tubeless valve leaking air
Our Community › Forums › Bikes & Equipment › Maintenance › tubeless valve leaking air
- This topic has 35 replies, 9 voices, and was last updated 7 years, 9 months ago by
hozn.
October 4, 2017 at 2:42 pm #919756
Tania
ParticipantI noticed this weekend that the spin-ny twisty top thing on my presta value was sticky – meaning, I had trouble opening it and then closing it once I was done adding some air. Now I can neither open it nor close it and it’s stuck in a half open position and slowly leaking air. At least, I’m fairly sure that the air is coming from the valve.
Is that fixable (and if so, how?) or should I just use a new valve stem?
October 4, 2017 at 2:46 pm #1076475
ParticipantDo your valves have removable cores? Replacing the core would at least be easier than having to remove the tire and replace the stem.
October 4, 2017 at 2:58 pm #1076479anomad
ParticipantMight try using a pair of pliers to close it. Don’t get carried away applying a ton of force. But you might be able to open and close it a few times and remove the gunk. Sometimes I use a rag or gloves (or pliers) to get a better grip on those little bastards when they get gummed up with Stans. Taking the whole thing apart and cleaning it later will probably take care of it for good.
October 4, 2017 at 3:18 pm #1076482drevil
+1. After wrasslin’ with gunked up cores and trying to clean ’em with little success, I discovered that replaceable cores are cheap and a huge time saver. Buy a bag of 10 Kenda cores for a little more than a buck a pop/each:
https://www.amazon.com/Kenda-Presta-Valve-Cores-Bag/dp/B0028N8DGUOctober 4, 2017 at 9:32 pm #1076539Harry Meatmotor
https://www.amazon.com/Kenda-Presta-Valve-Cores-Bag/dp/B0028N8DGUbikeshop trick: customer has flat tire –> after replacing tube, ask customer if they want the old tube –> if no, pull the valve core (if removable) and stash in workbench drawer.
non-bikeshop trick: call bike shop –> ask if they have a stash of used presta valve cores –> profit.
other bike shop trick: no tubeless valve stem? cut up old innertube, leaving 1 cm of butyl around valve stem. Viola! tubeless!
October 4, 2017 at 9:59 pm #1076543hozn
ParticipantMy solution to removable cores is to put red loctite on them
. Otherwise forget using a thread-on Lezyne pump head.
(Honestly, I have never understood why people go through the hassle of putting in sealant through the valve stem.)
But in this case, certainly having a removable core might save a little bit of money. (But at $4 for a stem — or maybe less for a tube that you cut the stem out of, this isn’t a big ticket item.)
October 5, 2017 at 12:55 pm #1076560drevil
Nice! I’ve had little success removing the cores of my old tubes, most of which are Kenda or Specialized. I have a huge stack of them that I’ve been meaning to patch, but at this point (a few years?), I’ll just try to remove the cores and recycle them.
There was one time I was going to use a stem cut out of a tube, but the rubber base was nowhere near as thick or sturdy as a tubeless stem like the Stans, so I abandoned the idea and ponied up for a real one. I assume you’ve never had issues doing this though?
The pumps I carry on my mountain bikes are thread-on Lezyne or Specialized, but it’s rare for the valve to get unthreaded on removal. If they do, I just screw it back in. I like the ability to be able to take them off out in the field for when I’m out in the woods. On longer rides or bikepacking trips, I’ll bring at least one 2oz bottle of Stans just in case of emergency.
I have a few wheel/tire combos that work fine tubeless, but they’re relatively difficult to initially seat because they’re so loose when first mounted. Sometimes I might have to use a tube initially or use both hands to pull the tire taut while using my foot on the compressor valve. (Note, this scenario is usually with 4″ or wider tires on 65mm rims or 3″ tires on 40mm rims
). Basically, it’d be very messy if I put sealant in initially.
