Our Community Forums Bikes & Equipment Going from a triple to a double – what don’t I know?
  • #919086
    My “I don’t have the kids but the fixie is impractical for this ride” bike is a 2013 Bianchi Volpe. It came with a triple up front – 50/39/30.
Viewing 15 replies - 106 through 120 (of 158 total)
  • #1069784
    @vvill 158934 wrote:
    47-15 works ok
    That’s over 80 gear inches. That might work for me on the moon, maybe.
    #1069786
    it’d be fine on Hains Pt if it’s not windy, and Two Sisters is short. just go hard for 30 secs, wheeze, and repeat.
    #1069787
    I hadn’t ridden Two Sisters westbound for a looong time until last week; I was amazed how steep it is going that way. At my best I’d keep it to 70gi. You’re a beast for going after it at 80-something.
    #1069791
    Now that you’ve gotten me curious, my previous PR on that segment was fixed (46X16 or about 77 gear inches).
    #1069792
    I have found rather little correlation between PRs and equipment. (At least when we’re comparing loosely comparable systems.) . I have found a very strong correlation between riding a new bike/build and PRs, though.
    #1069795
    It is surprisingly steep when you’re not feeling energetic. But at least it’s short.
    Ok I have to admit here that I haven’t actually ridden it with that 80+ gearing. Though I have done 48×16 on it plenty of times – and I’m sure Dirt and OneEighth have as well.
    #1069798
    EasyRider
    Dang. I don’t think that’s supposed to happen. (BB explosion)
    #1069805
    Neither did the bike shop. It had about 5,000 miles on it, so not new but by no means ancient.
    #1069807
    Upgrading to external-cup BB is probably worth putting on the list. Probably makes sense to decide if you like 1x and then, if so, just get one of the SRAM 1 cranksets. Looks like Apex 1 cranksets are around $100 (when you include the BB). Looks like they also use a new chainring BCD “standard”, though !?? Maybe SRAM didn’t like Shimano having all the fun making up new standards.
    #1069808
    EasyRider
    Upgrading to external BB — for performance gains/compatibility with more advanced cranksets, not durability, right?
    #1069811
    Harry Meatmotor
    external cup BBs are more durable. larger diameter bearing = more ball bearings = loads are spread over more bearing surface. they also place the bearings further outboard from the BB shell which puts less axial load on the bearings. Also, to run any type of “modern” crankset, i.e., anything post-Shimano Hollow Tech, you’ll need outboard bearings.
    #1069812
    Aesthetically, I strongly prefer the internal BBs. Not sure the benefits of an external would be worth it to me.
    #1069814
    EasyRider
    Yeah, I get the compatibility with modern parts, and figured with larger bearings, durability should be better. But in practice, doesn’t having the bearings outside the frame expose them to grit and grime, especially off-pavement, and make them go kaput sooner? Kaput meaning rough and unpleasant feeling, not necessarily failure like the above picture?
    #1069815
    Agree to disagree on this point!
    #1069816
    It’s a subjective opinion for sure
