ReplacING batteries on blinking lights
Our Community Forums Bikes & Equipment Maintenance ReplacING batteries on blinking lights
  • #918806
    Does anyone do this? It seems wasteful to toss them when the batteries are done, but OTOH I can see people thinking it absurdly cheap to maintain something handed out for free. Depending on the response, I may have a further question.
Viewing 15 replies - 1 through 15 (of 19 total)
  • #1060619
    Yes, it is easy to do.
    #1060623
    Yes, the Arlington blinkies have replaceable button batteries. You just have to pull out the hardware from the rubber covering and take off the black cover. You’ll see the batteries inside. I just replaced mine in fact.
    #1060624
    So here’s my question. I got 3 volt coin shaped duracell batteries to replace the old ones. But the new ones are thinner than the original blinkie batteries, and the replacement does not seem to work. The duracells were the only 3 volt batteries I saw at the drug store. Do I need to go somewhere else to find batteries that match?
    #1060625
    ursus
    Besides for the voltage the 4 digit code must match. The two letters just indicate the brand, e.g. DL=Duracell. CR is a generic designation with C meaning lithium and R meaning round.
    I don’t know which type you use but all of my bike computers have used 2032. 20 means 20 mm diameter, and 32 means 3.2 mm thickness. You must have bought something with a lower last two digits than needed. I suspect that the drug store does carry the correct type.
    #1060626
    Starduster
    The BikeArlington blinkies use the very common (for a button cell battery) 2032 battery. Anything else will not fit. Sounds like you tried a 2016, which is thinner.
    #1060627
    Starduster
    oh, and they must go in with the proper polarity, or you won’t get light. Another reason for proper polarity- the 2032 is a common battery used for the CMOS functions on a computer motherboard. There are warnings about the battery exploding if installed backwards. No, that hasn’t happened to me in my IT career… (Now watch the panic ensue, ;) ) I know, shame on me…
    #1060629
    Yup, that is what happened.
    Any common household uses for the 2016?
    #1060630
    peterw_diy
    Why not experiment, add 1.6mm of aluminum foil?
    #1060631
    Judd
    FastFriendlyGuy replaces blinkie batteries. He buys them in bulk online. You could probably sweet talk him into giving you one.
    #1060635
    komorebi
    I also bought a bunch of batteries in bulk online for this exact purpose. lordofthemark, I’m happy to give you some next time we’re at coffee club together. Just remind me.
    #1060636
    ursus
    IIRC, they are used for some car key fobs.
    #1060640
    Judd
    I’ll have to check my FOB when I get back to Arlington. It’s due for a replacing.
    #1060642
    It is possible to make thinner ones work, although not as reliable. I accidentally got some 2025 (or something like that). I added a layer of folded paper so that they were pushed all the way in, and it worked.
    On line you can get them really cheap. I think I ordered 20 for something like $3.99.
    You can also see what happens if you put 3 of them in. Let me know. I’m curious.
    #1060643
    LeprosyStudyGroup
    Yep if the batteries are too loose and the connection is patchy, I put layers of tape on the inside of the cap until it’s tight. The connections are usually a spring in the center bottom (which can be bent up to increase tension) and a clip along the side of the upper battery that kind of holds them in place. As long as you don’t block either of those connections and the batteries are oriented properly it should work.
    I like layering tape around cylindrical headlight batteries to keep them from rattling around too.
    #1060647
    ian74
    Yeah. This is totally sound advice. What could possibly go wrong? But makes sure you microwave the battery with the foil on top of it to fuse them together to enhance conductivity.
