HRM advice, please
Our Community › Forums › General Discussion › HRM advice, please
- This topic has 34 replies, 15 voices, and was last updated 11 years, 10 months ago by
vvill.
September 5, 2012 at 1:12 pm #912021
ParticipantMy Garmin “premium” HRM “soft strap” is kaputt. I tried changing the battery but it still works very intermittently. A new one retails ~$45-70. A bit ridiculous for something that lasted 6 months. Any other options for something with ANT+? I have a Garmin Edge 500.
April 3, 2013 at 3:12 am #966387
americancyclo
Participant@hozn 48126 wrote:
Also, I just discovered my Garmin hrm was dead (replacing battery did nothing), googled around a bit and tried the advice of taking out the battery and putting it in backwards for 10 seconds to reset the device. Worked like a charm.
At least in my case, the transmitter registers as connected, but its not getting any signal from the strap, so I’ve guessed that the problem is the strap. Maybe ill try calling garmin.
April 3, 2013 at 3:23 am #966388americancyclo
[h=3]
Garmin wrote:A Product Support specialist will respond to you within 3 business days.[/h]
Message Summary
Category:Edge 705
Subject:Premium Heart Rate Monitor (Soft Strap) not workingApril 3, 2013 at 10:32 am #966389hozn
ParticipantYeah, it does sound like a different problem in your case. FWIW, I have had poor luck with email support from Garmin, but great experience calling them. Good luck!
April 4, 2013 at 12:16 am #966518Mark Blacknell
Participant@americancyclo 47777 wrote:
My strap stopped working a while ago, but the monitor still functions. I was going to try out the Polar Wearlink strap that supposedly works with the Garmin HR transmitter.
http://www.dcrainmaker.com/2010/08/solution-to-heart-rate-dropoutsspikes.html
Anyone else tried that yet?
I see that you ordered already, but I’ll chime in to say that yes, I’ve done this, and the Polar strap has lasted longer than any of my Garmin soft-straps. I won’t be buying the Garmin straps in the future (tho’ I have kept one of the old style straps as a backup).
April 4, 2013 at 10:29 am #966539Dirt
I used the new soft strap until it broke, then went back to the old, plastic garmin strap. It has worked perfectly for many years. I think they still sell them.
April 5, 2013 at 1:54 am #966620hozn
Yeah, I have the plastic one too. Other than that need-to-reset incident it has been working without incident for several years now.
April 5, 2013 at 4:48 pm #966706americancyclo
ParticipantI got an email from Garmin Support asking me to read the care instructions and then let them know if the strap still wasn’t working and they would send me a replacement. I also received the Polar Wearlink in the mail. The Polar Wearlink Strap has rubber grommets around the snaps, so the Garmin transmitter won’t stay attached. It pops off without ever really engaging. The options I’ve seen are to cut down the rubber with a knife, or try the Polar Soft Strap. I’ll probably wait to see if I get my free Garmin replacement before exchanging or cutting the Polar strap.
April 29, 2013 at 8:00 pm #968561americancyclo
ParticipantI wanted to follow up that garmin sent me a replacement strap at no cost and it arrived in four days. thanks garmin!
May 2, 2013 at 12:14 pm #968921vvill
ParticipantThanks. I contacted Garmin as well and a new one should be on its way! Soon I’ll be able to again see how much I’m suffering to maintain 16 mph on the way home again
May 15, 2013 at 2:29 pm #970051vvill
ParticipantOne last bump – received my new replacement HRM strap (for free).
It’s worth noting that it is considerably different to the original “premium soft strap” that came bundled with my Edge 500. It’s considerably thicker around the sensor area – there’s actually some fabric to it, and it’s machine washable. So for anyone who’s had the original version break on them: I recommend contacting Garmin about it. I just used their online contact form.
September 17, 2013 at 4:39 pm #981503americancyclo
ParticipantAnd four months later the replacement Garmin strap has stopped working.
I contacted product support again, and they asked me to do the following:When you replace the battery in your heart rate monitor, please ensure that you are doing it following these steps:
1. Remove the battery from the sensor leaving them out no less than 10 minutes up to 24 hours.
2. Put the new battery in
3. Put the heart rate monitor on
4. Go to the Main Menu of the device
5. Navigate the menu’s to the heart rate monitor
6. Turn the monitor from on to off and back to on
7. Elevate heart rate for about three minutes (less if it finds it right away, however for some devices right at the three minutes it will detect the monitor)
8. Select Scan/Rescan or search on the deviceEven after this, I was still getting heart rate data that looked like this:
[ATTACH=CONFIG]3694[/ATTACH]
Then I switched to the Polar Strap that I had bought for $12 and got some good HR data today, like this:
[ATTACH=CONFIG]3695[/ATTACH]I’m going to send the Garmin strap back again, and ask for a replacement, but I’ll probably keep it only as a backup in case the polar dies on me too. I’ll report back in a few months to let y’all know how the polar strap is working out.
September 17, 2013 at 4:53 pm #981506ShawnoftheDread
ParticipantThe first pic looks about right for me. Fine -> moderate jump -> dead.
September 17, 2013 at 5:07 pm #981509OneEighth
ParticipantHe’s a zombie. Always suspected as much.
September 17, 2013 at 5:25 pm #981512Popsicleian
ParticipantMy Garmin strap had me at well over 200 BPM for a significant portion of my ride this morning (a leisurely commute). Somehow I don’t think it’s working properly…
September 17, 2013 at 5:31 pm #981514ronwalf
Mine does that if it fails to get a good connection with skin. Technical clothing and cooler weather seem to exacerbate the problem. Running the HRM under the tap to wet it down fixes the problem for me. They also make HRM gel for the same purpose.
