Route Advice – DC to Georgetown Branch Trail
Our Community › Forums › Where to ride? › Route Advice – DC to Georgetown Branch Trail
- This topic has 8 replies, 5 voices, and was last updated 11 years, 7 months ago by
Steve.
September 30, 2013 at 2:14 pm #982432
jopamora
ParticipantYall could ride 15th St to Park to Beach to the GBT.
September 30, 2013 at 2:19 pm #982434eminva
ParticipantSeptember 30, 2013 at 2:21 pm #982435Steve
Participant@eminva 65395 wrote:
Don’t forget: Dirt and WABA think you’re essential! You could take a ride with them.
Oh I know it! And considering this one as well. The only problem is we have to come in to sign our notice in the morning, and so I figure I’ll start riding after that (around 7-
, and so by 1 my legs might be a little tired.
September 30, 2013 at 3:33 pm #982452consularrider
ParticipantNo advice, but it looks like I have to work even if ya’ll get furloughed (why me again? :confused:).
September 30, 2013 at 5:35 pm #982472Kolohe
ParticipantAnother option, (particularly if you’re already east at Anacostia) is MBT to Silver Spring http://goo.gl/maps/8dJ9B (or this, which I have also done http://goo.gl/maps/9avna)
The other day, I did a route that went up 15/14th to Columbia Heights, then a turn on Spring Street to Kansas Avenue – then Kansas all the way to the DC border. (Though the way I went after that was probably the worst way possible through Takoma park)
September 30, 2013 at 5:42 pm #982473Steve
Thanks a lot. Quick question, is the MBT hard to follow between the path and on-street sections going back and forth? I’ve never actually rode on it, and would like to, I just want to make sure I don’t get lost on the ride (again, just due to my buddy’s time constraint). Again thanks for the great suggestions.
September 30, 2013 at 6:19 pm #982479Kolohe
Participant(tldr: The signage is a bit better than it used to be, and now I’ve done it enough so I know the way, but the first few times I did get turned around. If you have some sort of map with you, either with a phone thingey or old fashioned paper, I don’t think one has to worry about getting too lost for too long)
With all the construction on First St NE, it’s better imo to be on the east side of Union station when hitting the southern MBT trail head. Going up 2nd street is inuitive, then turn left on M, go under the bridge, and the ramp to the trail is then immediately on the left (across from the Metro entrance)
The trail goes up as a MUP to Franklin St where it ends and you turn right onto 8th (I just had to look up the Franklin street name, so I think it doesn’t really matter to remember that detail, the signage for 8th street is visible and this intersection has always been well labelled)
The construction where 8th street meets Monroe and Michigan (and Catholic University) is finally coming to a point where the trail in more apparent (and actually exists now) Go directly across Monroe from 8th (no traffic light there, but there is a cross walk – there’s also a light one block down in either direction) when you cross the street there’s a brand new path that curves around the new apt/commerical complex between the building and the metro station & tracks. The path continues under Michigan to the Catholic University entrance of the Brookland metro stop (watch out for throngs of pedestrians, you’re kinda still on the sidewalk here)
The trail then parallels John McCormack Drive parallel to Catholic U. The road curves to the left at the dump where then you climb up to Ft Totten Drive. Ft Totten is narrow with erattic traffic, but you’re only on it for about 4 blocks until intersection with Gallatin St a four way stop where you make the left. (there’s a school on the right back corner of this intersection)
Then you’re looking for 3rd after you cross New Hampshire on Gallatin, make a right on 3rd and follow it all the way to Van Buren. Right on Van Buren, under the tracks, then immediately left on Sandy Spring which curves around to Maple, then a left at Carrol, the first signalled intersection.
There is an MBT directing one left at Carroll now. But that’s the one I missed the other day, so I wound up going all the way up to Philadephia. So I haven’t done the rest up the connection on that side – Carroll to Cedar to Eastern to connect to the trails that parallel the tracks. The other way I have connected to the trails that parallel Takoma Ave is using Piney Branch Road.
There are signs that start to direct you to the Georgetown Branch Trail around Fenton street and Philadelphia Ave, but their placement around Silver Spring itself I find uneven. If one goes all the way up Fenton, one will eventually come across the Green Trail on Wayne Ave, then one can take to 2nd Ave and the nominal start of the (interim) Georgetown Branch Trail. (there’s also shorcuts through some of the other streets before that, but I’m not familiar with those)
The last thing is, the last time I did this trip about a week ago, I didn’t see a sign from 2nd Ave after you cross 16th St that directs you to the left you need to make on either Hanover or Grace Chapel Road to connect to the Talbot bridge and mile 0.0 of the labelled GBT. (I’ve always done this loop in a clockwise direction until last week, so I’ve never looked for the left turn)
October 1, 2013 at 5:31 pm #982591Steve
This is the ride we did and it was awesome! Thanks so much.
Also thanks @Kolohe. We didn’t have time to get lost because the shutdown took a while. I think I’ll be checking out the MBT this week if the shutdown lasts. Thanks again for all the advice.
