What type of repairs do you typically consider DIY and what do you get a pro to fix?
Our Community › Forums › Bikes & Equipment › What type of repairs do you typically consider DIY and what do you get a pro to fix?
- This topic has 29 replies, 10 voices, and was last updated 13 years, 10 months ago by
SteveTheTech.
May 28, 2011 at 12:31 am #926254
ronwalf
Half the fun for me is doing my own work. I research the repair online (Sheldon, usually), buy the parts, and either fix it at home if I have the parts or at one of the local co-ops. I’ve been burned by this occasionally, but it’s usually only with the cheaper parts.
Do you all clean your chains?
If so how frequently?
Realistic tire life and chain life span?Modern tires might last a couple thousand miles? It depends on the tire, the terrain and you. (also, Sheldon’s answer).
I “clean” my chain by wiping it down well, applying oil, and wiping again whenever it starts squeaking, which after every wet ride. This is essentially chain abuse, so please don’t tell the CPS (chain-protective services). I might get a thousand miles out of it this way.May 28, 2011 at 1:48 am #926259CCrew
ParticipantI do all my own work. I grew up in a family where my father owned a high end machine shop, so the concept of having other people fix things wasn’t in my upbringing.
Tires are dependent on what you buy, but my experience is that they’ll last 2k miles on the minimum.
Chains are based on stretch, but that will be hastened by inadequate maintenance. Chains don’t in reality stretch… they wear on the pins and in the holes the pins ride in causing the chain to elongate. I’m anal about mine – for the most part pulled and cleaned about every two weeks or less. More because I’m OCD about clean, and also because I like a dead silent bike. I put SRAM Powerlinks in my chains, pull them and throw them in a coffee can with mineral spirits to soak, and then wipe, install and relube. I won’t even start the great holy war about what lube to use. That’s like having a coke vs. Pepsi argument. For me it’s Boeshield T-9 but use what you’re happy with.
May 28, 2011 at 11:06 am #926260Dirt
ParticipantI do almost everything myself. I haven’t built any bike frames YET. That will likely happen next year.
Chain wear: Buy yourself a chain wear gauge. It tells you exactly how much life is left in your chain and when you should change it. Park makes a nice one. Many other companies do too. They’re easy to use. If you let your chain go too long the cogs and chainrings will wear in accordance with the stretched chain and then you’ll be forced to replace all three. Change your chain often and you’ll get many more miles out of your cogs and chainrings and save yourself hundreds of dollars.
Buy a bike repair book. Leonard Zinn has two good ones. Go to a book store and start reading and see if it makes sense. Sheldon Brown (may he rest in peace) may be gone, but his web site lives on at http://www.sheldonbrown.com. His web site answers questions you didn’t know exist, as well as a bunch that you probably did.
Lots of things people often overlook: A semi-avid cyclist (someone who rides 3 or more times per week) should change their cable housing AND cables once per year. Having the right housing length is extremely important in getting things to shift correctly. Clean chains help the drivetrain last much longer.
Bike Cleaning: I actually use a bucket of soapy water and Dawn dishwashing soap to clean my drivetrain. Citrus degreaser also helps when they’re really bad. I spray down the bike with a garden hose to knock off the big chunks of dirt. I take a long-handled, soft bristled brush and wash off the bike. I then rinse it with the garden hose. I spray the drivetrain with a bit of degreaser if it is really gunked up. Let it sit a minute or two. I then take a different long-handled brush… one with a little stiffer bristles if possible. and I brush the cogs and chainrings while pedaling backwards. This cleans the chain on both sides as well as the cogs and chainrings. Dip the brush in the soapy water often. After I’m done, I rinse the whole bike from top to bottom and wipe it down with a soft cloth. I wipe down the drivetrain with a shop rag. I take a little household cleaner and spray it on a rag and wipe down the rim surfaces. This cleans off any grease or grit that might have washed onto them while you were cleaning the drivetrain.
