Project Bikes
Our Community › Forums › Bikes & Equipment › Project Bikes
- This topic has 6 replies, 5 voices, and was last updated 14 years, 1 month ago by
dcv.
April 18, 2011 at 5:13 pm #925596
ParticipantCool stuff, Liz.
They’d both be pretty good and bad projects for getting going with mechanics. On the good side, there’s not much you can do to hurt either of these bikes. They’re gonna be pretty forgiving to work on in many ways. On the down-side, you have to have realistic expectations for how they will function once they’re overhauled. The brakes and levers on both bikes, when working PERFECTLY, never generated much stopping power. Just the nature of the beasts with flexy levers and calipers and non-machined rim surfaces.
There are some things that will likely not be easy at all. To service the headset bearings (where the fork goes through the frame) you’re going to have to remove the stem. Due to rust and age, the stem is going to fight you on that. Penetrating oil helps. So does a BFH (Big Flippin’ Hammer). Adjusting saddle height might require similar “persuasion”.
That internally geared hub probably still works nicely. At Apocalypse +1 the world likely be populated by roaches, my first attempt at baking muffins at high altitude over an open fire and millions of fully functional internally-geared hubs.
That said, I think you should go for it. Not sure which one I’d suggest starting with, quite honestly. I was gonna say the one with the internally geared hub would be a good one to start with, but if the cables are missing, there are some weird small parts that are likely missing.
Do you have space that you can work on these incrementally? It might take some time.
Also keep in mind that what you learn from these will likely help with some skills that you need to work on modern bikes, but most of what you’ll be learning is a sense of bravery and adventure. Though the concepts are basically the same, things on modern bikes are often a bit different. If you can work on these, you’ll be pleasantly surprised how easy stuff goes on a modern bike. Stuff is much more precise.
Is that of any help?
April 18, 2011 at 9:51 pm #925598Riley Casey
ParticipantI have a 1980 Raleigh Tourist ( that is essentially the same bike I got for my 13th birthday in the 60s ) that I am inordinately fond of in addition to my modern Jamis. Bikes are in the end 19th century technology and are very approachable in that sense. Read and ask questions on the forum, get a good bike repair book and have at it has been my approach.
http://www.sheldonbrown.com/oldbikes/index.html
http://www.bikeforums.net/showthread.php/623699-For-the-love-of-English-3-speeds…
http://www.bikeforums.net/forumdisplay.php/10-Bicycle-MechanicsBiggest point I would make is to buy a good set of tools. The wrong tool for the job can make an easy job hard and can in the worst case destroy a perfectly good part. Bike tools are cheap compared to many things in life.
April 19, 2011 at 10:17 am #925600CCrew
Considering the 19th century was before the automobile
April 23, 2011 at 12:06 pm #925638eminva
ParticipantHello —
Thanks everyone for your help. I ended up bringing the 10-speed home and my mother is keeping the three-speed a little longer. It was in pretty good working order so my father and I tightened things up and cleaned it up so she can ride it around the neighborhood. She is okay without having working gears (go figure).
So now I have the 10-speed to play with and I’m looking forward to adding to my tool collection as I puzzle this out. I have a couple of manuals and I might get another.
April 23, 2011 at 3:00 pm #925641Riley Casey
ParticipantThe BikeForums site has a good section on bike repair too. http://www.bikeforums.net/forumdisplay.php/10-Bicycle-Mechanics
April 23, 2011 at 3:32 pm #925644dcv
ParticipantI vote for fixed gear conversion
