Our Community Forums Bikes & Equipment Going from a triple to a double – what don’t I know?
  • #919086
    My “I don’t have the kids but the fixie is impractical for this ride” bike is a 2013 Bianchi Volpe. It came with a triple up front – 50/39/30.
Viewing 15 replies - 91 through 105 (of 158 total)
  • #1069337
    @jrenaut 158456 wrote:
    Ha, I know, it’s filthy. Freezing Saddles! No time for bike cleaning.
    You’re not riding it now…….
    #1069338
    I’m busy now
    #1069346
    @jrenaut 158454 wrote:
    I have a 44t narrow wide coming to the Bike Rack tomorrow. For now I might just put the old big ring back on, but going forward I think I need a chainguard. Anything I should know about chainguards?
    Are you getting a clutch RD? If so, you shouldn’t need a chain guard. If not, then you might want something if you expect to.ride over rough terrain (or potholed streets). When I ran 1x on the MTB pre-narrow-wide, I used a Drop Stop chain cather for inside and a bash guard in 2t larger size for the outside (e.g. a size-34 bashguard with my 32t ring). I may have had some rub of chain on bashguard in the small cogs/high gears. I would probably run without a bash guard/chain guard and see how it stays on even without a clutch RD.
    #1069348
    It’s not that I’m worried about dropping the chain, it’s that I want to use the single narrow-wide without changing out the triple.
    #1069349
    Yeah, that won’t be a problem. You just need shorter chain ring bolts. Or the SRAM 1x rings come with washers/spacers that allow you to use your 2x bolts with a single ring. I have always used a double crankset (which is same as a triple crankset as far as how the middle and outer rings attach) with 1x rings. (For my setup a double crankset makes more sense because the chain line is more correct for 135mm rear spacing, but for you a 1x would be correct chain line for the 130mm rear. Probably mount the narrow-wide ring on the inside of your crankset — where your middle ring used to be — if it will clear the chain stay.)
    #1069769
    So 1X10 seems to agree with me – inaugural ride and I PRed Hains Point and the Two Sisters, along with some other segments I’ve ridden a lot.
    #1069772
    Less weight and complexity…so by this logic, you can upgrade your Cat if you go 1×1 fixie, amirite? ;)
    #1069773
    If you find me a gear ratio that works well for Hains Point AND the Two Sisters, I’m all ears.
    The bike is lighter than usual – I took off the rack and fenders and haven’t put them back on again yet.
    #1069774
    Judd
    Drop the drivetrain completely and turn it into a strider bike. Fast fast.
    #1069775
    Forgot I have more pictures to share.
    Here is an example of a bottom bracket that needs replacement.
    IMG_20170415_161836973 by Jon, on Flickr
    When TwoWheels and I took it off, the bearings and lots of shards of metal flew everywhere. It was awesome.
    #1069776
    And here’s the finished product, though without the rack and fenders.
    IMG_20170423_155501456 by Jon, on Flickr
    #1069778
    What was the solution to your chain drop issue?
    #1069779
    Didn’t have the quick link closed fully so I could still take it off in case the length wasn’t right. In hindsight, it should have been totally obvious that this would make the chain pop off. At least now I know for next time.
    #1069780
    47-15 works ok
    #1069781
    @vvill 158934 wrote:
    47-15 works ok
    “ok” is not “PRing both segments in one ride”
