Newb questions about fixing flats.
Our Community › Forums › Bikes & Equipment › Maintenance › Newb questions about fixing flats.
- This topic has 80 replies, 23 voices, and was last updated 8 years, 9 months ago by
bentbike33.
July 7, 2016 at 3:00 pm #1054896
Participant@Harry Meatmotor 142675 wrote:
edit: also, to assuage any guilt associated with throwing used/punctured tubes in the trash, many shops have tube recycling programs.
I love finding discarded tubes. Free valve stems!
I agree with not using glue on the trailside. The adhesive patches work great for the I-already-used-my-tube trailside repairs, but I don’t keep them in long-term.
Actually, since converting to tubeless I don’t think I’ve had a situation where I had to put a tube in. Probably 7k miles now between the two bikes, maybe a bit more. I have ridden on less-than-ideal pressure once or twice. I still carry a tube of course — and patches. On long rides, I carry two tubes.
July 7, 2016 at 3:10 pm #1054898chris_s
ParticipantI used to be a “just put a new tube on” guy until I was forced to use a patch kit without removing the wheel while I was in the Netherlands. Now I’m a convert, especially since the rear wheel on my commuter is tough to get off and both wheels of the Bakfiets are a challenge. Now I’m a “patch the tube while it’s still on the wheel” person. I’ve heard a fair amount of negativity about the durability of the self-stick patches.
July 7, 2016 at 3:18 pm #1054900huskerdont
Participant@chris_s 142679 wrote:
I used to be a “just put a new tube on” guy until I was forced to use a patch kit without removing the wheel while I was in the Netherlands. Now I’m a covert, especially since the rear wheel on my commuter is tough to get off and both wheels of the Bakfiets are a challenge. Now I’m a “patch the tube while it’s still on the wheel” person. I’ve heard a fair amount of negativity about the durability of the self-stick patches.
Hadn’t thought of that. That could work when I get a flat on my fixie and I have forgotten to bring my full-sized wrench with me. (I have one of those little Crank Bros wrenches that I usually carry, but in all honestly, I think that would only work if I had a rock handy to hit it with. If I don’t really tighten the rear wheel down hard, it will slip through the track dropout; in fact, even when hammered down, it will eventually slip some over the course of a few weeks. So, I keep a full-sized wrench in my bag, but don’t always remember to take it out of the bag when I ride without it.) So, great idea. I’m learning here.
July 7, 2016 at 3:21 pm #1054901Steve O
It’s surprising that many people do not know that one can fix a flat without removing the wheel from the bike. Sure, if it’s a quick release, NBD. But my toodler bike requires wrenches and the rear has a coaster brake. I’ll fix that tube until it has 20 patches, using glue, of course, so they’re permanent.
July 7, 2016 at 3:25 pm #1054902Harry Meatmotor
July 7, 2016 at 3:26 pm #1054904Steve O
I agree with this conceptually.
My problem is that I forget that I put the glueless patch on…or I tell myself, “I’ll do it Saturday.” But then I never do and 10-30 days later I have another flat. So until I get a memory upgrade I’ll stick with glue, even on the trailside.July 7, 2016 at 3:30 pm #1054905ShawnoftheDread
Participant@Harry Meatmotor 142683 wrote:
Do you know of anything like this that works on forward facing horizontal drops?
July 7, 2016 at 3:42 pm #1054910Harry Meatmotor
My problem is that I forget that I put the glueless patch on…or I tell myself, “I’ll do it Saturday.” But then I never do and 10-30 days later I have another flat. So until I get a memory upgrade I’ll stick with glue, even on the trailside.or you could just put a new tube in :confused:
July 7, 2016 at 3:47 pm #1054912Harry Meatmotor
Somebody’s bound to make something that would work for FWD facing dropouts, but I haven’t really ever looked for one, either.
July 7, 2016 at 3:49 pm #1054914Steve O
Again, I agree with this conceptually, but there have been occasions where I have given my tube away on the trail and then forgotten I’d done that, so I ride around with no spare tube for weeks. Or some other boneheaded reason why I either don’t have a tube or it’s not functional or something else. Do not underestimate the negative effects of aging on one’s mental acuity.
July 7, 2016 at 3:55 pm #1054916Harry Meatmotor
Participant@Steve O 142696 wrote:
Do not underestimate the negative effects of cold vulcanizing glue fumes on one’s mental acuity.
:p :p :p
July 7, 2016 at 3:57 pm #1054918hozn
Yeah, I know that this is possible / that people do this, but that’s a good point. My concerns with a tubed-system would be finding the leak, though typically I’d prefer to do that even if I’m just gonna replace the tube (so I can check the tire for the culprit).
Tubeless really does make this a whole lot easier, though: if the leak is small enough that it’s hard to find, then you won’t have had to stop in the first place. If it’s large enough that sealant doesn’t work for it, then it’ll be really obvious exactly where the leak is and you can just throw in a tube without needing to track down where the intrusion was on the tire — or use tubeless repair plugs without touching the tire levers (my first choice).
July 7, 2016 at 4:41 pm #1054923vern
I will start placing discarded tubes in the weeds in Hunter Mill Valley to give you an occasional thrill.
July 7, 2016 at 4:42 pm #1054924lordofthemark
Participant@Harry Meatmotor 142664 wrote:
Honestly, why does it seem that everyone around here insists on using cold vulcanizing patch kits?
In my case because the patch kits are handed out free as swag. At this point I think I will keep the patched tube at home, and refrain from trying a ‘field patch’ till I feel more confident about it (and till I keep all the appropriate stuff with me)
July 7, 2016 at 4:47 pm #1054926hozn
Just remember that the small patch kits are basically one-time use (unless you happen to flat again before the glue dries out). The adhesive patches are a lot faster and then you can do the real fixing at home. Or just recycle the tube. Tubes can be had for $2.99, so you can hopefully outfit yourself for a year of cycling for $15. I repair tubes (or did when I used them) since I have a box of patches and a big tub of glue, but I don’t think it makes any sort of economic sense.
