Rear rack buying advice
Our Community › Forums › Bikes & Equipment › Rear rack buying advice
- This topic has 15 replies, 10 voices, and was last updated 12 years, 5 months ago by
hozn.
February 26, 2013 at 4:15 am #912918
ParticipantLooking for a rear rack. I have mounting points on the bike. I want something with minimal rattling. I hate rattling. I don’t need to carry an enormous amount of weight – mostly it will be a laptop and clothes and the occasional grocery store run.
The guy at my LBS recommended a brand he said was made by Tubus, but a lower end line? I forget what it was called.
I’ve been told you don’t want a straight triangular shape because it gives the bag nothing to grip at the bottom, and you’re more likely to get your back hitting your wheel. That sounds like bad times.
February 26, 2013 at 5:56 am #963310
ParticipantThere isn’t much to rattle on a rack, unless maybe if you get the kind with a spring; I wouldn’t waste a lot of cycles worrying about that. As to whether a particular rack provides enough support, it will depend on the shape of the rack and the construction of the pannier. A triangular rack will certainly work fine with many panniers with a rigid back, ample anchoring at the top, and a support that engages on the lower end.
At the duty cycle you describe I also wouldn’t worry much about getting a high end rack; you’re not carrying enough weight often enough for it to matter. On a commuter, aluminum may also be better due to corrosion resistance. If you were doing a cross country tour you might want a big steel rack, but that’s not what you described.
February 26, 2013 at 12:43 pm #963313rcannon100
ParticipantI have a Topeak Rack from REI. As Mstone suggested, it is aluminum and does not corrode. As a soft metal, it does wear a bit where the bag rubs against the rack – but not enough to worry.
Topeak fits generic panniers. Topeak also has a proprietary system – a track on the top of the rack – where its trunks slide in an lock in one quick motion. I use panniers for work and equipment like you are talking about. But on the weekend I use a Topeak Trunk that I can just slide on and off – which is nice when you are hoping around to coffee shops or doing other errands.
Be careful of low end. I bought Trans-it panniers from Performance. Now even if I am a 100% commuter, I think the bags wore out way too fast. I have holes in the bottom. People on the forum have Ortlieb, speak highly of them, and say they have lasted forever.
And remember, if you are carrying a laptop – you want something that is going to protect it.
One big thing to think about is how does the bag attach to the rack. My first bags attached with a spring and a hook, which of course would pop off. My Trans-it bags attach with a strap system. They almost never fall off; when they have it has been my fault. I would like a system that its easier not to make a mistake, though. And its a little hard to get on and off. Ortlieb’s system is suppose to be both very easy to use, and very secure. The bag is not flying off the bike.
February 26, 2013 at 12:51 pm #963314jrenaut
ParticipantHaven’t gotten to bags yet. In my experience, bags that need to be waterproof and carry federal government property are not something you go cheap on.
Good to hear, though, that I don’t have to break the bank on the rack in order to get a good one.
February 26, 2013 at 1:24 pm #963315Arlingtonrider
ParticipantOne thing to watch for – check the compatibility of the rack with the panniers you plan to use. Some panniers have a twist or toggle mechanism in the top/middle that helps to lock it onto the rack – in my view, a very nice feature. If the rack has a third brace coming up from the hub end, it may be difficult to place this type of pannier on it, as the brace comes up right where the toggle is.
I have two bikes and two different style racks. I much prefer the rack that is supported by only two braces.
February 26, 2013 at 2:23 pm #963327jrenaut
ParticipantIs it typical that the rack mounts on the skewer? I already have the Burley trailer attachment there, and would prefer the rack not interfere.
February 26, 2013 at 2:34 pm #963333dasgeh
ParticipantWhen you’re ready to buy panniers, The Clymb usually has them. For example, there are some available today https://www.theclymb.com/shared-brand-event/3445/Cycling-Accessories/325080 (full disclosure, signing up with this link will give me a bonus — I’ll owe you a beer).
February 26, 2013 at 2:36 pm #963335mstone
No, that’s a feature generally added for bikes that lack rack eyelets.
February 26, 2013 at 2:44 pm #963338jrenaut
I’m already a Clymb member, and have actually earned two referral bonuses through this forum.
February 26, 2013 at 2:45 pm #963339jrenaut
Ok, cool. It seems the hardest part about this is narrowing my choices from the millions that seem to be good options to anything that stands out for any reason.
February 26, 2013 at 2:59 pm #963341mstone
This is definitely something you can over think. Pick a bag, then make sure it works with the rack. (It almost certainly will unless it has a proprietary mount, in which case get the matching rack.)
February 26, 2013 at 6:18 pm #9633905555624
ParticipantMy rack of choice is the Jandd Expedition Rack. I’ve used some others, but this one is still my favorite. I’ve got 14+ years of service out of the one on my commuter.
February 26, 2013 at 7:04 pm #963393DSalovesh
ParticipantI’ve had a few racks. The one on my bike now is the Topeak “Super Tourist DX with Side Bars”
It has a tubular frame and all the blah blah good stuff – it fits, it works, etcetera and there’s an alternate version for disc brakes too.
The deciding feature – the one that made me replace the last rack that was otherwise identical – is the side bars. With those I can hang my panniers there and still put things on top of the rack, be it a trunk bag or a milk crate or a carefully strapped down pizza and some beer. I do have a Topeak trunk that uses the MTX track (and I’ve had my eye on the folding milk crate with wheels) but it works fine with non-MTX trunks too. It also worked fine with my Novarra commuter panniers and is working… okay with my Jandd really big bags – heel clearance is close with those, but that’s mainly because they’re so big.
Price is about as good as it gets, though I bought mine semi-locally at HTO for a few dollars more than the Amazon listed price.
February 26, 2013 at 7:07 pm #963394Tim Kelley
The folding tote works pretty well. It’s especially useful for taking it inside places–grocery shopping is a snap.
It isn’t particularly durable, so don’t bang it around too much! I busted a handle off, but Topeak was good about getting me a replacement part.
March 2, 2013 at 4:11 am #963755rpiretti
ParticipantHello, just a note I use a VO Constructeur rack and Axiom Lasalle Panniers and very happy with this combo. See my blog here for photos, rack only that is. It’s connected to my fenders…which I would INVEST in as well. You don’t need aluminum ones or anything but helps to have something..
March 7, 2013 at 1:49 pm #963975hozn
ParticipantI have the minimal Tubus Fly rack that is fantastic for carrying panier(s) and adds less than 1lb to the bike. I actually don’t need it, though, as I’ve decided that I hate riding bikes with racks & would rather wear a backpack (or plan my week ahead and skip the backpack too), so I would be open to parting with it and my Ortlieb metro panier bag at steep discount if you still are looking for a rack (and think that the Tubus Fly would be a good fit).