I do this every 5-10 rides on my fancy-pants road bikes. Since they only get ridden on Sundays, it isn’t very often. My work-horse bike is an old, fixed-gear bike that gets abused. I lube the chain when it squeaks. I clean it off when it gets disgusting to me or if I have to change the brake pads. That’s it. I ride that bike because it requires very little maintenance.
Things to note about this process:
1) Never spray a hard stream of water on any bearings on the frame. That means the hubs, bottom bracket, derailleurs, etc. Use a gentle misting… just enough force to get the soap and standing grunge off the bike.
2) If you have fancy-pants wheels… with rims made from carbon fiber, clean those separately and very gently. Mild soap on a soft rag is best and then water on a soft rag and then dry them. It is easy to get water into carbon rims and hard to get it out. Aluminum rims are generally a little more forgiving plus they are much less expensive.Two more general things to note as you work.
1) Modern bikes like torque wrenches. Most parts on a light weight bike will come with torque specs. They are measured in oz/in or newton/meters. Rarely are they measured in foot/pounds. Ritchey makes a 4mm hex key torque wrench set to 5.5nm (a common setting) for about $20. It is awesome. As you know, torque wrenches can be very expensive and are usually as good as their price. Park makes a nice one for bikes. There’s an Italian company that makes a great one specifically for bikes too.
2) kind of related to 1: Don’t force things. Brute force is rarely required with bikes. You know this already ’cause you’re an auto tech and you can tell the difference between what needs muscle and what does not. This is more aimed at others who will read this thread down the road. The day of fixed BB cups and freewheel removal that requires a lot of muscle are gone from the world of modern bikes. If you’re having to exert a lot of force, you’re doing something wrong.
3) Tools help. A good set of cable housing cutters make a huge difference. That’s the tool that I use the most on a bike that I don’t on a car. Bottom brackets cogs have a few specialized tools, too. That’s mostly it for bike-specific tools.
4) Your brake pads have a wear line. Change them often… before they get to that wear line is good. Stopping is important. Don’t postpone that change.Good luck.
May 28, 2011 at 4:27 pm #926263CCrew
Don’t rule out Craftsmen also. There’s nothing magical in bike mechanics, although the companies like Park do make bike specific tools like cassette removal tools, etc. But if you only intend to use the stuff occasionally the Spin Doctor stuff from Performance can be a viable alternative.
May 28, 2011 at 7:29 pm #926268Mark Blacknell
ParticipantI love reading a thread, starting to compile an answer, and then seeing that Dirt has saved me the trouble.
All I would add is:
1) if you bought your bikes this spring, your chain is fine.
2) In my view, about 95% of imaginable bike maintenance/fixes can be accomplished with a relatively cheap set of tools. At this point, the only reason I need a shop is to chase/face my BB, remove a fork’s crown race, or straighten a hanger. (And I think I’m about to address that last one). I doubt I’ve got more than a couple/few hundred dollars worth of tools. And you can manage about 75% of expected issues with less than $50 worth of tools, I’d bet.May 29, 2011 at 1:07 am #926275SteveTheTech
ParticipantYou all are great, thanks for the input.
Sheldon Browns’ passion and knowledge will carry on more through his website more than it could have via any method. I
would like to leave a small mark on the world with only a fraction of the usefulness of his site.Tools are something I can really get into, although I am fairly lax about using a torque wrench when making minor adjustments I have spent a decade tightening things with hand tools enough to know where 15 in/lbs should be. If I where to install the Ritchey carbon bars then I’d probably buy that tool as it would be useful, but most of the allen keys I come across are 5mm.
(it’s a pretty neat tool though, http://www.greentirebikes.com/tl3303.html). Beam torque wrenches are not worth relying on as the price of those reflects that. (http://www.greentirebikes.com/torque-wrenches.html -just a reference not a recommendation) and even an entry level basic click wrench from Harbor Freight.
(http://www.harborfreight.com/1-4-quarter-inch-drive-click-stop-torque-wrench-2696.html)
This one’s only $20I might get one of each of that one and a 3/8″ for that price, just to have one at home.
