@dasgeh 100605 wrote:
I believe the batteries for our Magicshine lights are dying — they only last about 30 minutes. Googling hasn’t turned up any replacements that have the same amperage, voltage and wattage that my current ones have. Thoughts? Suggestions? Can I use ones with different Ah/V/W?
If it helps, the one I have is 4.5Ah, 7.2V, 32Wh
You really only have to worry about the voltage. Amp hours (Ah) is capacity – the higher it is, the longer it lasts. Watt Hours (Wh) is another way of stating capacity – it just multiplies Amp hours times voltage (4.5 X 7.2 ~= 32)
