Newb questions about fixing flats.
Our Community Forums Bikes & Equipment Maintenance Newb questions about fixing flats.
  • #917429
    I am a bit embarrassed to show what a mtnce newb I am, but embarrassment keeps people from learning, so here goes.
    I had a flat over a month ago, someone lent me a tube, I am now trying to fix the flat so I can return the tube (my old tube is a schrader, and the borrowed one a presta, so they are not interchangeable) and because I need to learn to do this.
    I managed to find the puncture, and there were two holes near each other (which I guess means it was a pinch flat?)
    I used the little roughening tool that I found in my bike room toolkit, some glue (from my own flat fixing kit, some swag I got on BTWD I think) and the little patches. I think I did one of the patches too quickly (and had glue on my fingers and was generally messy about it) and didn’t quite get it down smoothly on the tube surface – anyway, when I came back to look at the tube a day later (I did not put the tube in the tire yet) it had lost most of the air I had filled the tube with. This weekend I tried again, putting a third patch on top of the patch that seemed to have been put down wrong, filled the tire again, and rode off (on the borrowed presta tube – I wanted to make sure the fix was holding) When I came back a few hours later, the tube had lost the air again.
    So question 1 – does this show I patched improperly – or is there something about inner tubes that they will not hold air if outside a bike tire? (Remember there is NO SUCH THING AS A DUMB QUESTION).
    If the latter, I guess I should fill the tire, and then put it in the tire right away.
    If the former, do I need to remove the patches I have put on and start from scratch?
    Your assistance is appreciated.
Viewing 15 replies - 61 through 75 (of 80 total)
  • #1054927
    @hozn 142700 wrote:
    Yeah, I know that this is possible / that people do this, but that’s a good point. My concerns with a tubed-system would be finding the leak, though typically I’d prefer to do that even if I’m just gonna replace the tube (so I can check the tire for the culprit).
    Tubeless really does make this a whole lot easier, though:
    Do they make a tubeless 590mm for 1960’s vintage 3-speeds?
    #1054930
    Sez you. Some of us are not that smart, or perhaps think it sounds like a whole lot of extra work for minimal gain. I think that’s the opposite of “easier.”:p
    /threadjack.
    #1054932
    @hozn 142708 wrote:
    Tubes can be had for $2.99, so you can hopefully outfit yourself for a year of cycling for $15.
    Where do you get yours? Got any tubes with 80mm stems at that price?
    #1054933
    If it’s low-pressure (< 45psi), you could just tape the rims & throw sealant in there and see what happens. But if it's road pressures, then this would be ill advised. So the only solution is probably n+1 :)
    #1054934
    Last time I needed 60mm valve stems, I added a couple tubes to my order from jenson. http://www.jensonusa.com/Duro-Road-Presta-Valve-Tube … Those are perfect for tubeless since they’re threaded all the way to the top (I am using them in 50mm rims). Sure was cheaper than $14.99 for a set of Stans stems [that would have required another $20 !?! for Stans threaded valve extenders!]. They don’t come in 80mm, though, no :-[
    #1054935
    @hozn 142708 wrote:
    Just remember that the small patch kits are basically one-time use (unless you happen to flat again before the glue dries out). The adhesive patches are a lot faster and then you can do the real fixing at home. Or just recycle the tube. Tubes can be had for $2.99, so you can hopefully outfit yourself for a year of cycling for $15. I repair tubes (or did when I used them) since I have a box of patches and a big tub of glue, but I don’t think it makes any sort of economic sense.
    I am pretty sure I used the same glue that I used for the failed attempt at a fix in March (described in the OP).
    #1054936
    That’s fair. If you never (or very rarely) flat then I agree it probably isn’t worth the hassle. It does lower rolling resistance, etc. but that isn’t my primary motivator. The GP4000SII tires with latex tubes feel at least as fast as Schwalbe Pro One tubeless.
    Oh, I did forget about flatting out [on tubeless] in the gravel at Poolesville Road Race. I put in a tube for that, since I didn’t have any plugs with me (saddle bag in the car) and fixed the tire at home.
    #1054937
    @Harry Meatmotor 142683 wrote:
    Try one of these!
    The Surly site says Bicycle Space may have those tuggnuts. They’re a short walk from werk or on the ride home. Looks like it would work a lot better than my idea of inserting a bolt in front of the axle.
    #1054939
    Ah, so you *can* put a tube in a tubeless in an emergency. How you get the tire glued back on trailside though I don’t even want to think about; or does it still clinch if there’s a tube in? (No need to answer that because Google.)
    I used to get a lot of flats, especially in Georgetown, but started going with slower, heavier tires with better protection and have now reached an acceptable level of flats. I still wouldn’t call it “very rarely” because the sample size isn’t large enough yet, but here’s hoping.
    #1054940
    Yeah, there is no “glue” with tubeless. Just latex sealant. Technically (usually) optional but kinda required for the self-sealing properties. It’s just a regular clincher tire, though, if/when you want to use a tube.
    This is completely unrelated to tubular tires, which I definitely think would be way too much hassle .
    #1054941
    Harry Meatmotor
    Also, for the belt-and-suspenders-types out there (or, if, for example, you’ve got an internally geared rear hub and don’t want to futz with all that jazz during a commute…), just squirt some Stan’s sealant (or Effetto Mariposa Caffelatex, or Orange Seal) into your new/unpunctured innertube before inflating it, and get all the puncture-resistance benefits of tubeless without dealing with the potential tire issues, or mess. For Schrader valve tubes you’ll need to remove the core, and for presta valve tubes I highly recommend pulling the core, but it’s not necessary. Yes, eventually the sealant will dry out, but it should get through at least a full fair-weather (May to October) cycling season just fine. In 12 months you’ll probably want to squirt fresh sealant in anyhow.
    #1054942
    @Harry Meatmotor 142723 wrote:
    just squirt some …. Effetto Mariposa Caffelatex,
    Wasn’t this one of the ways you could earn points in Brünø’s Big Bad Coffee Challenge?
    #1055086
    I should have been more precise and said “sealant,” which in my casual frame of mind at the time was synonymous with glue. However, now I know better because I’ve been thinking about it. My Ultegra wheel with Pro4s was flat, so I changed the tube, doing the usual look in the tire for glass and thorns. There was nothing there, but when I pumped the tube up, it immediately blew; however, the tire did not go flat! I was like, hey, if only I had some *sealant* I could ride this bike. Instead, I got out another bike. Pretty sure there’s something coming through the rim tape; will pump up the tube to find the hole location when I have time, but I do think I’ll stroll down to the LBS and get some sealant in the meantime. I’m nervous about trying it, but I was nervous about a lot of things I tried and then moved to doing all the time.
    #1055102
    Yeah, just note that you need a tubeless-specific tire if you are going to ditch the tube altogether. (You can, of course, add sealant inside a tube too.)
    #1056999
    After my flat on Saturday, I schlepped the bike home (post Mellow Mushroom) and since I was going to be putting the LITs on anyway, decided to do all that at once. I swapped out the tires (a bit harder than changing a tube, but not that much) and replaced the blown tube with an old repaired tube I had kept. The bad tube has a biggish hole right near the valve. Focusing on getting the new tires on, I did not remember to note where on the old tires the hole had happened. Or even which tire was which. I guess I now need to go over the old tires to see if there is something that punctured them. I am also guessing it is probably not worth repairing this blown tube.
