What tool do I need (cassette and chainring and chain removal)?
Our Community › Forums › Bikes & Equipment › Maintenance › What tool do I need (cassette and chainring and chain removal)?
- This topic has 40 replies, 15 voices, and was last updated 9 years, 7 months ago by
jrenaut.
November 10, 2015 at 1:22 am #1040869
Participant@Vicegrip 127626 wrote:
I just looked at the images of your cassett and RD without squinting and peeking through fingers over my eyes. 😮 We can tear the drive train down and give it a bath in the heated ultrasonic cleaner while cleansing a couple of bike motors with a beer based solvent flush.
Not getting invited to this party must be the unanticipated downside to keeping my drivetrain sparkling clean.
:rolleyes:
November 10, 2015 at 2:25 am #1040874vvill
:rolleyes:
You can’t use a chain whip on a belt drive sprocket anyway.
November 10, 2015 at 1:57 pm #1040884dkel
There is a belt whip tool that does the same job! (I don’t have one, though.)
November 10, 2015 at 3:01 pm #1040891Vicegrip
Sure you can but only if it likes it.
November 10, 2015 at 3:04 pm #1040892Vicegrip
:rolleyes:
still need to flush the motor with the proper solvents.
November 10, 2015 at 5:25 pm #1040898americancyclo
Participant@Subby 127613 wrote:
I want to remove the cassette … (and evaluate for replacement).
You need to get out of your granny cassette gear more, it’s wearing fast!
November 10, 2015 at 5:51 pm #1040899TwoWheelsDC
Disagree. High levels of wear on the low-end of your cassette indicates that you stick to the Big Ring, which is PRO.
November 10, 2015 at 5:55 pm #1040901americancyclo
That would indicate cross-chaining which is NOPRO.
November 10, 2015 at 6:00 pm #1040902ShawnoftheDread
ParticipantI’m not sure there’s anything pro about that cassette. Greasier than a diner meatloaf.
November 10, 2015 at 6:27 pm #1040903vvill
ParticipantLooking at those pictures, I’m not sure there’s much point cleaning that stuff. I’d probably just get a new chain/cassette/rings and toss the oldies.
Either that, or just keeping riding as is until it starts skipping (or is it doing that already?)
November 10, 2015 at 6:38 pm #1040904dbb
Or as some would say, “You could grow tomatoes on that.”
November 10, 2015 at 7:20 pm #1040907Subby
ParticipantCassette just needs to be cleaned, no? The teeth look like they are in good shape. Chainrings are old.
How do I know if I have an 11 or 10 speed?
November 10, 2015 at 8:27 pm #1040917ShawnoftheDread
Dude, count the sprockets in the back.
November 10, 2015 at 8:32 pm #1040919hozn
Count the number of cogs/sprockets (gears in back).
Don’t try to fix what ain’t broken. E.g. the best way to make your BB start creaking is to take it apart to clean it. Cartridge BBs are effectively unserviceable, as once you pry off those seals they will never be the same.
If your chain skips on the cogs, throw everything into the trash and buy all new. If there isn’t any skipping then just use the edge of a rag between the cogs if you want it to look pretty; this act likely won’t do anything to help it ride better, but it is fun to get dirty in an effort to make things clean.
November 10, 2015 at 8:59 pm #1040924Vicegrip
ParticipantBig cog looks shot in the picture. Cassette and chain, check and unbend the RD hanger*, clean and lube the RD and wheels, Remove the brake pads, remove the brakes and pedals. ultrasonic tank the brakes and pedals if needed, blow them clean and dry with compressed air and re-lube while still hot from the tank. Pull the brake and shift cables, blow the housings out or replace and install new cables. Blow out the brifters and lube if able and needed. Feel the bottom bracket with everything else off and service if needed. Clean up the chain rings. Feel the headset and service as needed. Reassemble everything. Tune up the shifting and set the limits. Adjust the brakes. Easy peasy, two to three hours tops working in happy hobby mode.
*evidence of a couple of good hits on the RD pivot.
