Map of places to fill a tire?
Our Community › Forums › Bikes & Equipment › Map of places to fill a tire?
- This topic has 6 replies, 5 voices, and was last updated 14 years ago by
baiskeli.
June 13, 2011 at 6:51 pm #926944
CCrew
ParticipantBuy bike. Buy frame pump (or CO2) . Problem solved
June 13, 2011 at 7:21 pm #926948Dirt
ParticipantThat was kinda my thought too. I have had a few times over the last 40 years where my pump died and I needed help. Usually I just accost someone else that I see on a bike.
There are some places that do have compressors or air stations for cyclists along the MUTs. I can think of a few along the W&OD.
June 13, 2011 at 9:59 pm #926974jrenaut
ParticipantI have a pump, but it’s just a little hand pump that probably isn’t going to get the tires up to 120. And I don’t really like the idea of CO2 pumps, I’m not sure why. I have a floor pump that will handle it coming from Amazon tomorrow, but that doesn’t help on the road.
June 14, 2011 at 1:36 am #926976Greenbelt
ParticipantI got this guy — highly recommend. http://www.serfas.com/product_details.asp?ID=503
Fits on the bike with the mount, or in a back pocket of a jersey (sticking out some, granted). Has a extension hose so you don’t snap off your valve stem. Can put your foot on the base and pump straight down for leverage, just like a floor pump. I don’t fill as high as 120, but some reviews I’ve read say it’s doable. Make sure to have the shop convert the schrader to presta setup out of the box — requires a PhD. Jill sells these at Proteus if you’re up in Maryland.June 14, 2011 at 2:44 am #926978CCrew
ParticipantTopeak Road Morph is about as good as it gets for inexpensive and able to do high pressure for a frame pump. The Serfas that Greenbelt listed is also good. Similar designs.
For a shop level pump I have a Joe Blow Sport (cheap but effective) and a Specialized Air Force ($$$). The Specialized is the “go to” pump but either do high pressure well, and I have a bike that takes 160lbs (race tubulars)
I carry a Genuine Innovations pump that also does CO2 when I’m riding.
June 14, 2011 at 3:50 pm #927011baiskeli
If you’re thinking about using air from a gas station, be careful – it’s easy to overinflate and blow out your tire. I speak from experience. It was a long time ago, but I still remember. I had just filled up a few miles back, and I heard a rubbing sound. I looked down and saw the tire bulging fast. I knew what the problem was but it blew up before I could get to the valve and let some air out. That was my last time using a gas station pump.
