Some basic tips for BTWD — feel free to pile on more thoughts or argue with these!
Our Community › Forums › Bike to Work Day Archives › Bike to Work Day 2013 › Some basic tips for BTWD — feel free to pile on more thoughts or argue with these!
- This topic has 16 replies, 10 voices, and was last updated 12 years, 1 month ago by
Mikey.
May 16, 2013 at 4:41 pm #970309
ParticipantGreat list, though I worry it makes riding sound more complicated then it is. I would edit to say:
Seats:
For rides under 3 miles (or so), any seat is ok. Once you’re on the bike longer, you’re going to want a more comfortable seat (also called a saddle). It may be counterintuitive, but a more comfortable saddle is actually harder, and is fitted to your bum. Note, just because you have a big rear on the outside doesn’t necessarily mean you have wide “sit” bones and need a wide saddle. Also, try not to “sit” on your saddle when riding, but rather use it as a “perch” more than a resting place.On these harder saddles, you’ll want to wear padded shorts or underwear. You can wear gym shorts, cute skirts or similar over padded shorts or underwear if you want a different look. You don’t wear normal panties/boxers/briefs/tighty whities under padded shorts or underwear. If you’re prone to chafing (this is especially an issue if you ride in heavy rain or when it’s really hot and sweaty out), there’s a product called Chamois Butt’r that works miracles. Apply to potentially affected parts and glob it directly on the chamois too. It feels gooey and fun!
Carrying Stuff
Any bag will work, but you don’t want it to shift around when you’re on the bike. Backpacks are easiest. Messenger bags work too, and good ones have an extra strap to keep them from moving around. Whatever you plan to use, ride around for a minute with it on the bike to make sure it doesn’t get in your way.
Many commuters use “panniers,” which are essentially saddlebags, although you don’t mount them on the saddle, of course, but on a “rack” either behind your seat above the rear tire (best) or in front of your bike above the front tire (careful — it can be a little wobbly with lots of weight in the front). There are also basic baskets and crates that can be mounted pretty easily, especially if you have a rack. Be careful they don’t interfere with your pedal stroke or bike handling.
Bike “jerseys” (shirts with pockets in the back) and handlebar bags are really handy for carrying small stuff: wallet, keys, phone, snacks, sunscreen.
Flat Repair
Flat tires are a fact of life for urban commuters, especially if you run narrow, higher-pressure tires. Have a plan for if you get a flat. This plan can include knowing where the nearest bus stops are (you can always take a bike on local buses), having a cell phone and a friend who can pick you up, and/or carrying a small kit to repair a flat (tube, patch kit, air).For the tube, most bike tires are marked something like 700×35, which is the diameter and width in millimeters. Some commuter and most mountain bike tires are marked in inches, usually 26″ by 1.5″ or something like that. Sometimes 29″ by something. So jot down your tire size and get a spare tube or two in that size.
For the air, I prefer to carry a portable air pump, which mounts on my bike’s “frame” or can go into a backpack/bag. Some riders use CO2 cartridges to re-inflate after fixing a flat tire, but that can be tricky if you’ve never tried before.
You can put a flat tire repair kit in your backpack/bag, but many people put it in a little bag that fits under the saddle.
On BTWD, it’s almost a sure bet that someone will be around to help you fix a flat if you need it. But if you’re planning to commute every day, it’s a good idea to practice. There are lots of videos on the web that show how.
Water and Food
Do not underestimate the amount of water you’ll need, even on a cool day. Bring at least one water bottle if your commute is more than a couple miles, and two if it’s more than 10. Water bottles fit in “caddies” attached to your bike’s frame, and can also be carried in your back jersey pockets. I dislike processed energy bars, but it’s better to have one handy than to “bonk” (suddenly run out of energy) when cycling. Of course, BTWD pitstops will have fruit, bagels etc.Rain
BTWD goes on rain or shine. If it rains, you’ll get wet. That’s not a problem for you, since you can get a shower or wipe up at work, but it can be bad for your work clothes, work shoes, laptop, if you’re caught in a sudden rainstorm. So put them in plastic grocery bags if there’s a chance of rain and you suspect your backpack or panniers aren’t waterproof.May 16, 2013 at 4:45 pm #970310mstone
Participant@Greenbelt 52356 wrote:
Padded shorts are a must for longer rides.
