while we’re talking tires…good compromise between gravel and slick?
Our Community › Forums › Bikes & Equipment › while we’re talking tires…good compromise between gravel and slick?
- This topic has 202 replies, 44 voices, and was last updated 6 years, 4 months ago by
GP_Slowride.
October 14, 2015 at 7:01 pm #917463
Tania
ParticipantGot a super fun new bike and it came with Schwalbe Sammy Slicks 35s. No issues with them really although I put my Michelin Pro 4’s on there the other day because I had planned to get up stupidly early and ride some hills with the Bikenetic crew. I slept in instead.
Anyway, the Pro4’s are still on there (23’s) and coming in this am I was hesitant to hop off the W&OD and onto the gravel side track (sad face). It’s a beautiful afternoon and I’d like to go up the C&O to Chain Bridge and then suffer up 41st but…skinny Pro 4’s and I only have one tube with me.
Again, no issues with the Schwalbes, just wondering if there’s a better middle ground tire that lets me take some super fun detours on my super fun new bike during my daily commute.
February 12, 2016 at 4:17 pm #1047686
vern
Participant@Powerful Pete 126225 wrote:
Don’t go with the Gators. Cycling is meant to be fun. Honestly, a less enjoyable riding tire is yet to be invented.
I am converted. After two flats this week I changed tires last night and put on a pair of Gatorskins that I bought at a deep discount late last summer. I had used them before and didn’t really notice anything. The tires I replaced last night were stock Mavic tires that came on the wheels I bought last fall. Whatever the Mavic tires were/are, I found them to be supple and smooth. This morning, after no more than 50 feet on the Gatorskins I noticed a BIG difference, and none for the good. They felt very sticky, almost like glue on the road. I had dead legs this morning, so that’s probably part of it, but I really hated the way the Gatorskins rolled this morning. Out of guilt (because I payed for them), I’ll probably use them through the Winter and let them take the abuse of all the garbage that’s collected on the roads, but I’m going to switch them out in the Spring, maybe to the GP4000S’s the Hozn touts.
February 13, 2016 at 1:10 am #1047671vvill
I use one of mine as a trainer tire… muahahahahaha. Sweet revenge.
February 16, 2016 at 10:47 pm #1048002Tania
ParticipantWANT WANT WANT WANT WANT.
Want.
I really kinda want them for Monster Cross.
Emailed the company to see if they thought they’d fit my Warbird (I can fit 700×44 and the 40’s on there right now have plenty o’room on either side by the chainstays…
February 16, 2016 at 11:14 pm #1048004hozn
ParticipantI have heard/read about those Rock-and-Road tires as good all-terrain options. I do not have a good option for mud on the ‘cross bike; maybe those would be? But for hardpack and pavement hard to imagine anything better than the Trigger.
(The Panaracer Comets look nice too. Would love to hear a comparison between those and the Trigger.)
February 17, 2016 at 12:05 am #1048008Tania
ParticipantBruce wrote me back right away so I ordered them. You’re welcome to borrow them for a test run when they get here.
February 17, 2016 at 1:52 am #1048013dcv
I’d like to hire you as a personal bike parts shopper
February 22, 2016 at 2:15 pm #1047805Tania
ParticipantIf you’ve got a bike that can handle 43mm tires, the Rock and Roads are AMAZING. I didn’t have any issues with them yesterday at Monster Cross and it was pretty much every kind of surface you can think of plus it rained the last hour so they’ve been tested in dry and wet. Absolutely love them.
February 22, 2016 at 7:11 pm #1047775hozn
How does the pavement rolling compare to the Clements you run normally (are those 40mm MSOs?) ?
My current list of off-road tires to try includes:
– Kenda Flintridge (40mm, tubeless)
– Panaracer Comet (40mm, and apparently works tubeless)
– Schwalbe G-One (40mm, tubeless)But it’ll be awhile before I wear out my Specialized Triggers, so probably any other tire will be one that is less exclusively for hardpack.
