Help needed regarding inner tube valves
Our Community Forums Bikes & Equipment Help needed regarding inner tube valves
  • #919210
    I got a flat today. And when I went to REI, they said they didn’t have a tube that would fit my wheel. I’m trying therefore to order new tubes online, but am having trouble figuring out exactly what I need.
    The problem is that a Presta valve is too small for the hole in the wheel. However, a Schrader valve wrapped in rubber, like the one on the left, is too large. What I need is a plain metal Schrader valve, like the one on the right:
    [ATTACH=CONFIG]14350[/ATTACH]
    The tube that got a flat–which had the correct type of valve–was a Specialized. But I’m not sure whether all Specialized tubes have that design, or whether there is some particular model I need to ask for. Does anyone know?
    Of course, the next question is why someone designs a wheel that only works with a tube you have to special order. But that’s a rant for a different day.
Viewing 4 replies - 46 through 49 (of 49 total)
  • #1068636
    n18
    I ran into the same problem and I was able to fix it without getting new tubes or drilling wheels. I was only able to get the top part in, part of the rubber around the valve was sticking out microscopically. I tried again and pushed hard, while trying to rotate the valve around, and it worked. Here is something for you to try: get an electric tape or a piece of paper or sheet of plastic, and wrap it around the valve, essentially making a cone like the following picture:
    [ATTACH=CONFIG]14431[/ATTACH]
    This should get the rubber part through the hole.
    #1068643
    Rod Smith
    @cvcalhoun 157614 wrote:
    By preference? Or because that’s the wheels available?
    Wheels available. My trailer wheels prefer Schrader. My pump has dual head. Carrying a 26in Presta spare and a 16in Schrader. Oh and running 26in tube in the front, 700c in the rear. Really should change that rear tube. :p Bound to fail at a bad time.
    #1068644
    Rod Smith
    Ive widened valve holes with a flat head screwdriver. One that is narrow enough to get part way in but not all the way. Insert and twist. Necessary to clean rough edges afterwards (de-burr).
    #1069282
    So apparently I am still riding with Presta tubes in Schrader drilled rims. Re-discovered it today when I swapped in a different tire on my 26″ bike which I never flat on. I’ve been using the Wheels Mfg adapter thingy, but I can understand why you may not want to have to remember that for a trailside flat – it just dropped out when I pulled the tube, having totally forgotten about it.