October 5, 2017 at 1:27 pm #1076562TwoWheelsDC
While I haven’t tried it the “Hans Way”, I think it would be very messy for me too. I’ve found that adding sealant through the valve stem is pretty clean and easy. But different strokes and all that…
October 5, 2017 at 2:04 pm #1076570Harry Meatmotor
It’s more of a fix in a pinch, and I usually run three layers of tubeless tape, with overlap at the valve hole, so the cut up valve fits pretty snug through the hole poked in the tape.
I’ll add to this discussion, too, that I tend to look at tubeless valves/valve cores as kinda dispensable – if they give me any grief due to gunky valve cores or bad seals at the base I just toss them out.
October 5, 2017 at 2:31 pm #1076573Tania
ParticipantI don’t have a spot at my place to even deal with sealant etc so I usually let the shop handle all things tubeless-related. However, I’ve been thinking about getting the SO a small compressor for his garage as an xmas present. So that then I can use it.
October 5, 2017 at 2:39 pm #1076574drevil
Participant@Tania 166294 wrote:
…as an xmas present. So that then I can use it.
LOL, you’re not the first to do this
October 5, 2017 at 2:46 pm #1076575hozn
I’ve been saying recently that I see no point in paying a premium for tubeless valve stems, but I just learned the other day that there is a meaningful difference in construction. I cut the rubber pretty close to the stem from an old tube and then continued to tighten the stem nut until eventually I pulled it through the rim bed … That was annoying to get out! But in general, if you don’t cut it too close and you don’t go crazy trying to over-tighten it, using stems from inner tubes works great. The downside is that if you leave enough tube around the stem to ensure you don’t pull through, it can be tricky to seat tires on narrower rims. E.g. my 18mm-internal-width rims would prefer less interference around the bead shelf, so I bought pack of 32mm valve stems to use on those rims.
I had a hard time getting cores not to unscrew and so eventually just read the internet where people said to use Loctite. Maybe I just wasn’t tightening them enough? Anyway, this method works fine for me, but I can appreciate that it is probably messier than if you’re able to get the tires fully seated without sealant in them initially.
Yeah, I’ve only done the valve core method a couple of times, but the valve got gummed up and it didn’t seem to make anything easier so I stopped. But it might have been cleaner to do it that way. Certainly seating tubeless tires is a messy operation with various soaps or waxes in addition to the sealant; I do it outside. I’ve gotten better about not spilling sealant (that stuff’s expensive!), but on hard-to-seat tires, I definitely lose some to the process.
October 5, 2017 at 2:49 pm #1076576hozn
Honestly, I have a Specialized Air Tool Blast (https://www.specialized.com/us/en/accessories/17pumpfloorair-tool-blast-117288/117288) but my Lezyne Dirt Drive pump can seat pretty much anything that the Blast can.
October 5, 2017 at 4:09 pm #1076579bentbike33
Participant@Harry Meatmotor 166291 wrote:
I usually run three layers of tubeless tape…
Is three layers enough rim tape to keep the air pressure from stretching the tape into little divots over the spoke holes? In my limited experience (with narrow-ish road tubeless rims), I can only get a tubeless tire to seat with fresh rim tape.
October 5, 2017 at 4:30 pm #1076581hozn
2 layers of stans yellow tape (or similar blue tape like that used by Velocity) is enough for road pressures. 1 layer is enough for MTB/Cross.
Some people “build up” the center channel on non-tubeless rims to help with seating. I’ve never had to do that, but maybe I’ve been lucky. (I don’t use any rim strip in addition to the yellow tape.)
October 5, 2017 at 4:40 pm #1076582Harry Meatmotor
for most of the rims I’ve dealt with at the shop, 2 wraps is good enough using stan’s tape. At home, however, I used 3M blue packing tape you can get on amazon and according to the innernets, it’s a teeny-tiny bit thinner than stan’s. So at home I wrap 3 wraps. Haven’t had any major issues yet between the two bikes in the house running tubeless, aside from burping in races and getting a bunch of crap in the bead because my GF corners at ludicrous speed.
