Spoke tension
Our Community › Forums › Bikes & Equipment › Spoke tension
- This topic has 16 replies, 10 voices, and was last updated 12 years, 2 months ago by
ShawnoftheDread.
April 10, 2013 at 1:21 pm #967040
brendan
ParticipantOuchie.
April 10, 2013 at 1:30 pm #967042Dickie
ParticipantThis happened on my Neuvation wheels last year, almost all the eyelets cracked at the same time. I could hear them creaking like an old wooden bed in a brothel when I was riding. Granted they were old and had a ton of miles on them. Luckily Neuvation wheels are cheap (for a reason), and they offer a re-build policy. I sent in both hubs and spokes and they re-laced both wheels with new rims for around $120.00… not too bad. If you want some cheaper training wheels, their deals are not too shabby. Their customer support is awesome. I had a few email exchanges with John Nugent (the owner) himself…. very knowledgable.
April 10, 2013 at 1:48 pm #967049Dirt
ParticipantBicycle wheels are amazingly strong, but they do eventually wear out. You did a great thing in posting this…. Teaches us all that we need to do pre-ride inspections regularly.
Great post! Thank you.
April 10, 2013 at 3:24 pm #967078americancyclo
Participant@ShawnoftheDread 48833 wrote:
Time for new wheels, I suppose.
Dude, you get no love from your wheels! All the broken spokes during ‘saddles’ and now this. ugh!
April 10, 2013 at 3:28 pm #967080vvill
Curious to know – which Neuvation wheels are they? I have over 4000mi on my R28Ls and I’m wondering how long I should expect them to last.
April 10, 2013 at 3:32 pm #967081Dickie
R28 Aero 4 wheels (campy hub), probably had about 12,000 miles on them.
April 10, 2013 at 3:38 pm #967087DismalScientist
What? They are only 20 years old. They’re just getting broken in.:rolleyes:
April 10, 2013 at 3:38 pm #967088TwoWheelsDC
All that torque from his massive quads…it’s a blessing and a curse.
April 10, 2013 at 3:57 pm #967094ShawnoftheDread
ParticipantThese are old wheels: 105 hubs with Wolber rims, 126 mm spacing, and 7-speed cassette. Better to replace or rebuild as far as best value and ease go?
April 10, 2013 at 4:48 pm #967103Bilsko
ParticipantIf you are looking for new wheels on the cheap, I bought my set of FG wheels from these guys
The sketchy website name notwithstanding, I’ve had zero problems with the set in the 6 or 7 years that I’ve had them.April 10, 2013 at 4:50 pm #967104krazygl00
Pre-ride inspection in the road bike this morning revealed this:
[ATTACH]2677[/ATTACH]Time for new wheels, I suppose.
Ouch. Did you recently get them trued?
Sometimes when a wheel gets old and the rim is truly bent and it is getting more and more difficult to true, an inexperienced mechanic can make the mistake of overtensioning spokes to force it into true. I’ve had this happen to me before I learned to do my own wheels, and the result for me was a rip like yours. It is better in cases like this to leave the wheel slightly out of true but within proper tension. At least then the owner can have a little advance notice that they will soon need new wheels or rims.
April 10, 2013 at 4:57 pm #967106DismalScientist
If it will be replace, you might as well go with 130 mm spacing with 8-10 speed cassette (not the 7 speed freewheel) since this is a steel framed bike. You can still use the down-tube shifters, but in friction mode until upgrading to the correct indexing (downtube, barend or even brifters).
April 10, 2013 at 5:13 pm #967110krazygl00
Of course, replacement is the easiest; just lay down cash and boom, new wheels. You can get low- to mid-range wheels (105/Ultegra mix) for not too much money and just be done with it in a jiffy.
As far as value, hand-built wheels can be better, but it depends on what you want out of them. Do you tend to abuse your wheels? Are you looking for a wheelset that will just get you rolling quickly or do you want something that will last you longer? Handbuilts that are maintained can last a looong time and roll smooth and true for years. What shape are the hubs in? If they can be re-used it cuts down on the cost (although some builders won’t re-use hubs).
One low-budget (and time-saving) thing I’ve done in the past when I just wanted to get rolling again was to get a wheel from Performance, (Ultegra hub with Mavic Open Pro rims and wheelsmith spokes) for like $150. I then de-tensioned all of the spokes and spent a good couple of hours re-doing the wheel the way I like, gradually tensioning, truing, tensioning, truing, stress-relieving the spokes, etc. I considered it $150 spent on parts and the labor of spoke lacing.
April 10, 2013 at 5:22 pm #967112DismalScientist
The sketchy website name notwithstanding, I’ve had zero problems with the set in the 6 or 7 years that I’ve had them.Only one of the wheels they offer has a 5-7 speed hub with old-style freewheel threading… and that comes with 27″ rims.
Also try http://www.niagaracycle.com for a cheaper, similar spec wheel but overall a lesser selection.April 10, 2013 at 7:02 pm #967116ShawnoftheDread
Also try http://www.niagaracycle.com for a cheaper, similar spec wheel but overall a lesser selection.The current wheel actually has a 7-speed cassette with a lock ring, not a freewheel.
