quick release light mount
Our Community › Forums › Bikes & Equipment › quick release light mount
- This topic has 8 replies, 6 voices, and was last updated 8 years, 5 months ago by
DSalovesh.
November 2, 2016 at 7:40 pm #1059781
Participant@EasyRider 148284 wrote:
With the time change nearly upon us, I just wanted to plug a useful doodad I’ve enjoyed having the past couple of winters — the Problem Solvers quick release light mount.
http://problemsolversbike.com/products/quick_release_nut_light_mount
November 2, 2016 at 7:45 pm #1059782Judd
ParticipantDa it cast any weird wheel shadows? I could picture it creating some sort of strobe effect if the light has a wide enough beam.
November 2, 2016 at 8:41 pm #1059784peterw_diy
ParticipantLooks like it might get beaten up badly at crowded bike racks.
November 2, 2016 at 11:52 pm #1059789EasyRider
ParticipantNo strobe effect. It’s mounted at the hub so you’d have to have the headlight pointed sideways to get that.
I have the wheel on the right hand side of the front wheel and I get full illumination to about 930/10 o’clock on the opposite side.
I’ve had it since 2013 and haven’t snagged it on anything yet. The end of the mount is about 5 inches from the centerline of my bike. The outside edge of my pedal is 8 inches out so it’d get hit first in close quarters. The peg itself is tough and screwed into a QR skewer. The skewer would break if you stepped on it with all you weight but everyday bumps and bangs? Nope. It’s just a chunk of aluminum. If anything, it’s protecting my bike from neighboring ones.
November 3, 2016 at 12:32 am #1059793peterw_diy
Cool!
November 3, 2016 at 2:47 am #1059799KLizotte
ParticipantWhat about providing light high enough for drivers to notice you? Can you post some photos?
November 3, 2016 at 11:26 am #1059801EasyRider
I think so. I use my cygolite’s partial strobe mode when I’m in traffic in the dark. It doesn’t flash full time. It’s steady for two seconds, then rapidly flashes for a second. Hard to miss, even mounted low to the ground.
November 4, 2016 at 4:45 pm #1059948DSalovesh
ParticipantPaul Components makes a couple of other options to look at.
One replaces the top cap of threadless stems and puts the light higher than normal:
https://paulcomp.com/shop/components/stem-cap-light-mount/
The other simply has a hole drilled for an M5 bolt, same as for racks and fenders, which opens up many other mounting locations front and rear.
https://paulcomp.com/shop/components/gino-light-mount/
And, these two products on Amazon are old standbys, and the related product searches show a bunch of other options:
https://www.amazon.com/Topeak-60001001-The-Bar-Extender/dp/B000FIAVN8
https://www.amazon.com/Minoura-Accessory-Handlebar-LW-Clamp-Devices/dp/B0089TA7CA -
