HRM advice, please
Our Community Forums General Discussion HRM advice, please
  • #912021
    My Garmin “premium” HRM “soft strap” is kaputt. I tried changing the battery but it still works very intermittently. A new one retails ~$45-70. A bit ridiculous for something that lasted 6 months. Any other options for something with ANT+? I have a Garmin Edge 500.
Viewing 15 replies - 1 through 15 (of 34 total)
  • #950420
    I seem to have to replace them every season or so…
    Where did you find just the strap for sale? I ended up getting a new strap and sensor because I could find just the strap by itself.
    This is also a good read: http://www.dcrainmaker.com/2010/04/troubleshooting-your-heart-rate.html
    #950428
    Didn’t actually find just the strap for sale – edited my post, although it doesn’t show up with a edit on the history.
    #950408
    I haven’t tried the old straps with my 800, but I found that they lasted me much longer… I got 3 years out of my old one and it was still going strong when I got my 800. It isn’t as comfy as the new one, but it sure lasted well. If I recall correctly, it was about half the price of the new one.
    #950409
    I tried one of the new garmin straps and it only lasted a few months. I get a few years out of the old style straps. They are cheaper, too.
    #950389
    JorgeGortex
    What I can add, based on Tim’s link to DCRainMaker is that I run my strap under warm water and then smear warm water on my chest where the contacts will rest against my skin. Then I put my HR strap on. I do this before any outing. My HR readings are usually fine. I also make sure my chest strap is fairly tight so I get good contact with the skin. I just wish the Polar straps worked with Garmin products b/c the soft ones are more comfortable than the soft Garmin units.
    I think proper care after use is important to keeping the units working too. I rinse with clean water and dry the strap with a towel before I hang it to air dry.
    JG
    #950395
    americancyclo
    I dunked my old school strap (OEM for the Edge 705) a few months ago, and i think it shorted. whatever it was, it never worked again even a few days later.
    Heartratemonitorsusa has good prices on straps, and you can usually find an additional percentage off code from retailmenot and they offer free shipping. I just put the old school strap in my cart and with a code, it’s only $37.99
    #950381
    PotomacCyclist
    If I can find my old Garmin HR strap, I would be willing to part with it for less than retail price. I only used it for a few weeks, although that was a few years ago. Do HR straps wear out even if you don’t use them? I don’t think so. But then I didn’t think boots would age. (I once had a pair of nice L.L. Bean boots where the heel completely crumbled, like dust. I hadn’t worn them in about a year. When I tried them out again, the heel literally fell off as though it were made of sand!)
    It’s the older version, not the newer soft strap. But it should be in good working condition.
    #950344
    Thanks for the DCRainMaker link (I’ve read it a couple times before). The issues I’ve had seemed to indicate a battery life problem, not something with the contacts, because it would work for 10-15 mins and then gradually taper off to giving fewer and fewer readings and then no readings at all. I do wash the strap regularly, mostly because it gets stinky easily.
    Strangely, my HRM worked fine on the way home yesterday and this morning. I think it must’ve overheard my threat to trash it. We’ll see how long this lasts…
    #966053
    americancyclo
    My strap stopped working a while ago, but the monitor still functions. I was going to try out the Polar Wearlink strap that supposedly works with the Garmin HR transmitter.
    http://www.dcrainmaker.com/2010/08/solution-to-heart-rate-dropoutsspikes.html
    Anyone else tried that yet?
    #966054
    No, but for the price, I’ll probably try it.
    #966174
    SteveTheTech
    Me too.
    My wife has been using the soft strap for a while. I did not see it in the pile of clothes and washed it….never worked right again, (so they appear to be very sensitive to water intrusion). Beside that that is the third one of those I have bought. I am still using the lower end heavy strap model that came with my original Forerunner (working fine for three years, with several new batteries). I have a broader chest (not bragging in any way it just fits me well, where it never fit my wife right) and no problem detecting accurate HR so that strap actually works very well for me, for others though the readings are very erratic or non existent. I washed the cheap one, sweat on it for 10+ hours and swam in it a few times and it still works like a champ.
    I have had more of a problem with breaking the cadence/WSS pickup off mid ride.
    http://www.amazon.com/Garmin-Premium-Heart-Monitor-Strap/dp/B0029M3NSS/ref=sr_1_1?ie=UTF8&qid=1364834316&sr=8-1&keywords=garmin+premium+heart+rate+monitor
    $45/year isn’t too bad if you are a data junkie like several of the people in this thread are.
    http://www.amazon.com/Garmin-010-10997-00-Heart-Rate-Monitor/dp/B000UOD5QM/ref=sr_1_2?ie=UTF8&qid=1364834783&sr=8-2&keywords=Garmin+Heart-Rate+Monitor
    I know my Stravadiction will not let me cheat on Garmin but with the exception of some erroneous GPS trails I have had pretty good luck with my Forerunner 610 and cheapo strap.
    #966179
    FYI–if you already have a sensor that works fine, just replacing the strap can save you 10 bucks: http://www.amazon.com/gp/product/B00305HOWO/ref=oh_details_o05_s00_i00?ie=UTF8&psc=1&tag=651998669-20
    #966192
    americancyclo
    I just ordered the Polar strap ($17) to try with my Garmin transmitter. I’ll let you know how it goes when it arrives.
    #966217
    brownnugen
    I recommend giving Garmin a call. Their customer service is terrific and when I had problems with my HRM, they sent me a new one at no charge.
    #966372
    Also, I just discovered my Garmin hrm was dead (replacing battery did nothing), googled around a bit and tried the advice of taking out the battery and putting it in backwards for 10 seconds to reset the device. Worked like a charm.
