Kickstand for touring bike?
Our Community Forums Bikes & Equipment Kickstand for touring bike?
  • #913013
    crysb
    Would anyone care to recommend a good kickstand for a bike used for fully-loaded touring? I assume it’ll be a double-legged kickstand, as all the weight from panniers will likely render a single-legged kickstand useless. I know some will argue that a kickstand isn’t worth using since you can just lay your bike down – but it seems like an easier way to stop and get something out of a pannier.
    My bike is a Surly Cross Check, in case compatibility matters.
    All leads are appreciated, especially if it can be ordered through a DC bike shop.
    Thanks!
    Crystal
Viewing 6 replies - 1 through 6 (of 6 total)
  • #964982
    I run a double legged one on my touring bike, but I can’t remember the brand. I’ll check later and let you know.
    #964998
    I have the ESGE/Pletscher Double Kickstand on my bike. I’m running a soma saga, which actually has a mounting plate for a kickstand.
    #965003
    I’ve got the pletscher also. Be warned, it’s a boat anchor–about 1.5 pounds. On a tourer you probably won’t care. It’s a fairly ingenious solution, and does what you want it to do.
    #965006
    Well, back in the day, we didn’t use no stinking kickstand. We used walls. If a wall wasn’t available, we just put our bike (actually the pannier) on the ground and let the rear wheel spin freely.
    #965196
    crysb
    @dbb 46651 wrote:
    Surly has this to say http://surlybikes.com/info_hole/spew/kickstands_on_long_haul_truckers
    Ouch. Good to know. I did a little more reading online and it looks like kickstands and Surlys don’t like to play nice – without a mounting plate for a kickstand, it might be safer to forego it. Another said they bought the Pletscher kickstand but there wasn’t enough space to mount it on the Cross-Check.
    I’ll just keep an eye out for walls, for now. Thanks everyone!
