Takoma to Metro Center
Our Community Forums Commuters Takoma to Metro Center
  • #942473
    jopamora
    This is mostly the reverse route I take when going to the Takoma Park Library. I usually take 11th instead of 13th to avoid the hill and because 11th has a bike lane after Spring.
    http://maps.google.com/maps?saddr=5th+St+NW&daddr=Metro+Center,+13th+Street+Northwest,+Washington,+DC&hl=en&ll=38.91027,-77.019653&spn=0.034262,0.084543&sll=38.929703,-77.031713&sspn=0.017126,0.042272&geocode=FTy0UgIdBMVo-w%3BFZuIUQIdFKBo-yGo-nRsYPPVIA&t=h&dirflg=b&mra=prv&z=14&lci=bike
    Good luck, have fun, and ride safe.
    #942476
    SilverSpring
    KLD,
    You might also consider cutting over on Piney Branch to 14th (which has a bike lane most of the way) down to F (G?) and then cut over a couple of blocks. Or, you could take 5th/6th down to G (F?) at the Verizon Center and cut over (that’s also got some bike lane and is the least trafficky of the routes).
    #942479
    eminva
    I used to do a similar commute (Takoma DC to Farragut North) and took the first route SilverSpring suggests (Piney Branch to 13th to Colorado to 14th). The only downside is that the bus routes go down 14th so you are always interacting with buses and you specified that you were looking for something a little quieter.
    Instead of a quieter route, I would suggest looking at the WABA website and taking a Confident City Cycling course. This would give you more practice on your road bike and also give you tips for riding on the busier city streets. That way you can take the easiest and most direct route. It is not hard to get used to with a little practice.
    Good luck!
