #1074838
    FFX_Hinterlands
    I was just in Paris and nearly every bike had three locks. 1-2 U locks and a chain lock (or a frame lock, chain and heavy u lock). Even the little old ladies on Dutch bikes had three locks.
    Here was a creative lock job I just had to capture:
    [ATTACH=CONFIG]15385[/ATTACH]
    #1074917
    ian74
    You’re still using cable locks? You crazy!
    #1074918
    Vicegrip
    With bike locks that tends to be true. Put it this way, there are no metals or alloys in common use that can’t be cut with an abrasive cut off wheel. Mild steel, case hardened steel, Boron steel, stainless steel, titanium all cut just fine. (Titanium makes fantastic pure white sparks forth of July style) The nature of what the bike lock has to do means that it is exposed. It has to go around some of the bike and then something else. This means the lock and or components of the loop has a flank that can be attacked. OTOH look at a job site tool box. All you can see of the padlock is the butt end of it 2 inches down in a hole. You ether pick or drill it or take the angle grinder to the box to go after the locking mech inside. 20 seconds turned into 2 min with prior knowledge of how that box locking system works.
    Some padlocks have skirts that shield the sides of the shackle and in the right use this makes it hard to bolt cut and with the added metal to have to cut a bit harder to cut with an abrasive wheel. Puck locks like the ones you often see on van doors have no exposed shackle but they can be defeated in seconds with a cut off wheel if you know how (and I ain’t tellin’)
    Some of the cable lock makers tried using goo that burns with nasty output and lubed cable in sleeves to make it hard to bolt cut or torch but even that format succumbs to the abrasive wheel with just a slight bit of know how. The motorcycle lock I sliced through was that format. The owner was bug eye stunned. Bless his little heart. He actually thought it was as human proof as the advertising said……
    No I am not a burglar. I am one to the people that has to deal with stopping them as part of my work.
    #1074919
    EasyRider
    I’m def resigned to angle grinders, but I do pay attention to bolt cutter resistance. I see padlocks from $10-$100 advertised as not being vulnerable to long handled cutters. I understand that having the lock near the ground allows a thief to use their body weight and the ground to their advantage, instead of just applying arm strength the the handles. What locks are legit?
    #1074921
    In this case the cable lock was used to secure my bike INSIDE my locked, fob controlled apt building bike room (theoretically accessible only to people registered for numbered spaces in the bike room, and to building management). While I doubt anyone in my building is going to steal my bike, I don’t want to tempt anyone. I also DID sometimes use it for very short lockups (to go inside a store or to use a restroom) IN Northern Virginia. However as I am no longer in possession of an intact cable lock, at least for the foreseeable future I will be using a U lock for those purposes.
    #1074928
    When my bike was stolen at one point, this is what the police told me to do. He said that most bike thieves bring tools for one kind of lock (U-lock or cable), so having two different kinds of locks made you noticeable safer.
    Of course, in my case, I also help to prevent theft by being the least valuable bike locked up in any given area.
