Recommend: Wall mount repair stand
Our Community › Forums › Bikes & Equipment › Recommend: Wall mount repair stand
- This topic has 11 replies, 5 voices, and was last updated 10 years, 7 months ago by
AFHokie.
November 16, 2014 at 11:34 pm #1014848
ParticipantIf you have the space, don’t use the stand for storage. That’s my only advice.
November 16, 2014 at 11:38 pm #1014849jrenaut
ParticipantHow come?
November 17, 2014 at 12:52 am #1014853Bilsko
ParticipantIts gonna be pretty tough to get out of spending over $100
I have the Top Peak TwoUp in the living room with two bikes haning on it right now. Not enough space to have them mounted properly (horizontally), I have them both hanging vertically with the seat tubes resting on the stand arms. It’s location behind the TV makes it tough to get set up to use as a service stand, and the few times that I have used the stand, its been adequate but not great.
If you want to do your own work, you really would do well to get a stand that will support and secure the bike.
All of that said, if it looks like the type of thing you’d like, I’ll gladly part with mine for $100.
November 17, 2014 at 1:22 am #1014863jrenaut
ParticipantThe ceiling in my basement is very low – not tall enough for two bikes. My plan is two of the $20-30 fold down mounts that are just for storage, and one more expensive version that’s meant for doing work on the bike (something like this).
November 17, 2014 at 2:59 am #1014872ShawnoftheDread
Participant@jrenaut 99758 wrote:
How come?
Only because it becomes an annoyance to rotate bikes around to put the one you need to work on on the rack.
November 17, 2014 at 3:04 am #1014873AFHokie
Could you post a photo of that? I’m having a hard time visualizing how you describe the bikes on the stand in the space you described. I’m using a Topeak Dual Touch 2 stand in a location that’s a little too short to stack the bikes one above the other without some overlap. Wondering if your method would work better.
November 17, 2014 at 3:27 am #1014874jrenaut
That shouldn’t be too big a deal. It’s not that many bikes, and I don’t do that much maintenance. The Bianchi would probably hang out in the work stand because currently most of my recreational riding is the new fixed gear because it’s so sexy I just can’t resist.
November 17, 2014 at 3:57 pm #1014897Bilsko
Looks like this, but now I have the rear wheel off of the Surly:
https://twitter.com/Bilsko/status/361118624800448513
November 17, 2014 at 4:15 pm #1014902americancyclo
For some reason I always thought that pic was over a stairwell landing instead of behind a TV. probably safer that way.
November 17, 2014 at 5:54 pm #1014931Bilsko
Participantnot sure its terribly safe. big tv right in front of the stand would definitely topple over if the stand fell into it.
I used to keep one bike hanging on the banister on our entrance stairs. Haven’t done that in a while though
November 17, 2014 at 9:16 pm #1014963 -
