Power meter on a fixed gear
Our Community › Forums › Bikes & Equipment › Power meter on a fixed gear
- This topic has 12 replies, 5 voices, and was last updated 9 years, 8 months ago by
vvill.
September 28, 2015 at 1:24 pm #1038518
Participant@jrenaut 125059 wrote:
My Garmin came with a power meter.
Did it come with a power meter or a cadence sensor? Because those are two very different things.
September 28, 2015 at 1:38 pm #1038519jrenaut
ParticipantOh, you’re right, it is a speed/cadence sensor. That changes things.
People are still welcome to tell me why I would want a power meter on a fixed gear, though.
September 28, 2015 at 3:06 pm #1038530MattAune
but then I was thinking, can’t you calculate power from speed when you’re riding fixed?
In a very specific and tighly controlled environment, yes. You need to account for Crr, CdA, Grade, and Wind Speed and they all need to be constant. So unless you are on a track, or rollers in your basement it is not feasible.
I assure you that 8mph up 15th and 8mph down 15th street require vastly different amounts of power output even on a fixie.
You would want a Power Meter on a fixed gear bike for the same reason you want it on any other bike. 1) you are serious about training and power is the most useful metric. 2) to brag about your FTP
September 28, 2015 at 3:48 pm #1038534TwoWheelsDC
…and 3) knowing exactly how many beers and/or snacks you can consume post-ride without gaining weight.
I have a power meter on my Cinelli (Stages, but I’ve also used my Garmin Vector pedals) and it’s kinda interesting to see the differences in power output between FG and geared. The main difference is that on fixed, you can’t shift to keep your gearing high on downhills, so there’s a point at which it becomes nearly impossible to keep power to the pedals (mine is about 135 rpm) and your average power on a fixed gear is going to be lower than what you can generally average on a geared bike. On my commute, for example, I can somewhat easily average 200W on my Cervelo, but even pushing pretty hard on my Cinelli I can only get my average power up to about 180W.
September 28, 2015 at 5:51 pm #1038548jrenaut
ParticipantOk, this all makes sense. I doubt I really need a power meter. The cadence sensor might be nice, but the only reason for me to get a power meter is to have more squiggly graphs vs time on Strava.
September 28, 2015 at 6:04 pm #1038549jrenaut
ParticipantRelated – I now want to put a power meter on the Xtracycle and do hill repeats with the kids on the back.
Ok, not really. But a little bit.
September 29, 2015 at 6:55 pm #1038645vvill
Participant@jrenaut 125094 wrote:
Ok, this all makes sense. I really need a power meter. The cadence sensor might be nice too, but the main reason for me to get a power meter is to have more squiggly graphs vs time on Strava.
FTFY
Having a cadence sensor on a FG is slightly pointless if you have a speed sensor too. But it will let you verify your crazy spinning/stupid mashing, and you could calculate your gear inches from your data. Also, if you’re a skid stopper you could see that too I guess!
I have used a Stages power meter on four of my bikes, it’s handy. I verified that towing a trailer with kids on a folding bike uphill needs more power. But mostly because yeah it is the most useful metric if you’re trying to quantify your actual output. Wish it was easier to have one on every bike (n+1 problems…)
September 29, 2015 at 7:00 pm #1038646vvill
I’m interested to try a power meter on the FG (I have run it once or twice on my converted hybrid when it was FG), mostly because I’m curious if a FG ride will result in lower power at the same speed. Of course, even just spinning the cranks you use up calories, but I did notice it was quite easy to spin on flats/downhill showing 0W.
October 7, 2015 at 12:45 am #1039063TwoWheelsDC
Well, this is about as good a comparison as I can probably ever do. Same length of the same section of road (123>Chain Bridge>Great Falls), yesterday on the R3 and today on the Cinelli. Speed, and HR are practically the same, but average power on the R3 was 15W higher with slightly lower average cadence. I attribute that to a bit more wind yesterday, small difference in power meters (Vectors on the R3, Stages on the Cinelli), higher drivetrain efficiency with the Cinelli, and I think the R3 may be a pound or so heavier than the Cinelli. It’s also a bit wonky since there are differences in the timing I hit the various lights along the route. Also interesting is that total kJ for each ride were basically identical.
That said, it does seem that a fixed gear running a large-ish gear (48×16) is more efficient (less power to maintain the same speed) than a geared bike, but there are still a lot of variables…
[IMG]https://farm1.staticflickr.com/575/21385375903_8a7528570c_h.jpg”[/IMG]
October 7, 2015 at 1:55 pm #1039085MattAune
ParticipantJust to be a pain, I will mention that I routinely see greater than a 15w variance between my stages and Quarq/Powertap on the same bike on the same ride. Then throw in wind, Crr, CdA differences and it is really hard to make any conclusions.
One day maybe I will do a few back to back runs on the same bike and same power meter switching between fixed and singlespeed because it is a pretty interesting question.
October 7, 2015 at 2:44 pm #1039080Tim Kelley
Don’t forget drive train inefficiency! You’ll have the least power lost at the pedals, then crank, then finally by the time you’re measuring at the hub you’ve could definitely have lost a few watts. Remember that article testing different chain lubes to see what the biggest watts saver was?
October 7, 2015 at 6:49 pm #1039109vvill
ParticipantYeah there’s a few problems with doing meaningful tests. I love the convenience of the Stages but it is left sided only so it’s comparable really only with its own data (I imagine it mightn’t be accurate enough for Crr/CdA testing).
In a well-controlled environment I think you could test meaningfully for drivetrain loss differences between FG, SS and geared (without changing gears during the test – just throw on a rear derailleur and longer chain, and maybe alter the chainline slightly to simulate that). Other differences such as those from shifting gears, and coasting vs spinning down hills, etc. might be tougher to do, and probably aren’t that useful anyway. It’s tough to get into an aero tuck spinning at 120rpm+, or spin really fast, so a freewheeling hub is going to have advantages there, and differences in terrain across test courses will affect gearing choices and how much shifting and coasting you do on a geared bike.
