Maximum PSI
Our Community Forums General Discussion Maximum PSI
Viewing 8 posts - 1 through 8 (of 8 total)
  • #930145
    I wouldn’t run over 120 on local roads. I’m not familiar with those specific tires. I’ve got tubulars that max out at 200 psi. Anything over 120 in them makes the ride quality bad. If you are racing, perhaps trading ride quality for less rolling resistance is worth it.
    Check the maximum pressure for your wheels. Rims usually are limited in the low to mid 100s.
    I hope that helps.
    #930146
    StopMeansStop
    I’ll second that. If youre not racing, never run at max PSI.
    #930148
    Unless your local roads are unusually smooth, 150psi is not only harsh but slower as well. Overinflated tires don’t conform to the road surface and actually increase rolling resistance.
    Check http://velonews.competitor.com/2011/07/tour-de-france/tour-de-france-tech-wet-weather-preparations_181775
    Perry Moarman, HTC team mechanic, said that normally the team will inflate to 8.0 bar (116 psi).
    Pros are running under 120psi (on tubulars, no doubt). The correct pressure for you will depend on the tire, your weight, and what your local road surfaces are like. But 150 is almost certainly excessively high.
    #930151
    OneEighth
    “These go to eleven.”
    I use Zaffiros, too, and prefer to pump them about as hard as they will go.
    Do what is comfy for you within the inflation range of the tire. But don’t overinflate it to get it to the max pressure. You’re not doing the tire any favors.
    #930167
    KS1G
    They may go to eleven, but I prefer it more around eight. More is not always better.
    150 psi? word – That would result in a painfully harsh ride for me. I have 23mm Vitorria’s Open Corsa CX-somethings on one of my road bikes and usually ran 110-120 psi, 95-105 is still more comfortable and not noticably slower. See #2 and #4 above for other very good reasons.
    #930171
    pfunkallstar
    I’ve got Grand Prix 4000’s on mine, weigh about 170 on a good day, and keep them right around 105-110. Haven’t gotten a flat in a while.
    #930360
    Holy sh*t, 150? I run at around 90-110 on Vittoria Rubino Slick 23s most of the time.
    #930370
    elcee
