My fixed gear project
Our Community Forums Bikes & Equipment My fixed gear project
  • #915972
    I was planning to wait until some other things got done in my life, but I was a little bored this afternoon, and instead of going for a ride, I stripped down my old Schwinn World!
    [ATTACH=CONFIG]6793[/ATTACH]
    I don’t have a crank puller or any bottom bracket tools to get those off.
    [ATTACH=CONFIG]6794[/ATTACH]
    Fork is good. I kept the seatpost bolt just in case, but I’ll have to replace those ball bearings for the steerer.
    [ATTACH=CONFIG]6795[/ATTACH]
    A pile of parts. The seat is fair, but the seat tube is too short. Those rims have rust patches in the braking surface. I could keep the stem and bars, but they’re pretty rusty.
    So what I’d like to do is turn it into a fixie, and I’d like to use new components, in part because the old ones are really dingy, but also because I’m too lazy to troll endlessly for used parts on Craigslist. I want the finished product to be a bit of a beater, but I’d like it to be reliable, and if I wanted to upgrade to a nicer or newer frame, I’d love to be able to move the components over without them being totally out of place. That said, I’m not ready to spend a fortune.
    I realize, of course, it would be cheaper and easier to buy a new fixie from somewhere like Purefix, but then I wouldn’t get to do the work myself.
    So, gurus, what say you? I’ll have lots of questions as I go, and this project will probably take months, but I’m interested in how you all think I should go about getting started.
Viewing 15 replies - 16 through 30 (of 160 total)
  • #1012632
    @bikesnick 97434 wrote:
    I used an automotive gear puller on my single speed conversion of dumpster find road bike.
    The crank puller I used on it does essentially the same thing as the auto gear puller, except it threads into the crank arm instead of grabbing onto the gear. The leverage would probably be about the same, I’d think. I had two wrenches going in opposite directions on the thing, and couldn’t budge it. A new bottom bracket isn’t expensive enough to warrant me working any harder on that old crank; I’ll just replace it.
    #1012636
    Rockford10
    @DismalScientist 97408 wrote:
    Why bother with a new headset? I would think if the old one worked, just leave it alone (after repacking).
    They have quill stems with modern handlebar attachments. That may make more sense than an adapter plus stem.
    New saying at the DKel household, WWDD?
    DKel: Can I buy [insert random bike tool]?
    Me: WWDD? Also, HFAOYDAY?
    #1012650
    peterw_diy
    I expect the answer should be expressible as a mathematical equation, and that equation would not be N+1, at least not for any definition of 1 that hozn would accept. ;-)
    #1012662
    Hey, how did I get thrown into this? :) For the record, I “only” have 3 bikes with no plan/ability to add to that unless I also n-1. Space-constrained — the brilliantly simple way to rein in my consumerist tendencies.
    #1012678
    You loom large in our world.
    #1012681
    But only for a second as he rides past…then he gets really small really fast.
    #1012684
    peterw_diy
    Any b
    #1012690
    And he gets a bit redder also.
    #1012696
    #astrophysicshumor
    #1012697
    And he stays younger longer.
    #1012703
    Back on topic…
    After I get the headset put together, I think wheels are the next step. Then I can put them on and measure for chain line so I can get the right bottom bracket spindle length. (Man, this is complicated). A couple of questions for you experts:
    I’ve just been looking at these. I’m intrigued by the fixed/fixed rear hub, and I like the machined braking surface. Black is nice, too, and so is the price on these. Does anyone have thoughts? I believe vvill recommended the fixed/fixed configuration; there’s more flexibility to that in the long run, isn’t there?
    Last thing, my front fork has these thingies:
    [ATTACH=CONFIG]6879[/ATTACH]
    to go in these thingies:
    [ATTACH=CONFIG]6880[/ATTACH]
    like this:
    [ATTACH=CONFIG]6881[/ATTACH]
    How important would it be to keep these on there, since there are no flared edges to hold the wheel in if the skewer loosens up? Seems like those washers aren’t very substantial to hold the wheel in the fork ends, and with track hubs, the wheels will be held on with regular old nuts, which are easy to crank down.
    #1012704
    Wow.
    #1012718
    @hozn 97514 wrote:
    Wow.
    You usually provide a little more insight than this…
    #1012725
    cyclingfool
    Last edited by dkel; Today at 03:56 PM. Reason: Or were you responding to your routine demonstration of relativistic physics?
    I think this is what he meant:
    [ATTACH=CONFIG]6882[/ATTACH]
    i.e., the latter. ;)
    #1012733
    You don’t need the retaining washers. Unless you’re a lawyer, in which case bikes are very dangerous and the washers are a vital safety feature that I would never suggest you remove because you might die.
