Fixed gear ratios
Our Community Forums Bikes & Equipment Fixed gear ratios
  • #916020
    My bike, I believe, is 46/18. I’m thinking I might need something a little different. I’m getting used to a higher cadence, but I’m still very slow at a cadence that is borderline uncomfortable. I don’t want to make a huge change because I do still have to get up a hill to go home from pretty much anywhere (shockingly, Columbia Heights is on a hill).
    What ratios do you all use?
Viewing 15 replies - 76 through 90 (of 94 total)
  • #1020917
    dcv
    All kidding aside, finding the right FG gear ratio is a matter of personal preference and the type of rides you plan to go fixed. I have two scenarios:
    – A gear to climb the toughest hill (41st St)
    – A gear to keep up on medium pace group rides
    I’d suggest you figure out a few preferred gear ratios, then build a bike for each.
    I prefer 165 – 170 mm cranks (spin to win).
    #1020922
    @Raymo853 106111 wrote:
    Driving to go ride, ugh.
    If you don’t want to drive to ride, you could get one of those newfangled bikes that have multiple gears…
    #1020947
    OneEighth
    I’m with dcv on crank length. Shorter cranks also leave me less worried about pedal strike in the corners.
    As for ratios, it’s good to see what others are doing, but whatever works best for you is what’s best for you.
    And, honestly, what feels about right today may not work tomorrow. This time of year, 48×16 on the steel bike can feel like a slog. Come Spring and Summer, it will feel right. I’m just not in the mood to switch out the cog and chain.
    #1020959
    Raymo853
    Don’t worry, to prove my hypocrisy, I plan to drive to Leesburg Saturday morning to ride my geared road bike around out there. Hypocrisy is not just the name of a mountain range in Turkey.
    #1020974
    That looks like a perfect route to ride out to ride … And you’ll even have gears and a road bike! Or is it that you are riding your MTB 55 miles *and* doing Snotcycle? That would be a different story.
    #1020976
    dcv
    A few of those roads are gravel, but they’re the “new” type of gravel that pretty much seem paved. So disappointed the last time I was out there.
    #1020979
    See you there!
    #1020986
    Wait wait, did they pave some of the gravel grinder roads out there??
    #1020988
    dcv
    Old Wheatland and Old Waterford almost seem paved now. Furnace Mountain Rd was still gravel two weeks ago. Not sure about Piggot Bottom Road.
    #1020991
    Rod Smith
    Chip seal :(
    #1020992
    I did Furnace Mountain for the first time this past fall. Didn’t realize it was gravel; the 23mm tires got some exercise.
    I am sure the residents appreciate the improved surfaces.
    #1021043
    DaveK
    A lot of them don’t want the improvement – http://www.washingtonpost.com/local/loudoun-wants-to-keep-its-historic-potholed-gravel-roads-unpaved/2014/02/14/ccdda5e0-94c8-11e3-84e1-27626c5ef5fb_story.html
    #1021049
    No, not Old Waterford!! :(
    #1021051
    Raymo853
    No I am not doing Snotcycle and I suspect I will not get there early enough to see much of the race.
    #1021056
    Subby
    @Rod Smith 106199 wrote:
    Chip seal :(
    We better get back out there and do our li’l old route again before everything is paved.
