My fixed gear project
Our Community Forums Bikes & Equipment My fixed gear project
  • #915972
    I was planning to wait until some other things got done in my life, but I was a little bored this afternoon, and instead of going for a ride, I stripped down my old Schwinn World!
    [ATTACH=CONFIG]6793[/ATTACH]
    I don’t have a crank puller or any bottom bracket tools to get those off.
    [ATTACH=CONFIG]6794[/ATTACH]
    Fork is good. I kept the seatpost bolt just in case, but I’ll have to replace those ball bearings for the steerer.
    [ATTACH=CONFIG]6795[/ATTACH]
    A pile of parts. The seat is fair, but the seat tube is too short. Those rims have rust patches in the braking surface. I could keep the stem and bars, but they’re pretty rusty.
    So what I’d like to do is turn it into a fixie, and I’d like to use new components, in part because the old ones are really dingy, but also because I’m too lazy to troll endlessly for used parts on Craigslist. I want the finished product to be a bit of a beater, but I’d like it to be reliable, and if I wanted to upgrade to a nicer or newer frame, I’d love to be able to move the components over without them being totally out of place. That said, I’m not ready to spend a fortune.
    I realize, of course, it would be cheaper and easier to buy a new fixie from somewhere like Purefix, but then I wouldn’t get to do the work myself.
    So, gurus, what say you? I’ll have lots of questions as I go, and this project will probably take months, but I’m interested in how you all think I should go about getting started.
Viewing 15 replies - 1 through 15 (of 160 total)
  • #1012073
    dcv
    When looking for new wheels check the rear spacing, measure the distance between dropouts. Most road bike frames are 130mm but some older frames may be 126mm.
    Also think about chainline, distance from centerline to the chain. Both the cog and chainring should match. You’d have to check the hub and the crankset/bottom bracket specs.
    So much to discuss, perfect coffee club agenda.
    Did you look up Sheldon Brown yet?
    #1012085
    I’ve spent lots of quality time with Sheldon. Good stuff. My rear spacing is 126 without the hub squeezed in the dropouts, but it may be 120 when it’s all tightened up. I’ll have to measure the hub that was in there and see. I’ll plan to get my butt out of bed early enough so I can get to VTCC and receive some wisdom!
    #1012091
    If it’s a steel frame, it don’t matter. If you had a 6 or 7 speed freewheel, it’s 126. If 5 speed, it’s 120.
    If your bottom bracket spins OK, don’t do anything and slap on a new crank if you are sick of running on your small chain ring. If your bottom bracket needs adjustment, just replace it with a new sealed unit. Replacement will take about the same effort as adjustment.
    In the end it may be cheaper to buy new and move all the components to your frame and sell the new frame.:rolleyes:
    Rust on the rims? Are these steel? If so, I’ld look for a used wheelset with alloy rims.
    #1012093
    I remember the nice chromed steel rims on my old schwinn. Even brings back memories of the time I decided to really make the bike shine and waxed the wheels. (Pro tip: don’t do that. What did I know, I was a young teenager.) I’d recommend a nice new/used set of alloy rims, especially if you run at high pressure (some of the old steel rims didn’t have bead hooks, so you can blow a modern tire off fairly easily) or if you might ever ride in the rain (steel rims are horrible for stopping in the wet, even if not waxed).
    #1012095
    This is true, and it causes my head to spin. I can’t bring myself to do that. (It’s only money, after all.)
    #1012464
    Finally got the cranks off and the bottom bracket out.
    [ATTACH=CONFIG]6831[/ATTACH]
    Also got the last bits of the headset out of the head tube.
    [ATTACH=CONFIG]6832[/ATTACH]
    The frame is all cleaned up. It weighs 6 lbs on my bathroom scale. I don’t think that’s very accurate, but it must be in the ballpark.
    [ATTACH=CONFIG]6833[/ATTACH]
    I’ve been looking online for components. Fyxation has some pretty things that are cheap…
    #1012477
    mcfarton
    Now is the time to have the frame powder coated.
    sent from your mom’s house
    #1012478
    Tempting, but I don’t think this frame warrants that treatment. It’s not even chromoly; it’s cheap hi-ten steel. I also want it to look like a beater. A nice beater, but a beater nonetheless. If the build works, and I love riding fixed, I can get a nicer frame and move the components over.
    #1012479
    Yeah… That’ll add another $200 to the project.
    #1012599
    I ordered a cheap headset. I’m thinking I’ll get a threaded to threadless adaptor quill, so I’ll have more options in bars, and potentially less trouble taking the bars off and putting them on something else.
    This will be obvious for the experts on the forum, but for the rest of us: if you’ve ever wondered how bikes work, build one up yourself. I’ve already learned a lot about bikes, and I’ve only ordered one part! It’s pretty amazing.
    #1012603
    Let me know if you need to borrow a (DIY) headset press or crown race seating tool.
    #1012604
    Why bother with a new headset? I would think if the old one worked, just leave it alone (after repacking).
    They have quill stems with modern handlebar attachments. That may make more sense than an adapter plus stem.
    #1012607
    The old one had some brinelling. The bottom bracket still worked great, and I was considering keeping it, except I still can’t get the crank arm off the drive side. In any case, it’s good experience for me to replace all these parts.
    I did see some of those. I’ll look into that further. If I’m remembering correctly, there are few options of that type. One of my challenges is finding bars that I will like, and standard quill stems tend to have retro sizing for bar diameter. Again, more options in threadless, including the wide diameter like I have on my Straggler. (One of my visions is that I might like riding fixed so much that I would move some of these components over and run the Straggler fixed for commuting…)
    #1012609
    Phatboing
    Oh oh I actually have a threadless quill adapter thingy that you’re welcome to try out.
    #1012629
    @dkel 97411 wrote:
    … I still can’t get the crank arm off the drive side.
    I used an automotive gear puller on my single speed conversion of dumpster find road bike.
