Taking a bike on metro bus
Our Community › Forums › General Discussion › Taking a bike on metro bus
- This topic has 9 replies, 7 voices, and was last updated 13 years, 2 months ago by
KLizotte.
April 6, 2012 at 3:07 pm #938845
ParticipantI’ve used Metro buses to get home when I’ve had a mechanical issue with my bike and it is unridable. Once I figured out how the bike rack worked, I’ve had no problems. The first time the driver was helpful in showing me what to do. When I get off the bus I always use the front door of the bus so I can tell the driver I am taking my bike off the rack. All but one of the times I’ve used the bus this way it was during the evening rush hour and I’ve never had a problem (knock wood). That said, I’ve never been on a crowded bus with my bike.
April 6, 2012 at 3:37 pm #938846Mikey
ParticipantI take the bus with my bike from FFX to the Pentaon 8-10 times a week. The Bike rack on the front is fairly simple to use. Just ensure that you wait for the bus to come to a complete stop before walking out in front of it. There are two rack positions; I originally started using the one closest to the bus because that would allow another bike easier access to the other rack, but 2 or 3 bus drivers told me to swap it to the other one (most forward rack). Each driver told me the reason is that if you use the one closer to the bus the seat and rear wheel block some of the driver’s visibility (don’t know how much this is true), but if you use the forward most rack the handlebars and front wheel are infront of the driver and not as much of a visual blockage (?). It does make for a rather awkward dance with my bike after pulling down rack because I pull down the rack with my left hand while I am holding on to my bike with the right. Since my bike is facing the street (aligned how it will go into the rack I have to walk around the bike to put it onto the rack, no big deal but took a little getting used to).
I always get off the bus through the front door and tell the driver that I’m taking off the bike. I ensure that my bike and I are safely on the sidewalk and the rack is back up before I give the driver a thumbs up.
There are two locking arm styles (spring loaded arms that fit over the front wheel to hold the bike in place). The older style is an iverted J with black a foam rubber coating over the hook part; the newer style has a yellow “basket” like top. Both fit on the bike similarly, the older style tends to rub against my front brake assembly a little and is harder to extend. Once the older style J was looped around the bus’ windshield wiper, so it was difficult to pull down the rack. Newer racks tend to be on newer busses.
Hope this helps, I’d be glad to answer any other questions you have.
April 6, 2012 at 4:04 pm #938850dasgeh
ParticipantI’ve done it on plenty of crowded buses. I just stay near the front for the whole ride (I rarely get a seat). I’ve gotten plenty of looks from people when I squeeze to the side to allow others to go further back, but the drivers have always gotten it. Then I exit through the front door and remind the driver that I’ll be getting the bike. Never had a problem.
April 6, 2012 at 4:27 pm #938852CCrew
Exactly what I do. Never had an issue. If my bike is the only bike on the rack I also always make sure to fold it back up when I take the bike off.
April 6, 2012 at 5:20 pm #938857KLizotte
ParticipantThanks for all of the advice. I wasn’t aware that there is more than one rack style out there (only one style is shown on WMATA’s website the last time I looked).
It seems to me that it would be ideal if there were “bike buttons” inside the bus so you could signal that a bike was coming off at the next stop. That way, cyclists could exit at the back of the bus like they are supposed to and sit/stand wherever necessary.
I think for my first trip I’ll try a Sunday morning when ridership is low. Whooohoooo! Field trip
April 6, 2012 at 6:27 pm #938864Riley Casey
ParticipantOperative term. Nothing like trying to get it sorted out in front of a standing room only rush hour busload of impatient, tired commuters. Gee it looked so simple from afar. DooHH:p
April 6, 2012 at 6:40 pm #938866CCrew
Actually there’s three styles now. I know a bunch of FFX Connector busses are sporting fancy three bike racks
April 6, 2012 at 8:01 pm #938868dbb
ParticipantThere was some discussion at the Arlington Bike Advisory Committee this week about parking a bus at one of the Arlington Pitstops for BTWD so cyclists could have a no-stress exposure to the bike racks. Stay tuned.
April 6, 2012 at 8:14 pm #938869KLizotte
Would be a very good idea at the Rosslyn station because of the big climb up Wilson which discourages a lot of would be commuters, esp in summer time.
