Help on bike buying, part 2
Our Community Forums Bikes & Equipment Help on bike buying, part 2
  • #914224
    Okay so I still haven’t bought a new bike.
    But I’ve now commuted four times, ridden a lot more than that, and read some stuff here and elsewhere. So I think I’ve learned something, but still want helpful tips.
    I will try to isolate some issues.
    1. Test ride bikes – yes, I know thats going to be the key and I haven’t done much yet. I resolve to do so.
    2. New vs used – I expect to look at both. I think a better deal can be had used, but I’ve seen tempting sales on new. If I get used, it will be from a shop – I do not know enough to try any refurbing myself.
    3. Needs – I want to make it mainly about my commute. If I can manage weekend rides on my old low end mtb, I can probably manage them on whatever I get to commute. and then someday I can get ANOTHER bike for weekend rides, right? My commute is a mix – well paved roads around the pentagon, trail through LBJ grove, MVT and 14th street bridge, sidewalks to Water Street, Water Street itself, and the Eye street bike lanes (terribly “paved” for now).
    4. I want upright handle bars. I think I want 26″ tires. I want a rack and fenders – and maybe a chain guard? I want something I won’t have to fix on the way to work. I want tires that are less knobby than my old MTB’s. The center ridge thing? I may want a step through – I am less than 5’6″ tall and often find a diamond frame uncomfortable, and at least so far I stop a lot. I am pretty sure I want flat pedals (IE I want to be able to ride without special footwear)
    5. I think this means I want a hybrid, maybe one of the bikes marketed as city or commuter bikes.
    6. The Novara Transfer I saw before struck me as a possibility – but I need to test ride it. Although it lists at $700, it seems to be on sale at less than $400 at REI pretty regularly. I am at least mentally using that as a standard to compare to.
    7. My local LBS sells used, but is tiny. I will look there. I should probably look at Phoenix bikes. I will go back to REI, to test ride the Novara. Of the local stores that are more focused on new bikes, which would come closer to my needs and price range?
Viewing 15 replies - 1 through 15 (of 30 total)
  • #982115
    Guus
    One thought to put in the mix: take a look at bikes with a hub dynamo. They are great to give you excellent light without the need for battery. Especially useful if you are commuting in any type of traffic.
    It’s difficult to put a hub dynamo on an existing bike. I mean it’s possible but it’s not the type of thing that you can easily upgrade your bike with.
    #982116
    FFX_Hinterlands
    Finding a used bike with fenders and a chainguard is going to be difficult.. they are all cruisers for the most part. Check out Bikes for the Rest of Us for ideas on bikes like you describe. (disclaimer, I contribute to BFROU).
    I have a bike that exactly fits your description, but it is heavy and a three speed (Torker Cargo T). Probably more heavy duty than you need.
    #982123
    I think you will find a much bigger selection if you go with 700 C wheels. It is hard to find relatively narrow tires that go to high pressure for 26″ wheels.
    I suggest you look at flat bar road bikes with 28 mm tires as they may be substantially lighter than other hybrids.
    #982125
    Bikenetic stocks the Kona Dew for around $500 new. Fits most of your parameters, easily takes fenders and rack, and is a fairly light hybrid.
    #982127
    PotomacCyclist
    Bike and Roll has a sale on Oct. 20, from 11-3, at their Old Post Office location. Trek hybrid for $280. Road bikes available too.
    More info at bikethesites.com.
    FYI – The Army Ten-Miler takes place that day. Many roads along the Mall will be closed for the race.
    EDIT: Link to the press release: http://bikethesites.com/Press-Releases/bike-and-roll-s-fall-2013-bike-sale
    (I was using a smartphone before. I haven’t figured out how to copy and paste a URL on the phone.)
    #982128
    $650 for a Trek 1.5 seems like a decent deal… May have to look into that for the wife.
    #982142
    Light is good – as that would help me on hills and bridges. Would such a bike be less comfortable/more likely to need repairs when ridden on poor pavement, up curbs, over gunk, etc?
    #982144
    $500 is a bit more than I want to spend now, but it definitely sounds like I should take a look at that.
    #982145
    If I buy from bike and roll, they don’t offer the same service as a shop would, right?
    How would you compare the Trek 7300 to say the Novara Transfer? Lighter, I guess?
    #982147
    KayakCyndi
    Another plug for Bikenetic is that they offer free lifetime service on bikes purchased from them. That will save you $$ in the long run if you don’t do your own wrenching.
    #982148
    Look at the welds. This past summer we bought a new bike for my son. We went to REI to try out the cannondales. But we also tried out the novaras. First, the welds on the novaras were down right sloppy. Second, it just was not a comfortable ride. My son test road it for seconds before he got off it and said no. In the end it was a choice between the Trek 1.3 (or 1.2 I dont know) and the the Specialized Allez. In general, the Treks were excellent bikes. A quality brand.
    Just in terms of brand, I would take Trek over Novara.
    #982158
    Comfort–It depends on how you personally define comfort
    Durability–Should be the same durability. If you are worried about riding on poor pavement, just don’t go for low-spoke count wheels (and that matters more the heavier you are).
    #982161
    If you want comfort and durability, make sure you have sensibly-sized tires–that will matter more than anything else.
    #982164
    My wife has a Trek 7300. It’s a heavy aluminum hybrid with 3×8 gearing, so-so components, a lightly suspended fork and 35 mm tires. She doesn’t like it.
    The Novara Transfer is a steel bike with an 8 speed internal hub. Apparently, it weighs 36 pounds. That is HEAVY.
    I would look for something with specs like these:
    http://www.bikesdirect.com/products/motobecane/cafe_latte_x.htm
    It may be difficult to get bikes with better wheelsets in your price range.
    #982165
    NicDiesel
    You can’t go wrong with a steel road or cyclocross bike (think Surly Cross Check, Salsa Casseroll, Trek 520) or an old ’80s steel racing bike (Raleigh, Trek), frame wise for a commuter bike. I’m a super heavy rider (350+lbs) and ride about 80 miles a week on a Surly Cross Check with a stock 32h front wheel and a 48h rear wheel. Outside of replacing the chain at 5,000 miles and upgrading the cassette and saddle, I’ve had zero problems. If you’re a heavier ride (250+lbs) I’d try my best not to hit pot holes or drop off of curves, but normal street riding shouldn’t be an issue if you have a decent wheel set.
    In the spirit of full disclosure, my rear wheel was pretty expensive (~$700) but it’s a Phil Wood 48h hub ($420, should last for 20 years) and Velocity Chukkar rim (~$90, perfect for bike polo and super heavy riders). After well over a year of riding it hasn’t needed to be trued or repaired yet and probably won’t for another 10,000 miles.
