My fixed gear project
Our Community Forums Bikes & Equipment My fixed gear project
  • #915972
    I was planning to wait until some other things got done in my life, but I was a little bored this afternoon, and instead of going for a ride, I stripped down my old Schwinn World!
    [ATTACH=CONFIG]6793[/ATTACH]
    I don’t have a crank puller or any bottom bracket tools to get those off.
    [ATTACH=CONFIG]6794[/ATTACH]
    Fork is good. I kept the seatpost bolt just in case, but I’ll have to replace those ball bearings for the steerer.
    [ATTACH=CONFIG]6795[/ATTACH]
    A pile of parts. The seat is fair, but the seat tube is too short. Those rims have rust patches in the braking surface. I could keep the stem and bars, but they’re pretty rusty.
    So what I’d like to do is turn it into a fixie, and I’d like to use new components, in part because the old ones are really dingy, but also because I’m too lazy to troll endlessly for used parts on Craigslist. I want the finished product to be a bit of a beater, but I’d like it to be reliable, and if I wanted to upgrade to a nicer or newer frame, I’d love to be able to move the components over without them being totally out of place. That said, I’m not ready to spend a fortune.
    I realize, of course, it would be cheaper and easier to buy a new fixie from somewhere like Purefix, but then I wouldn’t get to do the work myself.
    So, gurus, what say you? I’ll have lots of questions as I go, and this project will probably take months, but I’m interested in how you all think I should go about getting started.
Viewing 10 replies - 151 through 160 (of 160 total)
  • #1017767
    That’s a really nice looking bike. Enjoy
    #1017768
    Congrats on finishing! Just in time for the big Jan 1 ride!
    Weird about the quill adapter; but that is how it is supposed to be? (I.e. it is sufficiently braced/secured and you’re not worried about safety concerns with the stem mounted so far above the HT?)
    #1017770
    I read about this on Sheldon’s site. The HT tapers in near the bottom, which is why the quill only goes in so far. There are two concerns for the quill: minimum insertion depth and not engaging the wedge against the tapered part of the HT. I’m in fine shape with regard to both aspects, so that quill isn’t going anywhere. I think what happened is that some quill adapters are longer for the specific purpose of raising the bars. Some are quite long; I just managed to pick out one that’s intermediate in length, without being specifically a quill extender. Origin8 makes one that’s a few cm shorter, and I can always go with that if I want to change it. Also, being a threaded headset, the stem doesn’t need to rest against the top race, unlike a threadless system that is held together by the stem.
    #1017771
    Ah, ok; interesting. I suppose you could also replace the fork with a 1″ threadless steerer fork if you wanted? Anyway, looks great. Enjoy!
    #1017773
    I could replace the fork, yes. I’m more likely to replace the whole frame eventually, though, as this one does have its shortcomings, not least of which is that it is borderline too small for me. It’s funny though, when I imagine all the things I might like a fixed gear frame to do, I end up with a list of things that is pretty much met at every point by my Straggler. It might be easier to just convert that to fixed (he said, as if money were no option). One thing at a time, though: I haven’t even gotten comfortable riding fixed yet, so it’s a little early to start thinking of converting my “do-everything” bike into a FG.
    #1017775
    I misspoke here: it’s the steerer that tapers in towards the fork crown, not the HT.
    #1017784
    schvin
    sweet build! thanks for reminding me of the forums :)
    -george
    #1017785
    I think I just fell in love with cycling all over again! I took the new build out from Falls Church to Java Shack (never been there before!), back the other way out to Gallows Rd, and then home again. 19+ miles. It was amazingly easy! I only tried to coast a couple of times, and I never had any trouble on climbs; in fact, they felt oddly easier than on my commuter. I have figured out how to use the front brake to lift the rear wheel and set my pedals for the next start, and I never felt like I was spinning too fast. This bike is much lighter than my commuter, so I’m sure that’s why some of the riding was much easier; still, I felt like I was connected with the bike, and we were totally working together. Just amazing! Having done all that work on the build myself added to the magic. 😎
    #1017787
    One last, important thing: a massive THANK YOU to all you forum gurus for all the advice on how to execute the build!! I couldn’t have done it without all the great advice and encouragement I received here, nor would I ever have had the idea and courage to try it. This forum makes cycling better! You guys are the best!
    #1017788
    Another thing to think about, which may or may not end up affecting you, is that riding fixed requires a bit of re-thinking when it comes to winter layering. I find that it’s a little more difficult to regulate my body temp when riding fixed, because there’s no pedal-heat up/coast-cool down cycle…I’m constantly working. So layers that I could wear comfortably on a geared bike for a given temperature may cause me to overheat and sweat a bit more when riding fixed. It’s not a huge difference, but I try to layer down by about a half-layer’s worth when I ride fixed to compensate.
    Again, maybe this is all in my head, but for me it is one of those weird adjustments that you don’t necessarily think about when making the transition.
