Garmin Edge Battery Life
Our Community Forums Bikes & Equipment Garmin Edge Battery Life
  • #915411
    I thought we might have had some discussion on this earlier, but I can’t find it. The short story, my Edge 500 battery died during the Tour de Cure yesterday. It was fully charged as of Saturday evening and had been on for just under 10 hours. I was using it to both record the ride and to follow the course (shown by a line). The unit is almost four years old and only other time I had gotten a low battery warning was after the 2012 Total 200 as I was riding home, and the unit had been on for over 15 hours, but I was not using it to follow a course track.
    Does anyone have any experience with this deterioation of batter life? Is it worth it to replace the battery, or should I just use this as an excuse to upgrade (too bad I missed the short lived special REI deal on the 800 bundle)? I’m signed up for the Total 200 in two weeks and don’t want to miss recording half of the ride. After all, I don’t get Strava credit for manually entered rides. :p ;)
Viewing 15 replies - 1 through 15 (of 16 total)
  • #1003040
    DaveK
    You won’t be able to expect more battery life from an 800 if you’re following a course. In fact, probably less. This track ended at just over 10 hours of on time because my battery died – http://www.strava.com/activities/137558154
    Most of the Total 200 idiots I know (and I mean that in the nicest way) use the Garmin backup battery.
    #1003042
    Brent
    I say upgrade. I’ll even buy your 500 for Kim.
    I got the 510 after I lost my 500, and I’ve been happy with the battery life so far, even when connected to my phone over Bluetooth for live tracking.
    #1003043
    Yeah, I get the claimed 15 hours on my Garmin 510, even with Bluetooth. (I don’t use the LiveTrack feature very often; the one time I did my phone died after 8 hours, so haven’t really tested the limits there.)
    The battery life is a great reason to upgrade, though I think the satellite sync/lock speed and BT sync with phone are even better reasons. I love just plugging in the Garmin once a week (to charge).
    #1003044
    Will the 500 take external batteries while running? The 800 will, but not sure about the 500. They charge off USB so external batteries are easy to find.
    My experience is that the 800 would last 13 hours or so when new (which was the longest ride I ever did with it, and it was about dead when I got home). All Li-ion batteries lose capacity as they age, so it wouldn’t surprise me if it didn’t last as long today.
    #1003045
    Brent
    The 500 won’t let you plug in an external USB battery while it’s going (unless the firmware has changed since I had it). The 510 will let you continue using it off an external battery.
    #1003046
    There are a couple of BikeForum.net threads on external battery. One claimed it did work, another that it did not. I’m not sure I want to plunk down $90 with Garmin for theres, but the AA version from Gomadic is tempting at $20.
    #1003048
    You should be able to check it by just plugging it into any USB charger while its on.
    And Amazon is littered with USB external batteries. You shouldn’t need to spend a bunch.
    #1003049
    I haven’t been able to get the 500 to use an external battery and run at the same time. I have a Monoprice external USB battery.
    My original 500 from 2012(?) doesn’t work as well as it should (GPS track deviates regularly, freezes up occasionally), so I bought a used one for $100. I have run both on some rides – for long ones I just turn the backup one on after about 6-8 hours so at worst you’ll have two overlapping rides (you can then trim on Strava, or merge the files some other way.) I think a spare Edge 200 would be fine for just the GPS tracking part if you don’t care about ANT+. I want to upgrade to a 510 though…
    I don’t use the course feature on the 500 anymore. I’ve used it maybe for 10 rides, and had it crash enough of those times that I stopped bothering with it.
    What jabberwocky said about batteries though – 4 years of recharging and near daily use has probably taken quite a toll on your Garmin’s battery.
    #1003066
    Make sure to turn off the screen backlight to save on battery too. In full sun it’s hard to tell if it’s on, and it drains your battery just as much as running the nav…
    #1003071
    americancyclo
    Tim, didn’t you have a tip about loading up the map, but not starting the nav to save battery?
    #1003072
    When you select the course, you have the option of turning on turn by turn style “turn guidance.” I think that I’ve found that keeping that off and just following the little red line on the map saves battery. Anyone else had similar results?
    Also, I use this: http://www.amazon.com/gp/product/B002FU6KF2/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1
    #1003113
    PotomacCyclist
    I think all rechargeable batteries eventually lose their capacities after many charge, drain and recharge cycles. I don’t have an Edge but I’ve noticed that my Garmin 305 battery doesn’t last as long as it used to. Even if I charge it fully the night before, I’ve received Low Battery warnings after just 2 or 3 hrs. on the following day.
    If I haven’t used it in a while, the battery seems to drain quickly, even when off. Then when I use it again (without recharging), the battery charge runs out in less than an hour.
    I’ve had the 305 since 2009. Definitely overdue for an upgrade of some sort. (I also use the 305 for running. Because it’s still kind of heavy and awkward for running, I might get a thin and light running Garmin and a separate bike Garmin in the future, when it fits in the budget.)
    #1003119
    ronwalf
    You can replace the battery in the Edge 500 with a little handiwork:
    I’ve never done it, but it looks easier than most cellphone repair jobs.
    #1003467
    Phatboing
    This is kinda what I was doing during the NoVA Epic, but I took the idiot route of turning on navigation, yelling at the Garmin for being dumb, and then ignoring the navigation cues and just following the damn line. Except the little red line on the Edge Touring is purple. Bug or feature?
    #1004195
    Just a short update on my situation. I decided to just get a new Edge 500 as the cheapest option (got a good deal), since I don’t use a smartphone, several features on the 510 weren’t worth an extra $150. I also noted that the 500 claims an 18 hour battery life compared with 15 hours for the 510, 800, or 810.
    On Saturday’s Total 200, I did not use the course routing function and the gps was on for just over 15 hours. When I plugged it in to recharge it still showed at least 25% battery life left.
