Hills for practicing standing climbing
Our Community › Forums › General Discussion › Hills for practicing standing climbing
- This topic has 34 replies, 24 voices, and was last updated 8 years, 10 months ago by
huskerdont.
August 1, 2016 at 8:58 pm #1055871
AFHokie
ParticipantWould a hill loop consisting of S Dinwiddie St & S Culpepper St off the northern side of S Walter Reed Dr work? Culpepper is a quiet residential street & Dinwiddie is fairly quiet as well. Both are about a 100ft climb over less than a half mile.
August 1, 2016 at 10:07 pm #1055875GovernorSilver
ParticipantWhen I was learning how to ride a bike last year, I recall reading an REI article that said to only stand if the hill is so steep that there’s no other option. They seem to have softened their stance since then – now they say the same things I’ve read on other cycling websites:
https://www.rei.com/learn/expert-advice/climb-hills.html
August 2, 2016 at 12:03 pm #1055878Sunyata
ParticipantThere are several shorter, but still “steep-ish” hills in the vicinity of 31st Street that would probably work for what you are doing in Park Fairfax.
Less steep: Martha Custis from Valley Drive to Preston Road
Less steep: Gunston Road from the bottom of the pedestrian bridge to just past Fitzgerald Lane.
Medium steep: Gunston Road from the Valley Drive intersection towards Chalfonte Drive.
Medium steep: Preston Road from Valley Drive to Martha Custis
Steep: Valley Drive from Martha Custis to Crestwood Drive
Steep: Martha Custis from Gunston Road to Preston RoadThese are all very low traffic roads and can provide a pretty decent workout when looped in with some other neighbourhood climbs in that area as well.
August 2, 2016 at 2:23 pm #1055891MRH5028
ParticipantDepending on how far you are willing to go out, the hill on Hunter Station Road is good. Just head west on W&OD past Vienna, when the trail hits Hunter Mill Road get off and make the quick turn onto Hunter Station. Follow the road around and over the bridge, you will find the hill. Normally low traffic on the road as well. Riding out on the W&OD provides a nice warm up for doing a couple of “Ups”.
August 2, 2016 at 2:31 pm #1055894Harry Meatmotor
ParticipantMt. Ida repeats!
August 2, 2016 at 3:16 pm #1055899lordofthemark
ParticipantSo many hills! Thanks to all.
August 2, 2016 at 3:49 pm #1055900DrP
ParticipantAnd when you are done with all those, you can try 41st N, by Chain Bridge (not marked on all maps, but the bike route for getting to Chain Bridge). This took me many, many tries to even bicycle up the hill, but as long as I am in a good gear, I can bike up the hill now (although I still do not do the little curvy bit at the top since it is often slick with leaves. Yes, really, that is the reason
August 2, 2016 at 3:55 pm #1055901bobco85
Your assigned goal for the remainder of the year is now to ride all of the suggested hills. Make a checklist! 😎
August 2, 2016 at 5:03 pm #1055905Tim Kelley
Participant@lordofthemark 143737 wrote:
I am up for your suggestions.
Here’s a route that incorporates plenty of hills in your area: https://ridewithgps.com/routes/13800756
Both Oxford and 16th are among my favorites for that ride.
August 2, 2016 at 6:39 pm #1055910KayakCyndi
Disappointing. I was sure that was going to be a Kill Bill link!
August 2, 2016 at 6:44 pm #1055911lordofthemark
ParticipantJust to remind everyone, the target climb is 0.3 miles, at at an average grade of 5.6 percent, for a total elevation gain of 108 feet. You really don’t need to find me climbs that are longer and steeper than that, but thanks!
August 3, 2016 at 2:46 am #1055934hozn
ParticipantHonestly, you don’t even need a hill to work on riding-out-of-the-saddle form. Just put it in a high enough gear. Or Dismal’s suggestion.
My son rides almost exclusively out of the saddle on our flat street. I guess he’s working on form; I think he just does it to annoy me now
(I have been unable to convince him that there is value in using gears lower than “10”.)
August 3, 2016 at 2:58 am #1055935TwoWheelsDC
ParticipantThe best solution, of course, is to start riding a fixed gear bike fitted with no fewer than 75 gear inches. You’ll actually have to work up to being able to stay seated!
August 3, 2016 at 11:39 am #1055939GovernorSilver
That’s similar to the climb to my house – 0.2 miles, 100-ish ft. elevation gain. Only difference is the gradient range: 7-9.5%.
The steepest section is just coming off the street – I’ve had the tendency to stand there, then downshift and pedal seated when standing gets too tiring, which coincidentally is past the steepest section. The one night when I climbed most efficiently was when I never stood – just steady pedaling. I might have had 2 drops of sweat from that climb and was breathing comfortably. I usually sweat buckets and am out of breath.
August 3, 2016 at 1:04 pm #1055940Anonymous
GuestI like about a 2-3% grade to practice standing on. Just enough of a slope to feel like the bike is headed “upwards” and change my position on the bike a bit, but gentle enough that when my legs get tired and I sit and drop into an easy gear, it is actually easy.