ParkTool has some good specialty tools but I would not get into their hand and regular tools as they are pricier than their quality tends to warrant. But as noted the torque requirements are fairly low. I do not have a bike stand but I made one that fits in my vice at work from an old axle. Harbor Freight ftw.
Pete- I enjoyed reading your cleaning regiment I assumed that was how you clean all of your bikes…I looked over and wondered if mine wanted to go outside and meet the garden hose. lol. I’ve got a half a bottle of window tint film solution still mixed up I think I am going to use for this weeks post ride clean. The tint solution I am currently using only Johnsons Baby shampoo and water. I keep a bunch of microfiber towels around for all types of non marking cleaning and that should work. Maybe a little canuba wax will keep some of the gunk from sticking.
I’ve been going through YouTubes vast cycle repair sections. There are many techniques that seem much less complicated when you watch someone do it. Google has provided hours worth of material to research.
The opinions on tires seem to vary and it really seems like wear is the best judge. My biggest fear still remains blowing one as far from the car as possible. Some people use separate wheels indoors but my wheels to bike ratio must remain 1:1…at least only 1 set per year.
May 29, 2011 at 2:58 am #926276CCrew
Just a tip from someone who’s anal about a clean bike. Pledge furniture polish rocks versus car wax.
And beware of Simple Green. Good stuff but it is caustic to aluminum.
-Roger
May 29, 2011 at 6:12 am #926279JimF22003
ParticipantWhen I was in highschool (in the 70’s, ahem) I used to be able to tear my Campagnolo-equipped bike down to the last bearing and put it back together again. Now I’m afraid to touch half the stuff on my bike. I can do cassette changes, chain changes, pedal and saddle swaps, and brake pads, and minor derailleur adjustments. Anything else just gives me the willies
I bought a fancy Parktool torque wrench a couple of weeks ago because I got a new seatpost, and was afraid of over-torquing the seatpost collar. For some reason I was expecting that when the torque wrench hit the limit it would sort of “ratchet” multiple times like a freewheel or something. Instead it just makes a single “click” to tell you it went over the limit. So like a dummy when mine did the “click” I just kept turning. Sort of defeats the purpose
May 30, 2011 at 12:14 am #926281SteveTheTech
-Roger
Now that is priceless info right, there. Kudos to you good sir. I will be trying that.
I did the same thing when I purchased my last click style torque wrench with a wheels’ worth of lug nuts. It took me several tries to be able to feel the click. About a dozen or so uses into it the click was a bit more audible…either that or I just gained a little more experience.
May 31, 2011 at 1:27 pm #926305Dirt
ParticipantSteve: You expressed concern about tires and getting flats way out away from the car. There are definitely things you can do to help with that. Flat tires are probably the repair that needs to be done most often with bicycles. It is important that you have the supplies (tube/patch kit), tools (tire levers… GOOD ONES!) and skills to fix a flat. Have a little duct tape around your pump in case you damage the sidewall on your tire. The duct tape goes on the inside and can help you limp home. A dollar bill folded twice works for that too. I once rode home with a $20 poking out the sidewall of the tire for lack of smaller change.
Tire choice can also help. Light-weight racy tires are great, but they are a bit more fragile and wear faster than bomb-proof touring/commuting tires. I love my Continental 4000s and GP’s, but they are not as durable nor as flat resistant as others. I get between 3000 and 5000 miles out of a set of lightweight ubertires.
For commuting and general errand running I use something much more durable. Continental Gatorskins, Specialized Armadillos (the more expensive of the 2 models) and anything in the Schwalbe Marathon series have worked PERFECTLY for me over the year. I got almost 20,000 miles on my last set of Armadillos with ZERO flats. I took them off not because they looked worn out, but because they got to the age where their rolling resistance was noticeably slowing me down. I ran a set of Schwalbe Marathon Extreme on my cargo bike for over 4000 miles last year… many miles were with the bike fully loaded (and a few with the rider fully loaded) and the tires show no wear at all. I got one flat when I pinch-flatted while hopping up a curb while carrying 200 pounds of mulch. Definitely user error.
