Rain gear expectations too high?
Our Community Forums Bikes & Equipment Rain gear expectations too high?
  • #915905
    Dickie
    A year ago I decided to finally invest in some quality rain gear. I was tired of arriving at work or home soaked or even worse cold. I couldn’t afford to get gear specific to each season so I opted for hardshell outer layers to wear over my regular riding clothes figuring I could add/remove as needed. I summoned the forum gods for advice and decided on an Endura Flyte jacket and Shower Pass Convertible rain pants. I also purchased some Pearl Izumi WXB waterproof shoe covers. Less than a year in and perhaps 15-20 good tests of the gear I’m sad to say I’m really disappointed. The Flyte started losing it’s repellency after about 5 uses…. pretty poor for an expensive item. After some research I concluded that perhaps by folding the garment up and putting it into my backpack I had weakened the DWR coating. I had also not washed the garment as so many horror stories about incorrect care floated around the web, but it seemed reasonable that by not washing the jacket I was actually hurting it’s water repellency. I washed the jacket per the manufacturers instructions and re-activated the DWR to no avail. This morning I arrived at work soaked. The jacket and pants were not beading up, and were wet on the inside. My base layers were wet as well…… don’t even get me started on my feet. Luckily it was warm so I wasn’t miserable, but this just doesn’t seem right. Am I expecting too much from my gear? Is it too much to ask to ride 20 miles in drizzle/rain and not be soaked when wearing almost new rain specific gear? I specifically didn’t exert myself much this morning to avoid over-heating so I could eliminate that as a factor. Any thoughts? I’m British, this is really pissing me off!
Viewing 15 replies - 31 through 45 (of 46 total)
  • #1010726
    AFHokie
    I have a lot of gear from years of camping and from years in the field while in the military, but I’ve been looking at wet weather/winter clothing and trying to figure out what will work for cycling. The cycling specific jackets I’ve looked at have not impressed me.
    Even in cold weather it’s a given I’ll sweat, so any jacket I’d want must have pit zips for ventilation. Any true waterproof jacket will cause you to sweat with any amount of physical activity. If saturated Gore-Tex will loose the ability to repel water, but based on my experiences I think Gore-Tex is the best option.
    I currently have a Gore-Tex North Face rain jacket that’s worked well while hiking/walking, but it is not long enough to completely cover my back while riding. Additionally, the hood blocks my vision too much and doesn’t fit very well over a bike helmet. I already ordered a Gore helmet cover…curious as to how well that’ll block the rain from running down my head through the vents.
    Let’s also not forget preferably a jacket that’s hi-viz.
    I don’t have much faith in any rain pants. The only truly waterproof pants I’ve ever owned were my ski pants and those are entirely too bulky (and too hot) to wear on a bike. Right now my assumption is to wear thermal tights that will block the wind and hopefully, they’ll have some similarity to wool or neoprene and still keep me warm even when wet. So far what I’ve found online doesn’t leave me hopeful unless I’m willing to spend.
    Based on previous outdoor experiences I want a dedicated winter shoe. I’m looking at Lake Cycling or 45NRTH Wölvhammer but they’re pricey.
    #1010744
    Dickie
    Thanks everyone for the great information. I agree with most everything stated below. When I was commuting only 12 miles each way I was less concerned… a few well placed merino wool garments and I was fine. If the temp dropped below 45º then my winter gear was enough. Now that I’m riding 30-40 miles each day getting really wet is more of a problem. Yesterday I left the house early enough that the wind, rain, and temp was just too much for a 20 mile ride without proper protection. I have given up on my feet and only expect better protection if I buy dedicated shoes for the task. The covers as many have stated work for a short time but eventually leak in all the obvious places…I wear merino wool socks in the rain so at least I am warm when wet.
    The Flyte jacket is wonderful in almost all it’s details (high-vis, great cut, pit zips, protected pockets, etc), I was just surprised how quickly the waterproofing failed. I will take Dirt’s advice and try re-applying Nikwax. As SteveO mentioned, some garments suggest the dryer treatment to re-activate the DWR, however with Endura they suggest against this as the heat could damage the sealed/taped seams. Endura requires that you use a “cool” iron to re-activate the DWR. Shower Pass doesn’t provide much use care. One thing all these water proof garments have in common is the recommended type of detergent you must use, but this also gets confusing. Basically you do not want a detergent that has any softeners, perfumes, or dyes in them as these will clog and damage the breathability and also the repellency of the garment. However, British companies like Endura require you use a non-biological powder for cleaning purposes, but finding an equivalent here in the US is not easy. Basically soap flakes is what they require. Apparently biological detergents (what we use everyday;Tide, etc) have enzymes in them that clean deeply in cooler temps, but these enzymes damage the DWR properties. Non-Biological detergents use no enzymes but require harsher chemicals to clean well at cool temps… so confusing. If you google this stuff prepare to be overwhelmed… and then when you add in cleaning merino… UGHH!
    All in all, perhaps I am expecting too much, and even though I was tootling along I am sure my core heated up over the 20 miles to make me sweat just as much as normal, and thus trapping me in a sauna.
    Cheers
    #1010756
    Rockford10
    @dkel 95420 wrote:
    I just had a surprisingly long talk with Rockford10 about rain gear, and she and I don’t have the same feelings on the topic. It’s apparent to me that everyone’s comfort level and needs are different, so there’s no right or wrong answer, aside from what works or doesn’t work for you. Unfortunately, spending money is usually required before you can figure that out.
    I just don’t melt in the rain and it’s never bothered me that much. I do have some “rain resistant” pieces, but with the length of my commute and the fact that there is a warm shower and dry clothes at the end of the ride, I have no interest in spending real cash on rain gear. I can see myself making one of the Ikea hack ponchos, but would rather buy another wool icebreaker top.