February 22, 2016 at 7:21 pm #1047777Tania
I usually keep the 40 MSO’s on there all the time and ride a lot of pavement in them. The Rock and Roads didn’t feel any slower at all – there was a 2-3 mile paved section around mile 10 (mostly uphill?) and both times around I used that section to open it up and gain a lot of time. That could be due to relief at finding some recovery time on pavement though. They only time they felt slow was in a few of the sandier spots (the feeling where you’re not quite sure if your tire is flat or not).
I tried them Sat when I first put them on at 70psi and HATED them. They were squirrelly if you moved the wheel even a little bit and I was really nervous I’d made a huge mistake. But I let out some air and they flattened a bit and were fine. I doubt I would have been as happy with the MSO’s especially after it started raining. I wish I could tell you what I was running but I did it off feel. Probably around 40 which was almost too much.
Seriously – take them for a test spin around Lake FFX if you think they’ll fit your bike (they’re pretty meaty). Once things dry out, I plan to do just this.
February 22, 2016 at 7:26 pm #1047765hozn
ParticipantOk, I might take you up on that if/when the logistics work out. I would be kinda nervous about borrowing tires, but it would be useful to know before buying.
My frame should fit them; it is supposed to clear 45mm tires, though I have not tried anything larger than 42.
February 23, 2016 at 2:15 pm #1048149hozn
Participant@Raymo853 129855 wrote:
First ride this morning to work on the 30/32 Specialized Roubaix Pro 2BR. I am finding it tough to not buy another and replace the Bonti on the front. I love it. Rolled fast, cornered great, holding air well without a tube, had a good smooth feeling ride, and shrugged off one hard pothole edge slam.
It seated up with only a little difficulty on my Stan’s Grails. Like most Specialized tires, it is huge. It has about 0.5 cm clearance to the chain-stays on my Salsa Colossal.
[ATTACH=CONFIG]10253[/ATTACH][ATTACH=CONFIG]10254[/ATTACH]I am grateful you posted these. I ordered a set of these in gumwall to try out after my Schwalbe Ones are finished. Around 5k miles on my One front tire — and no flats. Probably another thousand miles on the set.
I am hoping these Roubaix Pro 2BR fit ok under my fenders; other “32mm” fit, but we shall see! I am very happy with the Schwalbes, but these are cheaper. Worth a shot.
Raymo, what pressures are you running? I see the range listed, but expect that it should be on the lower end when running tubeless. I would like to run these at around 60-70psi if I can since I will be running these as pavement tires and want to keep the rolling fast. But I notice they are not called out specifically as “road tubeless”.
February 23, 2016 at 4:02 pm #1048157Raymo853
ParticipantI am very bad at being consistent on pressures. I typically check and pump them up every so often, to about 60. Too hard, I think 50 is perfect on my wide Grails.
March 2, 2016 at 1:22 pm #1048689hozn
ParticipantI got impatient (and the One with over 5k on the front is looking kinda done). I pumped these up to around 70psi. They don’t feel as fast as the Schwalbes, but the do roll smoothly and look great. At $40 pretty amazing value. I will give them a try on some faster road rides and see if that is noticeably more difficult.
April 18, 2016 at 7:32 pm #1050999Raymo853
ParticipantHere are my Spec Roubaix Pro 2BR tires with some miles on it. It has developed these small round holes in various places. They do not seep sealant at all.
I also have one cut (photo did not come out) that was leaking sealant. I put more Stan’s in and it now is sealed up fine. Held the whole 52 mile Rough Roubaix without and more seepage.
And regarding pressure, I pumped it and the Bonti 28 on the front to 62. That was way too hard, I dropped both mid-RR to an unknown level and was much happier.
[ATTACH=CONFIG]11558[/ATTACH]
April 18, 2016 at 7:43 pm #1051000DrVoidberg
I know some continental tires have small holes that serve as wear indicators. Looks like that could be the case here?