The commuting/touring tires definitely do not roll as fast as the racing tires. They sometimes weigh twice as much. That trade-off is definitely something worth considering… especially when you own 1 set of wheels.
May 31, 2011 at 11:43 pm #926322SteveTheTech
ParticipantIt really is a shame this forum doesn’t have a points system. As usual that was an epic post. The dollar bill trick sounds perfect for the type of damage I fear.
I currently have a set of Conti Ultra Race with. They have lost only 1.5 lbs of inflation pressure over the last three months and almost 500 miles and have only a small bit of wear from the heat of my (cheap) trainer. These tires are so much better than their car tires. There are many spots where I should have destroyed them (as a former MTB and bmx rider I tend to try to jump over things, not worrying about breaking a spoke) but I personally think the tires have saved me.
In the future I be going with Gatorskins as replacements. I would sacrifice some rolling resistance for a rayon band and some added weight, I’ll bump the air pressure a few for a longer ride. I do the same thing with vehicle tires. Tires and brakes are two things to never compromise with in any vehicle.
The emphasis on good tire levers sounds like it comes with a really crappy story…I’ve got blue plastic Park Tool ones for both beaded sets of wheels…whether those will work more than once I am not sure…hopefully it will be some time before they get tested.
June 1, 2011 at 1:12 pm #926331Dirt
For most humans, normal tire levers work fine. It is my dumb luck that I find a tire/rim combination that is particularly tight. I put a set of Vittoria touring tires on my fixie wheels (Kind of obscure Eighth Inch Julian rims.) and those suckers were IMPOSSIBLE to get off with normal tire levers. I ended up buying a set of Lyzene aluminum tire levers specifically for those wheels. They were strong enough, but were still not easy to use. The death of that tire/rim combination came on a day where I belatedly found that there was a problem with the rim causing repeated flats. When the tire went flat for the second time that day I was so tired and annoyed that I decided to hammer home with a flat tire. It was only 9 miles home and I’d lost my patience with those tires. The wheels were the ones from my WBUI (Wheels Built Under the Influence) challenge (another long story there) so I didn’t think they’d mind dieing a warrior’s death.
This is me around 6 miles from the house.When I got home, I realized the fridge was empty, so I got back on the bike and rode 3 miles to my favorite restaurant… back tire still flat. So I ended up with about 15 miles for the day on a flat rear tire.
If you’re really bored, you can read the dramatized version on my much-neglected blog: http://ausoe.blogspot.com/2011/03/air-is-for-wimps.html
I guess the lesson from this story is that you don’t actually need good tire levers. You don’t need tire levers at all.
PS: Don’t try this at home if you’ve got a front flat. figuring out the handling is hard enough with the back wheel flopping all over the place. Even I’m not stupid enough to hammer 15 miles home and to dinner with a front flat. I’d definitely have to slow down quite a bit.
June 1, 2011 at 1:31 pm #926333OneEighth
ParticipantThis is where one of two redeeming features of tubulars comes to mind. Unfortunately, we full on into the non-redeeming features for about a day and a half after that…
June 1, 2011 at 2:09 pm #926337Dirt
I’m building a set of carbon tubulars for some fixie centuries this summer. Hopefully I don’t need to take advantage of that feature. On the good side, I found some red, white and blue mud-flap girlie stickers for them. They’re gonna be sexy. (Editor’s note: I’m not gonna say what parts of the sticker are strips and what parts are stripes.)
Back on topic, sort-of: Conti makes Gatorskin tubulars that are FREAKING AWESOME!!!! I’ve got about 1500 creamy, smooth miles on them and they’re still super juicy. I’m one of those weirdos that actually enjoys gluing tubular tires.
June 1, 2011 at 7:15 pm #926352Mark Blacknell
ParticipantWill someone please take the custard font color away from our Most Senior Member?
(And next time I see Dirt rolling for miles on a flat I’m calling Wheel Protective Services on him.)