    I note that DKel’s on his second set of rain gear in the past 12 months. REI’s return policy rocks when the pants no longer repel rain.
    #1010757
    Crickey7
    Courtesy of bikesnobnyc: “bicycling in a cleanroom coverall is possible.”
    https://www.youtube.com/watch?v=EMQTY_UwrVg
    #1010779
    True, but they also explain to you that you can’t wash their rain gear in regular detergent, but rather in tech wash of some sort, to which I reply that that information should be on the care label instead of “machine wash, drip dry.” I don’t like taking advantage of the return policy there, either, or they won’t have it anymore, so I’m determined to keep the current rain duds up to spec (somehow).
    #1010791
    Dickie
    Read my convoluted description of cleaning instructions below… you’ll never wash your rain gear again!
    #1010811
    FFX_Hinterlands
    @mstone 95359 wrote:
    For the rain cape advocates, how fast do you go in those? I’d kinda assumed that if you were moving fast they wouldn’t do much (rain would be going in horizontally) so I haven’t tried one.
    The cape is out over your hands and handlebars, so it blocks rain coming from the front and keeps it off of your thighs. So it’s long in the front. I have the Rivendell one and I wear it with an old pair of hiking gaitors or high boots. Works in even the heaviest downpours. A bonus is that it keeps your hands and handlebars dry. The downside is that you need a light that is not mounted on your handlebars (I have one mounted lower on a rando rack).
    #1010897
    Raymo853
    In my experience you can either get wet from the outside or wet from the inside, but you can never stay dry. I’ll wear rain gear when it’s cold enough that the rain is going to pose a health risk, but I still expect to need to change at the end of the trip.
    100% agree. I never expect my skin to be totally dry, even with my super fancy and expensive jacket, full fenders, rain-resistant tights and pants over them, and winter shoes. I always end up damp and needing a shower.
    Your skin is waterproof keeping the rain out of your organs. The main goal of rain/winter clothing, keep you skin healthy and able to keep the rain out.
    #1011172
    ctankcycles
    It’s not cheap, but rain apparel that uses Schoeller fabric is, in my experience, even better than Gore-Tex. I’ve had the Search and State S1-J jacket that uses Schoeller fabric for about a year and it keeps me dry for long periods of time, including a torrential downpour out in Colorado in August. I was hesitant at first since it doesn’t have pit zips but I had heard the breathe-ability is so good that they’re not necessary and I’ve found that to be true. Like I said, it’s not cheap, but it’s very high quality fabric and construction, and made in the NYC garment district so if supporting made in the USA cycling companies is important to you, it’s worth considering. Also, for what it’s worth, the S1-A is a beautiful jersey.
    #1016263
    Dickie
    *Update: Cleaning my rain gear (Endura Flight rain jacket, ShowerPass Convertible pants, P.I. booties) in NikWax tech wash and then using the wash-in to reactivate the DWR has made my gear work amazingly well (thanks Dirt for the tip), in fact I think it actually breathes better as well. Add to that the acquisition of some Sealskinz waterproof gloves and a gifted gore waterproof hat from consularrider and I have never been happier in the rain. Riding 40+ miles in constant rain was actually pleasant. I arrived home completely dry from hands to feet… amazballs!
    #1016499
    Orestes Munn
    I have had good luck with the NikWax 2-stage treatment on sailing foulies, too, even the bottoms of the bottoms, which live for hours between wet decks and cold asses and fail rapidly. However, I couldn’t ride 40 mi in February, wearing a Goretex tutu and a loose Livestrong band, without working up a good shvitz.
    #1016508
    creadinger
    I focus on staying warm, rather than staying dry. Because I know I’ll get wet, whether it’s from rain or sweat.
    Rain repellency is never a bad thing, but waterproof just doesn’t seem to exist in my world.
    #1016509
    Crickey7
    I don’t get how to keep water from getting into footwear from the top down or the bottom up, even if the footwear itself is waterproof? That’s what keeps me from riding when it’s raining and in the 30’s or below. I’ve had some extremely uncomfortable experiences.
    #1016510
    These seem to work very well: http://www.amazon.com/Outdoor-Research-Mens-Verglas-Gaiters/dp/B009Q1BGDE
    I think I bought them because I saw a picture of Dirt using them. I tend to automatically buy anything [that I can afford] that Dirt uses or vouches for :)
    Anyway, they work well, but they do make your lower leg warmer — so sweat may be more of a concern if you’re wearing them over rain paints (presumably you are). And depending on the shoe/boot, water may be coming in from the bottom (cleat) (as you obviously are aware). When I went for a ride on Saturday afternoon in the rain, these gaiters kept water from entering my boots from the top, but after about 45 minutes the front of my socks were still wet from water coming up into the shoes. (I have warmer boots that are fully sealed, but it’s not cold enough for those yet.)
    Anyway, my $0.02. One thing I will say is that I’m unsure how to do the sizing for those gaiters. I just went by pant sizes and got a Large, but I’m at the very limit of having them be tight enough to keep from slipping down above the calf. Perhaps this just means I need bigger calf muscles. If I went by their sizing (based on shoe size) I’d have an XXL which would be way too huge.
    Edit: Also, I agree that the must important thing is just staying warm, not dry.
    #1016512
    Orestes Munn
    I have had fairly good luck with the (nominally) breathable waterproof socks, for keeping my feet dryish while wearing Keens, sailing in cool (not cold!) weather. I have tried the Seal brand and another (forget the name), which has real Gortex and a nice cuff, but no stretch. However, at those temps you really need some insulation and there is even a risk of non-freezing cold injury on long rides, particularly when the feet are wet.