There are very few commutes of a length that even a relatively uncomfortable saddle “requires” padded shorts. (And with a comfortable saddle like a well-broken-in brooks, even a truly long ride doesn’t “require” an added pad.) What is required is clothing that does not chafe or bind (watch for seams!) and, ideally, handles moisture well. (Wicking it away rather than turning into an uncomfortable clingy mess.) Bike-specific padded shorts happen to provide those features, but I think it’s a mistake to suggest that people have to buy them in order to ride a bike.
Note that even with padded shorts, riding a bike will hurt your bottom if you’re not used to it. The only solution is to ramp up slowly and just keep at it.
May 16, 2013 at 4:56 pm #970319DismalScientist
ParticipantWhile I don’t necessary disagree with any of the suggestions, I wouldn’t take any of them too seriously if I were a newcomer to BTWD.
I am an experienced commuter with a 7 mile trip each way. I wear regular work clothes and not bike shorts. I generally don’t carry anything, but if I did, I would throw on a backpack. I don’t carry anything to repair flats, although I know how to change one. I don’t carry any food or water.Most commutes are in an urban area and buses are nearby. If I were to need water or food, I would simply stop at a store and get some. (Of course, I wouldn’t hesitate to carry water if I thought I needed it, but my commute only takes 30 minutes.) If I get a flat, I just put my bike on a bus and fix it at home. If it rains and I want to limit how wet I get, I’ll just put the bike on the bus. (Remember to check the radar before leaving work–you can try to time your commute to avoid the rain.)
It may be good to do a few trial runs where you are not under time pressure to determine the best route and what equipment, if any, to carry. Over time, you will learn what works for you. I think it is best not to worry too much before starting to commute by bike. After all, one advantage of commuting by bike is the lack of stress that your commute causes.
May 16, 2013 at 4:58 pm #970321baiskeli
Well, you are an economist.
May 16, 2013 at 5:01 pm #970323dasgeh
Great point. I would change the intro to something like “Tips for regular bike commuting” — you don’t need to follow these for one-off BTWD, but as you discover you love it and want to make it a regular thing, these are some good ideas.
May 16, 2013 at 5:07 pm #970328scott930
The only solution is to get out of that saddle, and ATTACK! between stoplights for the entire commute.
May 16, 2013 at 5:14 pm #970332baiskeli
Why stop at stoplights?
May 16, 2013 at 5:20 pm #970334DismalScientist
ParticipantMay 16, 2013 at 5:56 pm #970345TwoWheelsDC
ParticipantIf you’re going to change at work, don’t forget underwear. Every other consideration is secondary.
May 16, 2013 at 6:52 pm #970362baiskeli
Participant@DismalScientist 52387 wrote:
You forgot you sarcasm smiley.:rolleyes:
Oh, yeah, sarcasm. Yeah, right. If you say so.
May 16, 2013 at 7:18 pm #970373dasgeh
You’re not a true bike commuter til you’ve gone commando at work.
May 16, 2013 at 7:39 pm #970380vvill
ParticipantI had one of those mornings today. Running late. Halfway to the trail I realized I forgot my wallet/keys/ID/etc, luckily my wife hadn’t left for pre-school yet. Arrived at work and realized I had no underwear to change into. Etc.
May 16, 2013 at 7:46 pm #970382Terpfan
ParticipantI would add, if you’re not sure about something and on these forums, then just ask your question. People are great here about providing earnest advice and opinions. Similarly, on the trails, if something goes wrong during commuting (unlikely on just one trip, but hey, if you’re biking to work once, why stop?) then more often than not a fellow cyclist will saying something like “are you alright” often shortened to “alright?” If you’re not, just say so. People will stop and help you if they can or point you in the right direction. And enjoy it all–you will likely pace auto traffic, have amazing views, and appreciate everything around you a little more.
May 16, 2013 at 8:17 pm #970395Greenbelt
ParticipantMay 17, 2013 at 12:22 am #970420vvill
ParticipantHeh, no, but my 4 year old just isn’t very steady behind the wheel yet.
