What Frame To Use
Our Community Forums Bikes & Equipment What Frame To Use
  • #919002
    BobCochran
    I’m interested in buying a used frame somewhere, and building a bicycle with it. I want a frame that will let me use wide tires, say perhaps up to 42mm — I really like Compass tires now that I’m using Bon Jon Pass 35mm. Perhaps using 650B wheels?
    I don’t know a darn thing about how to get started. This is the first time for me. I lack bicycle repair experience, and will be learning skills from scratch.
    What is a good used frame to consider which will take up to 42mm tires? Maybe 650B wheels. I would greatly prefer disc brakes. I have no idea what frame size to plump for. My current bike is an early 2016-model Jamis Allegro Elite with a “19” on the frame. I assume that means the seatpost height is 19 inches. I’ve noticed that Velo Orange sells frames in generic sizes such as “XS”, “S”, etc. Perhaps that means I could buy a frame that is “about right” in size and add components such as a stem and saddle to get the fit exactly right? Sizing suggestions appreciated.
    Would it make sense to buy a used frame that has obvious rust on it? That is, could I clean rust off it myself and then bring the frame to a pro for priming and painting?
    Thanks
    Bob
Viewing 15 replies - 16 through 30 (of 37 total)
  • #1064273
    BobCochran
    @vvill 152961 wrote:
    Open U.P. https://opencycle.com/up/ (a review is pending on Bicycle Quarterly, I believe)
    Were you the one who noticed the photo of that bicycle on Jan Heine’s blog and made a comment about it? I think Heine must have leaked it as a teaser.
    #1064282
    nope http://www.instagram.com/p/BPXvBZ7B9zu/
    #1064290
    Harry Meatmotor
    Bob, I may have missed it, but what’s your budget?
    And like a few others have commented, IMHO you’re probably going to get best results picking up a telephone and chatting with V/O and building out a complete bike with Chris’ input.
    #1064293
    BobCochran
    Hi Harry, well the budget is really up for debate in my house at this time.
    I don’t have much experience with different bicycle components. I recently discovered the joy of wide tires. Previously, I thought narrow tires were all I ever needed. Now I want wide ones. Inexperience has bitten me. So I have this urge to try different parts. My Jamis bike is never going to take tires wider than 35mm. Experimenting with drop bars sounds expensive because of the brakes. think I can get a Nitto rack on it, and I want a generator hub. The Jamis seems to suffer from limitations. I’d like to get experience with parts and then go to Chris Bishop with a pretty good idea of what I want…naturally with his input.
    And yes, I do understand custom bicycles cost an arm and a leg. Maybe both arms and legs.
    Being deaf, it is not easy for me to pick up the phone and call around. Luckily, there is email and the Internet.
    Thanks a ton
    Bob
    #1064321
    anomad
    Something else to think about is the tire profile on different rims. A 32c or 35c tire on a wide rim feels and looks a lot bigger than when its mounted on a 19mm road rim. 35c on a wide rim is close to what we ran moutain biking in yesteryear. It makes a luxurious commuting/touring profile.
    If flats are a problem then think about adding 2 ounces of Stan’s to your tubes or even going tubeless. Out west I had a terrible problem with flats on my commuter. I ended up with a 35c tire with puncture belt, a secondary tube protector, and sealant in the tubes! Puncture vine (goatheads or sand burs) being the biggest cullprit. Heavy, but it worked for thousands of miles.
    #1064348
    Harry Meatmotor
    Thanks a ton
    Bob
    I think you could build out a perfect touring bike using mostly V/O components with all the touring trimmings (i.e., racks, fenders, bags, dynamo hub, lights) for just north of $2k. I’d also recommend going tall head tube and riser stem plus drop bars with a good amount of flare. You can pretty easily get your stack and reach on one of the V/O touring bikes to match or be very similar to your current bike.
