Fixed Gear Ratio of Choice?
Our Community › Forums › Bikes & Equipment › Fixed Gear Ratio of Choice?
- This topic has 21 replies, 11 voices, and was last updated 12 years, 4 months ago by
vvill.
September 17, 2012 at 2:25 pm #951259
ParticipantMy old fixie was 44-16. My two current ones are 46-17 and 48-18.
September 17, 2012 at 2:36 pm #951260OneEighth
Participant48×16 on the steel frame with high-pressure 25’s.
48×15 on the alu frame with higher pressure 23’s.
48×20 on the steel frame ride-to-the-market in sandals on swishy 35’s.Might go to 48×17/18 if I start regularly using cross tires, but, honestly, I think 48×16 is just about right for most riding in this area. Low enough for most climbs (not Kill Bill) and high enough to comfortably cruise between 18 and 22.
September 17, 2012 at 3:57 pm #951289Dirt
ParticipantFor endurance rides on Big Pink I have come to enjoy 48×16 with 23mm tires. I liked it so much that I even use it for commuting if I’m not hauling too much stuff in my pack.
My fixie touring bike is currently 48×18 with 40mm tires. I haven’t done the roll-out on that one yet, but I think it is remarkably close to what I run on Big Pink. While it is good for around town, it is a little tall when the panniers fill up. I get moving pretty darn slowly going up West Street in Falls Church with 20 or 30 pounds extra weight on the bike.
I’m in the process of setting up a Dingle drivetrain on the touring bike so that I can ride 44×17 with 700x40mm tires for normal commuting and light loads, and drop to 42×19 when I’m loaded down or pulling a trailer.
Surly makes the Dingle cog: http://surlybikes.com/parts/dingle_cog
FSA makes DH chainrings in 42t. Salsa makes chainrings in 44t.It takes few minutes to change gears (loosen rear wheel, slide forward, move chain, tighten rear wheel, smile). I think it will be a good set-up. Hope to have that rolling in the next week or so.
September 17, 2012 at 4:45 pm #951300mstone
So, basically, it’s the slowest derailleur ever?
September 17, 2012 at 4:59 pm #951305Dirt
No. The derailleur on my fat fixie mountain bike is slower. I have to remove the rear wheel, turn it around backwards and then put it back on again. Takes me 2-3 minutes total. It is a little faster if someone can hold the bike up for me while I do it.
September 17, 2012 at 5:00 pm #951306Dirt
By the way… for off-road, I run 34×17 with 29×2.4 tires for mellow, rolling trails and 34×19 with 29×2.4 tires for more challenging stuff.
September 17, 2012 at 5:19 pm #951316dcv
Participanti’m more like Jason and Jabberwocky in gear ratio preference (spin to win). 1/8 and Dirt – you guys are riding pretty tall gears.
Cinelli 48×17 (74.26 gear inches)
Scott 48×17 (74.26 gear inches)
Lemond 46×17 (71.17 gear inches)
Motobecane Cx 38×16 (62.46 gear inches)
Fuji single speed 53×19 (73.36 gear inches)check out all city’s gear inch calculator: http://allcitycycles.com/index.php/site/calc
September 17, 2012 at 5:22 pm #951317bikesnick
Participantmy fg came with 46×18 (~68 gear inches) and 700×25 tires. it has been fine everywhere (w&od, custis, mvt, capital crescent, dc streets, arlington streets, etc).
September 17, 2012 at 6:06 pm #951326Bilsko
ParticipantI’ve got a 48×18 setup on my steel frame (running 23s).
Now that I have some drop bars on it, I’d like to step it down to 48×16 or so for a little less spinningSeptember 17, 2012 at 10:23 pm #951356Jason B
ParticipantDang, a lot of big chainrings in this neck of the woods. But it is funny, once you start googling different ratios, you will get 15 different answers for the same ratio. I have had 3 different fixed gears and all have been 42/16, so I know no better. I have a 42 crank and a 16cog poised for the new build. I don’t want to change the chainring for it is a pain and cost more than tinkering with a different cogs. Might have to go to 42/14 to get a feel what you guys are cranking.
September 17, 2012 at 11:55 pm #951362dcv
42×14 gives you almost 79 gear inches, but you will only have 1 skid patch. maybe it won’t matter, it would be hard to skid with such a big ratio.
…or you could just use brakes.September 18, 2012 at 12:05 am #951363Dirt
ParticipantI have slowly stepped up my gearing as my distances got more. I rode 46×16 with 23mm tires for quite a while, but found when I got up over 70 or 80 mile rides, My legs just got dogged trying to spin over the gear at high RPM. I gave into the god of mashing and stepped up. I did 6 rides over 130 miles with the 48×16 this year and I’ve pretty much come to the conclusion that it is the ideal gearing right now. If I lose another 10 pounds, then I’ll drop to 15 and still be able to honk up the hills.
September 18, 2012 at 12:40 am #951365Rod Smith
ParticipantI don’t know much about fixies but I believe a 48 x 16 (exactly 3:1) can cause the rear tire to wear out faster.
September 18, 2012 at 12:43 am #951367dcv
you’re right, 48×16 has one skid patch – meaning you would always skid on the same spot. but that only matters if you don’t use brakes.
February 6, 2013 at 8:51 pm #961344vvill
ParticipantOk, some questions on one geared stuff in general.
I have a threaded fixed hub+wheel now and definitely want to be able to put a freewheel cog on the free side, which only go down to 16T. So I am leaning towards getting a 48T chainring but don’t know if I need something specific to SS/FG and how it will go with the chainline, since you can’t really change the position of the cog on your hub. I know very little about cranksets and BBs etc. The current crankset is a Shimano triple 2203 52/42/30, basically like Sora. Would I be able to just buy a 48T chainring and put it on the existing crankset? Would it be worth just getting a new set?
A 48T seems to give nice options for gear inches. Any particular reason so many people have 48T chainrings on this thread?
48-16 ~79 gear inches
48-17 ~74 (about what I’m doing on my SS now, running 23s but the bike has clearance to go up to 32s)
48-18 ~70
48-19 ~66I’d prefer to stay 3/32″ since I already have some chains.
