I’ve decided I need accessories more than a new bike
Our Community Forums Bikes & Equipment I’ve decided I need accessories more than a new bike
  • #912888
    I got back into cycling about 10 months ago – with an old cheapo mountain bike (Roadmaster ultraterrain extreme). I bought a helmet, bell, and mirror.
    After my last ride, Ive decided that Im not really going to become a regular bike commuter anytime soon, and the goal of my recreational rides is less about improving time than about losing weight and improving my riding ability. So there is really no impetus to get a lighter faster bike.
    Based on my own thoughts and some posts here, I have decided to get accessories instead. I need to get lights and high viz clothing (not only to extend rides to dusk and beyond, but to improve my visibility in all conditions). I need a bike computer – not only to check and incentive my progress, but more to improve my cadence, which is probably still too low.
Viewing 15 replies - 1 through 15 (of 38 total)
  • #962865
    Bilsko
    A selection of accessories will certainly help you spend more time on the road; lights and clothing will go a long way to improving ride comfort and safety.
    Cycling computers come in lots of shapes and sizes and you can spend very little money on the basics or several hundred dollars on the very advanced ones. I have two (both Cateyes) and they’re both in the range of $50-$75. They are pretty much the base functionality: they have a small magnet-based data capture device that reads your front wheel RPM, then calculates speed and distance based on you pre-setting what size wheels and tires you’re using.
    Models that track your cadence require another measurement point to capture your pedal spin RPMs – as such they’re typically a bit more expensive and require a bit more work to get set up. I don’t have one of this type, but I know that a few other forum members do so they may want to chime in.
    Cateye does make a handy chart comparing the functionality of all of their models – http://202.215.251.86/data/resources/cc_chart12_usa.pdf
    #962866
    What about tires? If you’re going to be riding mostly on streets and paved trails, some more road-orientied tires will improve your bike’s ride dramatically over knobbies. You don’t have to get anything fancy, but there are tons of options for sportiness, durability, puncture-resistance, etc…If you visit a shop and tell them your priorities, they can help you pick a set that best suits your needs. Also, putting them on yourself is good flat-fixing practice.
    #962870
    PeteD
    Don’t Poo-poo the bike upgrade cost, I learned is that the accessories end up costing more than the bike ever did.
    Cost of a Be-seen light: $15-20.
    Cost of a “Need to see the road because I ride when it’s dark and it’s a new moon and there’s no street lights”: $100-400.
    Cost of a TShirt: $15
    Cost of a Tech Tshirt: $17 at REI
    Cost of a Bike Jersey: $50-120. (Need those pockets – Bike Arlington Jersey at Revolution was $80 when I went thru last month.)
    Cost of Exercise Shorts: $15
    Cost of Biking Shorts: $50-90
    Cost of Biking Bibs: $80-200
    Cost of a Cadence Bike Computer: $40-70
    Cost of a GPS-enabled Cadence/Speed Computer: $200-700
    Then you have to add in the cost of a seat bag, so you can store your spare tube and Bike Arlington repair kit.
    #962873
    Presumably he’d need/want all these things with a new bike, too. Perhaps even more so. So forgoing the new bike for now seems to me like a good option for the occasional cyclist on a budget.
    I’d second the suggestion of new tires, too. Performance usually has a good selection in a range of prices.
    #962880
    baiskeli
    Cost of that Starbucks latte you’re drinking in your photo: $44.50.
    #962881
    thanks for all the suggestions, but Im not enthused about the new tire idea – for one I sometimes need the knobby tires (holmes run trail, Cross County trail, the trail through the park that leads up to Fairview, and the generally gnarly shoulders and service lanes of “downtown” Annandale) – and Im not keen to change tires regularly, or to take up the space. Second, since I am trying to lose weight and get more fit, dont the gnarly tires serve the same as the extra bike weight? Third I do still hope to get a road/commute bike not TOO far off.
    for the clothing, Im thinking some kind of birght colored/biking focused long sleeved jersey or windbreaker as the first priority – I have some bright t shirts, but taste in long sleeves has run more to the subdued. Also it would be nice to be a bit more aerodynamic (despite what I said above)
    And bike shorts, for comfort as well as visibility and aerodynamics.
    Lights of course.
    Computer can wait a bit.
    #962883
    Extra bike weight doesn’t help you loose weight, it just makes you go slower. Instead, just ride faster–wind resistance increases exponentially which should be enough to make you work harder.
    OR, add extra weight AND ride faster.
    #962888
    baiskeli
    I would still change them. You will feel a huge difference most of the time – and not as much of a problem when you’re on those difficult sections. You could get inexpensive compromise tires with some width and knobbiness, just not as much as you have now. Here’s an example (I pulled these off Amazon based on their tread and width; I’m not necessarily recommending them):
    http://www.amazon.com/Kenda-Komfort-Bicycle-Blackwall-1-95-Inch/dp/B002DX1D6W/ref=sr_1_10?ie=UTF8&qid=1361302828&sr=8-10&keywords=bike+tires
    I would think that you’ll get more weight loss out of doing lots of fast riding too. I’ll bet the right tires wouldn’t cost much. Tires are usually the first and best way to make a big change in the way you ride.
    #962889
    Non-knobby != weak. Basically, knobs are for mud. (Not gravel/crushed stone, but mud.) If you routinely ride in deep mud, you’ll need knobs. Otherwise, the knobs just cause rolling resistance and vibration at speed on smoother surfaces, which is unpleasant and fatiguing. You can get a tire that’s just as wide/cushy, but with a smooth tread which is better suited to non-muddy trails and much, much more pleasant and faster on the road.
    #962891
    As the forum cheap bastard, my recommendations are as follows:
    Just use street clothes. Find a reflective vest. When trying to figure your cadence, just count. And… here’s how to save on lights:
    http://bikearlingtonforum.com/showthread.php?1380-The-cheapo-helmet-light&highlight=cheap+light
    Of course the downside is that everyone might laugh at you.:rolleyes:
    #962893
    I might just get a reflective vest.
    Counting – so either check my timepiece every minute, or count pedal strokes for 5 minutes? I lack patience for that. And I think I will splurge on a helmet light, which is at least easy to take from bike to bike (yes I know I also need a rear light)
    #962894
    baiskeli
    How economical of you.
    We laugh at the ELITEs and poseurs and Freds decked out with all the latest expensive equipment too.
    #962895
    KelOnWheels
    I laugh at myself :D With all the lights I have strapped to the front of my bike it looks like I’m going on a deep-sea diving expedition. Of course the day all four of my front lights died on the way home I wasn’t laughing… :P
    But yeah. Don’t faff about with cheap lights, because you’ll wind up spending more on cheap lights you can’t see with than you could have spent had you just gotten a couple of good lights to begin with. Not that they have to be super spendy, just, y’know, decent.
    My Cygolite 350 was $75 on sale I think and it’s AWESOME, whereas my $60 Planet Bike 2 watt is a nice be-seen light but not nearly enough for a seeing-on-dark-trail-facing-GWP-headlights light. It’s a good backup if I forget to charge the Cygolite, but I had already gotten be-seen lights and could have saved the $60.
    #962896
    Bilsko
    FTFY: $47.30
    #962898
    baiskeli
    @Bilsko 44276 wrote:
    FTFY: $47.30
    Holy crap. I picked a ridiculously high price as a joke, and still came up short of reality!
