GPS Navigation Class at Freshbikes Dec. 9, 11 or 12.
Our Community › Forums › Bikes & Equipment › GPS Navigation Class at Freshbikes Dec. 9, 11 or 12.
- This topic has 19 replies, 9 voices, and was last updated 11 years, 4 months ago by
KayakCyndi.
December 9, 2013 at 12:37 am #987942
JimF22003
ParticipantWhat do you know about replacing the battery on the Garmin 800? I see batteries available on the web but some information indicates you need a special tool, or you have to view a special installation video (??) My unit gives out after about 75 miles now if I’m following a route, especially if I have the map visible. Mine bit the dust on the way home from the cider ride on Saturday, so I have no official proof that I made it a 93-mile ride that day
December 9, 2013 at 1:35 am #987955Dirt
How many hours were you riding?
My 800 is good for almost 12 hours if I don’t stay on the map screen. It drops to about 9 if I’m on the map. I solve the problem by using a back-up battery when the battery gets low. Charge it on the go. Garmin makes a nice one. I use the single cell battery from Exposure. It takes an adapter to plug into a micro USB, but it can also recharge my lights.
You can send it back for a refurb, but there’s no guarantee that it will last a lot longer.
December 9, 2013 at 10:54 am #987975JimF22003
Mine used to be too. I only used it for about 5 hours on Saturday before it died. I was using the nav, but wasn’t showing the map that much. The battery has just started lasting less and less for the last few months. Other than that it still works fine, so I’m reluctant to upgrade.
I guess I’ll go for the refurb, or take a shot at the replacement batteries available. I’m hesitant to take a crowbar to the back of the unit, or whatever it is you have to do to break into it to change the battery.
December 9, 2013 at 2:33 pm #987983Tim Kelley
ParticipantAre you running the screen on, with full brightness? That makes a huge difference. And running guidance (big white arrows) is also more draining that just having the course map up and following the lines.
How long does it work if you are just out riding and recording?
December 9, 2013 at 3:39 pm #987987JimF22003
ParticipantIt’s about 75% brightness. If I’m following a course, I don’t usually even have the map showing. I just rely on it telling me when there’s a turn coming up. The only time I use the map to actually find my way around, is when I’m lost
I really had no problems with the battery life until a few months ago. I’ve gone as long as 10 hours while following a route before, and longer if I’m just using it to track data. I think it’s just getting worn out.
I went ahead and ordered a replacement battery. It looks like the “special tool” required is just a screw driver, which is included.
December 9, 2013 at 5:41 pm #988016Dirt
ParticipantDue to weather concerns, tonight’s session has been moved to next week. I’ll update the original posting.
December 16th at 6:30pm for the Mosaic session. The other sessions this week will still go off as planned.
December 11, 2013 at 8:07 pm #988242Dirt
ParticipantThe first of these sessions is tonight at the Arlington shop. We’ll start up at 7pm. Look forward to seeing you there!
3924 Wilson Blvd
Arlington, VA 22203Thanks
December 16, 2013 at 3:11 pm #988682Dirt
ParticipantGPS Nav Clinic at Mosaic tonight! Hope to see some of you out there. Should be fun. We’ll likely go for a beer at Matchbox after.
December 26, 2013 at 12:08 am #989218KelOnWheels
ParticipantI missed the classes…
But Santa brought me an Edge 500!
I’m just setting up the pages and I liked the look of this setup someone posted on Bikeforums:
Page 1- Instantaneous Data
– Current Speed
– Training Time
– Distance Traveled
– Current Cadence
– Current Heart RatePage 2 – Averages and Sums
– Average Speed
– Average Cadence
– Calories
– Heart Rate Zone
– Average Heart Rate
– Heart Rate % MaxPage 3 – Conditions
– Time of Day
– Temperature
– Total Distance ( i know I have it here too )
– Total Ascent
– Grade
– ElevationWhatcha think?
I’ve already discovered that the user manual is really not helpful.
December 26, 2013 at 9:05 am #989234JimF22003
ParticipantNice!
I max out the first page, including temps, elevation, total ascent, grade, heading etc., and then don’t use any of the other pages.
I need to use bifocals in order to read the tiny little print though…
December 26, 2013 at 12:02 pm #989239Fast Friendly Guy
Whatcha think?I’ve already discovered that the user manual is really not helpful.
Hi Kel,
I find that ‘heading’ is very satisfying to display (cardinal compass points not degrees) Most weather sources show wind direction this way.
DaveDecember 26, 2013 at 1:15 pm #989243rcannon100
ParticipantYou young people.
Page 1: Speed + Distance
Page 2: Speed + Temperature
Page 3: Speed + Time of Day
Translation: The Garmin is set on the old people, large type edition. Two fields per page means I can actually see the numbers as I am riding.
December 26, 2013 at 3:42 pm #989250ShawnoftheDread
Participant@rcannon100 72691 wrote:
You young people.
And that you’re constantly taunted by the speed display.
December 26, 2013 at 5:02 pm #989259vvill
ParticipantIf you use HR you can show a little graph of your HR which is kinda nice.
December 26, 2013 at 8:34 pm #989269JimF22003
ParticipantP.S. I’m a “north up” guy on the map, and not a “track up” guy. I like the subtle sense of confusion I get when I think I’m heading one way, and the map tells me I’m nuts…
