Pants for fall/winter exercise rides
Our Community › Forums › Bikes & Equipment › Pants for fall/winter exercise rides
- This topic has 21 replies, 15 voices, and was last updated 13 years, 7 months ago by
PrintError.
October 27, 2011 at 3:43 am #931524
mwander
ParticipantI’m doing the same shopping planning now – before the weather changes.
I’m curious whether folks tend to purchase wind or water resistant or both (wind and water resistant). I’d like to buy something that’s useful for as many different weather conditions as possible. What tends to be most useful for… cold? wind? rain? snow?
What brands are popular?
Thanks.
October 27, 2011 at 3:57 am #931525Justin Antos
ParticipantI’m wondering the same thing. Have been pondering a pair of Pearlizumi pants but they’re not cheap. Looking forward to the forum’s advice…!
October 27, 2011 at 8:14 am #9315265555624
ParticipantWhen the temperature drops into the mid-50s, I add a pair of Lycra running tights over my bike shorts. When the temperature drops down into the low-40s, I switch to a pair of Polartec tights. I really don’t find the wind to be a problem with either option. In single digits I might layer, which means tights and rain pants.
If it’s raining/snowing? Rain pants from a rain suit. (Over the years, I’ve replaced the jacket, but since the rain pants don’t usually get worn when it’s warm, they’re still fine in the rain/snow.) If there is no precipitation, though, I just go with the tights.
It never gets too cold — at least since I have lived here — to ride.
October 27, 2011 at 8:30 am #931527JimF22003
ParticipantI have a pair of cheap Performance brand tights that I wear over regular bike shorts when it’s down to about 35-40 degrees or so, and a pair of heavier tights with zippers at the ankles that I use when it’s anything below that. The Performance tights aren’t very thick — about the thickness of standard arm warmers. The other tights are way too thick unless it’s very, very cold.
October 27, 2011 at 10:18 am #931530CCrew
ParticipantI wear cheap Starter brand running pants bought at WallyWorld for less than $10 a pair tucked at the ankle with my RoadID ankle strap
Wear short bibs or the chamois inner linings from the various Zoic MTB shorts I own underneath
October 27, 2011 at 12:00 pm #931532vvill
ParticipantI have a few pairs of MTB shorts – by nature they are 2 layered. I have cheap leg warmers from Nashbar that I pull up to cover the inner padding layer of the MTB shorts. The outer shell layer of the shorts then keeps out a good amount of wind/water.
October 27, 2011 at 1:54 pm #931543DismalScientist
ParticipantKhakis, with a rolled up cuff down to about 30 degrees. :p
I don’t do rain.October 27, 2011 at 2:27 pm #931555americancyclo
Participant@Joe Chapline 9668 wrote:
I’m averse to tight-fitting clothes, and I don’t mind using ankle straps, I’m used to that. Any suggestions?
My first reaction was, ‘No, all my winter stuff is form fitting’ and I like my Pearl Izumi Elite Thermal Cycling Tights but then I remembered I have a pair of Royal Mail waterproof overpants that I used to wear when I had to bike commute in the rain more often. I’m sure you could find them or an equivalent at any military surplus store.
They are loose, waterproof, and keep out the wind very well. That being said, they are not breathable, and the pair I have requires ankle straps to keep out of your gears.
Is the Barrier WXB Pant too form fitting for your taste?
October 28, 2011 at 12:14 am #931597Joe Chapline
ParticipantThanks for all of the suggestions, I will research these.
All the shorts I have are the 2-layered kind, so this could work. Now that I think about it, that’s how we did it back in phys ed — uniform shorts over the sweatpants. I could possibly maybe even consider tights in this scenario.
The Novara Headwind pants from REI seem like a good concept — water- and wind-resistant in the front, wicking in the back. I don’t intend to go out in the pouring rain to exercise, but on days when the weather is unsettled, it would be good to know that if there’s a little drizzle I’ll be fine.
October 28, 2011 at 12:24 am #931599Joe Chapline
No, that could work. I don’t really need waterproof, though, I’m just looking for a step up from sweatpants, which soak up water like a sponge. With waterproof gear, breathability is a problem, as you said. I have a rain suit I wear to commute, I wore it today. This was actually a nice rainy day — cool enough to wear the rain suit. Thanks for the suggestions; I’ll check out the tights, too.
October 28, 2011 at 1:19 am #931602Arlingtonrider
ParticipantREI is well stocked with all those things right now, in both men’s and women’s, but they’re selling pretty fast. My favorite purchase this season is the $19.99 clear plastic vented rain jacket I bought from Performance bikes. It has a really long apron in back, vents along the sleeves and sides, a high collar, and a Velcro closing. Worked like a charm today, and you can just wipe it off to clean it. Some reviewers said that the Velcro eventually comes unstitched, but I would think that you could just glue it back on. It wouldn’t be good for serious riding, but I think it will be fine for my commutes. Joe, I just noticed your earlier post about the Novarra Headwinds pants. Those are the ones I bought tonight. I think I’ll like them a lot.
October 28, 2011 at 2:50 am #931607PotomacCyclist
ParticipantI have a nice pair of Under Armour running pants that can work for winter riding. They are not form-fitting but they aren’t baggy either. They taper at the ankles with a zip-up bottom. The pants are black with a reflective strip down the side of both legs. There are two pockets with zippers. I don’t have to worry about my keys falling out while I’m riding or running. I bought them at City Sports a couple years ago.
I rotate those pants with Under Armour tights. I usually wear triathlon shorts under the running pants or tights.
I’ve tried leg warmers with mixed results. They tend to slip down on me. They are fairly tight, but they still slip. They don’t work when I run, but they might work better on the bike. I don’t remember if I’ve ever tried them while riding.
The pants and tights will help a bit with rain, but you’ll still get wet. At least the fabric doesn’t soak up water the way that cotton does.
If I layer up, my legs generally are OK on cold days. I have more issues with my hands and feet getting too cold on those days, even with glove liners, thick winter gloves, mtn bike shoes, socks and neoprene shoe covers. I’ll have to try the chemical hand and foot warmers this winter.
October 28, 2011 at 3:03 am #931608Joe Chapline
I will check out the Under Armour products. Love them, go Baltimore!
October 28, 2011 at 12:13 pm #931616americancyclo
Have you looked in to getting moose mitts, or similar? I’ve heard good things from forum members about them, and I see that you were thinking about getting them (or heated winter gloves) last fall, from reading this post
October 28, 2011 at 3:17 pm #931650PrintError
ParticipantI’m still just wearing shorts, your legs generate a lot of heat when pedaling!
