Recommend tires
Our Community › Forums › Bikes & Equipment › Recommend tires
- This topic has 26 replies, 15 voices, and was last updated 6 years, 7 months ago by
lordofthemark.
October 19, 2018 at 9:36 pm #1090618
Participant“Pretty sure” they need to be replaced, or the tread is actually worn? I’d say replace them when the tread is clearly worn off, before the threads start to show. For the conditions you describe, I’d say Continental Gatorskins would be a good fit. Good flat protection, decent enough ride, pretty long-lasting, and readily available at most shops.
October 19, 2018 at 11:06 pm #1090621dkel
ParticipantRegarding slicks in the wet, Uncle Sheldon explains that channels in bike tire tread are unnecessary because bike tires can’t hydroplane, so the channels don’t do anything for you except give you less rubber in contact with the road. There’s a good article about it on his website .
October 20, 2018 at 4:26 am #1090624Steve O
The way to do this is to wait until the threads start to show and then unride them about 100 miles.
October 20, 2018 at 4:29 am #1090625dkel
If you ride backwards, rubber actually accumulates from the road surface back onto your tires. Right, Steve O?
October 20, 2018 at 4:36 am #1090626Steve O
That’s the harder way. I just remount my tire in the opposite direction from the little pointy arrow.
October 20, 2018 at 4:50 am #1090627ImaCynic
ParticipantWhen mess with a good thing? If Conti served you well, stick with it. My key tire factors for tires are weight, durability, and rolling resistance, and cost. Take a look at their offerings and see what looks best for you
https://www.continental-tires.com/bicycle/tires
Folding tires are usualy lighter than wire beads but cost more. I like Vectran layer for durability, slicks might provide better traction but can have higher rolling resistance. Lastly, bike tires “worness” is not dictated by how many miles or how bald they might be, but by its age as well. A set of tires for daily commute should last about two seasons before needing replacement.
October 20, 2018 at 1:41 pm #1090630Starduster
ParticipantMore thoughts on tires- One direction are the fast road tires with extra protection- the Conti Gatorskins and such. Another direction, if you value durability above all else, would be a touring/commuting tire with flat protection. From Continental, that would be their *Plus* series, and from Schwalbe, any of their Marathon tires. They *will* be heavier, true, but they have the extra puncture-resistant layer under the tread. Ideal if you don’t want to be slowed going to work by having to repair a flat in the field. Most have smooth tread centers, with just enough tread/lugs on the side to be useful on Canal gravel. I have experience with Conti Touring Pluses (since superceded by Conti Contact Plus), then went with the vaunted Schwalbe Marathons. Which I found to be one gear faster with the same effort on the olde Trek.
Highly puncture resistant, but not puncture-proof. Once, I crowed about the Touring Plus’s ability to stand up to everything short of a snapping turtle. Then I met a roofing staple. Humility check.
A sizing note- Continentals tend to run small for their size. Schwalbe Marathons, true to size, but the original Marathon 32-622’s on the Trek are actually a taller profile- they have the rolling diameter of a 35, but still fit my bike with fenders installed.
One more thing to consider- you can get 28’s in these touring/commuting tires from Conti/Schwalbe/Vittoria, but there is a trend toward fatter tires, even amongst the road racing pros. Rivendell, whose business is aimed at touring cyclists, recommend as large a tire as will fit your bike. Lower rolling resistance, cushier ride, extra grip, and you likely won’t encounter an aero penalty unless you’re in time trail mode.
Reflective sidewalls are a *wonderful* visibility advantage at night in urban/suburban traffic. Enough so that the German StVZO road traffic regs will allow them instead of wheel reflectors. Most touring/city tires will have that. Of note, Larry Behery (The Old Bike Shop) runs Schwalbe Kojak slicks on his Cannondale “Lefty”, and those have reflective lettering instead.
October 20, 2018 at 7:44 pm #1090635lordofthemark
ParticipantSome pictures, for reference
The front tire – the Continental City Rider
[ATTACH=CONFIG]18495[/ATTACH]
and yes, its a 28
[ATTACH=CONFIG]18496[/ATTACH]
The state of the tread
[ATTACH=CONFIG]18497[/ATTACH]
[ATTACH=CONFIG]18498[/ATTACH]
October 20, 2018 at 7:53 pm #1090636lordofthemark
ParticipantThe rear tire. a Continental Contact
[ATTACH=CONFIG]18500[/ATTACH]
So wait, a 32-622 is actually a 28? Good news, I did not make so stupid a purchase last time as buying a mismatched tire, and feel less reason to replace this soon. Bad news, I am not good at recognizing the relative widths of two tires in front of me, and I have less of an excuse for riding slowly.
[ATTACH=CONFIG]18501[/ATTACH]More of the rear tire
[ATTACH=CONFIG]18502[/ATTACH]
[ATTACH=CONFIG]18503[/ATTACH]
[ATTACH=CONFIG]18504[/ATTACH]
October 20, 2018 at 8:02 pm #1090637SpaceJockey
ParticipantMust say I’m a big fan of semi-slicks for all situations and environments except for snow….why? The turning habits you develop as a semi-slick rider you can apply on treads, the same cannot be said the other way around.
October 20, 2018 at 8:04 pm #1090638lordofthemark
ParticipantAnd two more of the rear tire[ATTACH=CONFIG]18505[/ATTACH]
October 20, 2018 at 8:08 pm #1090639lordofthemark
Participantone more photo of the rear tire
[ATTACH=CONFIG]18507[/ATTACH]
October 20, 2018 at 10:45 pm #1090641Harry Meatmotor
ParticipantTake front tire, put it on rear.
Take rear tire, keep it as spare. put new Conti City Ride 700×28 on the front and ride.
Both of your current tires look completely safe to ride (judging purely by the photos); the rear is showing a bit more wear than the front, but still has some miles left (likely several hundred miles). You could certainly get away with merely swapping the rear to the front, and the front to the rear, and easily get another couple thousand miles out of that setup.
October 22, 2018 at 2:19 am #1090646dkel
Oddly enough, Sheldon strongly admonishes against this, because the wear patterns on the front and rear are so different. His argument is that the drive wheel on the rear wears a flattened area in the middle of the tread, creating a sort of corner to either side; these corners on the tire cause reduced traction when on a front wheel, because the front tire rolls to the sides in turns, and has less to grip with if there’s a pointy spot in the tread there. I’ve swapped tires rear to front many times and not had any crashes as a result, but I do think the front end squirms a little in the corners after putting a rear tire up front. Of course, all you have to do is ride that way for a while, and the tires become worn in in their new positions on the bike; and you will get more miles out of them that way.
October 22, 2018 at 2:23 am #1090647 -