    #1064352
    The VO Piolet checks all your boxes, I think. Can take huge tires with fenders. Can take 650b wheels (and 700c wheels), even on larger frame sizes. Has disc brakes. Has front and rear rack mounts and a crapload of eyelets for other things. It ain’t cheap, though.
    #1064364
    EasyRider
    Yes, I’d hold out for the latest version of the VO Polyvalent, if you’re a BQ fan. It’s 650b, designed for drop bars, has disc brakes, threaded low-trail fork, 47mm tires with fenders, rackable, etc. Prob same price as their other frames. The Polyvalent is like a classic French randonneur bike with disc brakes.
    #1064371
    I’ll state right now that I’ve never tried it, but I thought that putting Stans into a tube (instead of a tire) isn’t very effective because a tube is more stretchy than a tire, and Stans is too thin/liquidy (compared to something like Slime, which does work fine in a tube), so that the magic fibers in Stans don’t have a chance to settle into/below a stiffer hole of a tire. Hope that makes sense :D
    What size tire and pressures did this work successfully for you? Also, how did you get the Stans into the tube (removable valve tubes or cut/inject/patch)? And more importantly, how did you get the Stans boogers out? :D
    EDIT: I overlooked that you said it was 35c tires. What pressures though?
    The reason I’m asking this is because I have multiple mountain bikes that I can’t run tubeless, and I thought that Stans in a tube was not effective…
    #1064393
    Harry Meatmotor
    If my name was Bob, this is what I’d do.
    #1064395
    Mario20136
    I recently upgraded my 25 year Lotus Supreme Columbus SL/Frame and had it powder coated with Orange. I love the retro color and it sure does attract a lot of attention when commuting. On top of it, I recently replaced my aging Campagnolo Super Record with Dura 7800 Ten Speed drive train to include the shifters, brakes, crank set with bottom bracket, front and rear derailleurs. I also had my rear stays cold forge to accept 130mm rear hubs. It rides and shifts like a dream!
    Overall, it cost me a lot less than purchasing a new bike. However, the current setup is limited to 700x28c tires which are ideal for my daily commute to work.
    Of course, my dream bike is to own one of those “OPEN” complete bicycle. It’s too bad the complete bike is over priced for a whopping $6K plus tax. I can’t justify purchasing this toy especially if my bike is worth more than my car but seriously, it’s really a nice, light, and flexible bike capable of taking 700c and 29” tires. The closest bike that I can think of at this time is a Specialized Diverge or Crux. The specs don’t come close to Open specifications, but IMHO these bikes work as well.
    Happy Riding!
    #1064396
    BobCochran
    Ha ha! I will see what I can negotiate. I’m not so much a Bicycle Quarterly fan as I am an grey-haired innocent with little sophistication in bicycle tech. I look at the cyclists around me and realize they all have more experience in the field. So I stumble, bumble, and learn. Like, ha ha, it took me some Googling to figure out the references in this forum to “V/O” or “VO” mean “Velo Orange”. Now I get it.
    I don’t get how a Firefly or Moots product can cost over $8000. I figure that that amount must be 75% profit to the manufacturer. Just like cars prices: inflated because people are willing to pay what is being asked.
    With all that said…I don’t want my bicycle to be an advertisement for Velo Orange, Moots, or other brands. I want it to have a lovely paint job in colors I select and no manufacturer branding.
    #1064398
    EasyRider
    @BobCochran 153219 wrote:
    .I don’t want my bicycle to be an advertisement for Velo Orange, Moots, or other brands. I want it to have a lovely paint job in colors I select and no manufacturer branding.
    Sounds tasteful … and tasteful will cost ya!
    #1064400
    Titanium is really hard to work with in terms of doing welds, etc. correctly. Also, they’re not large companies and they probably don’t get that much in bulk discounts, and nice off-the-shelf bike components are expensive. Probably mostly made in US too, although I’m not sure.
    #1064401
    trailrunner
    I don’t know much about Firefly, but I doubt that Moots has a 75 percent profit margin.
