tubeless valve leaking air
Our Community Forums Bikes & Equipment Maintenance tubeless valve leaking air
  • #919756
    Tania
    I noticed this weekend that the spin-ny twisty top thing on my presta value was sticky – meaning, I had trouble opening it and then closing it once I was done adding some air. Now I can neither open it nor close it and it’s stuck in a half open position and slowly leaking air. At least, I’m fairly sure that the air is coming from the valve.
    Is that fixable (and if so, how?) or should I just use a new valve stem?
Viewing 5 replies - 31 through 35 (of 35 total)
  • #1077693
    @mstone 167570 wrote:
    I wonder what the average number of installed spokes is before someone throws the whole thing out a window.
    This is exactly why I’ve never even considered building one of these :) I think for me it would be 1, maybe 2.
    (Tape is so easy to install and adds negligible weight, so I’ll always choose that option rather than a wheel that is a pain to build or, heaven forbid, repair.)
    #1077695
    I wonder if you could do the same thing as in this video (at 2:46):
    [video=youtube_share;rAw7ihWIgAk]https://youtu.be/rAw7ihWIgAk?t=2m46s[/video]
    #1077698
    I think you can, yeah. That video does make it look easy. Probably the second time I accidentally lost the nipple in there after removing the magnet I’d be kicking myself, though.
    #1078001
    Raymo853
    @hozn 166259 wrote:
    Otherwise forget using a thread-on Lezyne pump head.
    (Honestly, I have never understood why people go through the hassle of putting in sealant through the valve stem.)
    Lezyne has a new design hose that no longer backs out valves. It is compatability with all the older pumps.
    I put sealant through valve stems every month in every tire. Why? Some tires are so hard to seat and sealant dries up in a few weeks.
    #1078003
    On their portable/hand pumps? I’ve tried a few Lezyne heads on floor pumps; the more traditional double-barelled head actually works well, but their other push on or “half-twist” heads worked terribly for me.
    I use the Silca push-on head on my Lezyne dirt drive now.
    For me sealant lasts closer to a few months, though it probably depends on a number of factors (?)
